Question about Beverage-Air MT27 Beverage Cooler Commercial
Lighting problem on ur30g cooler
I cannot get my cooler light to come on. I purchased a replacement bulb and still nothing. I cannot find the ballast or starter (I looked every where)Ca you please tell me where to find the statrer. Thanks Beverage Air UR30ge
  • wylekyle Sep 10, 2008
    interior light in the ur30g not working. new bulb, no light!
SolutionGuy
  • 331 Answers
SOURCE: bev air cooler
Bill, the main reason I've noticed for higher than normal temps in these boxes is filthy condenser coils (this will affect pressures in your sealed system). Remove the front lower panel and inspect your coils. Use a coil brush or a dust broom to thoroughly clean them up, don't use water. You can also pick up some condenser coil cleaner in a spray can from your local appliance parts store, but it's not necessary (the fumes are strong and may be objectionable to your customers... it gets 'em really clean, though!) After cleaning the coils, allow 24 hours for temps to stabilize. If they don't, here is a site for Beverage-Air, contact your local servicer with you exact model and serial number for pressure specifications. http://www.beverage-air.com/technical.service.html Hope this helps! Let us know, will ya?
Posted on Aug 13, 2007
Bob Gemmell
  • 209 Answers
SOURCE: Beverage Air UR30GE Won't Get Cold.
If the thermostat has been bypassed it sounds like lack of refrigerant gas in the system. The level cant be checked visually, it will need to be checked by an engineer with pressure gauges.
Posted on Sep 28, 2007
  • 7 Answers
SOURCE: Interior light
switch may be open
Posted on Jan 17, 2008
refritech08
  • 149 Answers
SOURCE: Vertical light
yes there's a ballast. on the top of fridge where you put the lights for the sign if you remove the plastic cover there should be a couple of them there.
Posted on Apr 23, 2008
refritech08
  • 149 Answers
SOURCE: Beverage-Air MT72
Bi-pin Fluorescent Lamp Installation /Verification Prior to applying power to the unit, verify that all lamps are properly installed and fully engaged in the lamp holders.
Proper lamp engagement is achieved by rotating the lamp 90° from its insertion position until it "snaps" or "clicks" into place.
Visual verification can be made on units without safety shields by using the identification mark on the end of the bulb. Properly installed bulbs will have the mark centered between the "halves" of the lamp holder.
On units with shields, the identification mark cannot be seen. Physically verify that the lamp has been rotated and locked into place.
Caution: Improperly installed lamps may cause damage to the lighting circuit. Beverage-Air shall have no liability whatsoever for equipment or component failures or other damages or losses which arise as a result of improper installation.
Can I replace the VEB82122 ballast on my hunter fan with a "regular" light kit?
Use an 8 inch Circline T9 daylight LED and directly relamp fluorescent FC8T9 bulb without rewiring
Feb 18, 2017 | Hunter Dryers
We have fluorescent cove lights in the living room. We think the "starter" is bad, but we can't locate the "starter". Can you help? We have tried switching the working light bulbs...
Very few flourescent lights have "starters" these days. If it does have a starter, it will be a visible cylindrical object usually located at either end of the fixture. More likely it's the ballast that is bad. Turn off the power and remove the cover to the fixture. The ballast will have a lot of wires coming out ot it. Take note as to where all the wires are attached, remove it, and take it to a hardware store or Lowes or Home Depot to get a replacement. Make sure it is an _exact_ replacement. Sometimes it's easier and cheaper just to replace the entire fixture as some of the older ballasts are expensive due to there being replaced by newer technology.
Dec 10, 2010 | Sli Lighting 48" Fluorescent Bulbs 34...
If all lights off on my coca cola commercial cooler now, is that because ballast issue?
Or it could be a problem with the light switch(with most commercial coolers, there's a light switch near the thermostat, if not, it may be hidden somewhere else on the machine.) Before replacing the ballast check to see if you have power coming to the ballast with a voltmeter. If you do, either the ballast is bad or all of the lights are bad(not likely, but possible).
If you don't have power coming to the ballast then go back to the light switch and see if you have power before the switch, if you don't, there's a wiring problem before the switch, if you do, the switch is your problem.
Mar 30, 2010 | Refrigerators
Two different size ultraviolet ballast. The .71AMP ballast feeds two 40W ultraviolet ''UV'' bulbs. The .37AMP ballast feeds one 40W ultraviloet bulb. The two light to larger bal;last want come on. The...
I usually test the ballast simply by excluding everything else.
1) Put in bulb that you know works
2) Replace starter (if you have one)
3) check that wiring is intact (sounds like it is for you but I had one light that the wiring barely made contact so sometimes it came on and sometimes it blinked)
4) If all that is good, then it's probably the ballast.
Sep 29, 2009 | Garden
Flourescant lights flickering
is there a ballast or a starter? if there is a starter (little silver metal or white plastic can), then replace the transformer inside the lamp housing. if there is a ballast (long black rectangle with many wires) and you replaced that and the lamp, then there must be a power drain in the unit somewhere.
Aug 25, 2009 | True GDM-12 Refrigerator Commercial
True 2 door light problem
I believe that unit has a ballast tucked in somewhere in the compressor compartment. It may be easier to access from the back of the unit. I don't think it has a starter.
Dec 09, 2008 | True TD-95-38-LT Beverage Cooler
Interior Lighting on True Refrigerator Unit
A starter may be located in the top area inside the cooler. Not all true coolers have starters. Check the connections where the light pins slide into. Also may need new ballast.
Jul 24, 2008 | True GDM-9 Beverage Cooler
Vertical light
Jan 15, 2008 | Beverage-Air MT27 Beverage Cooler...
Fluorescent light that keeps flickering
The ballast is a device that utilises and expanding/contracting electromagnetic field to create the high voltage which is needed to run fluorescent lights.
It is normally found behind the front cover or reflector part of the fitting and looks like a small box.
Replacement should normally be done by a person qualified in this field.
Oct 26, 2007 | Sea Gull Lighting Sea Gull Energy Saving...
Beverage-Air MT27 Beverage Cooler Commercial Logo
392 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
