Question about Frigidaire FEQ1442ES Electric Dryer
The dryer runs but isnt heating at all - Frigidaire FEQ1442ES Electric Dryer
  • Frigidaire Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape and running the dryer to check to see if the element is red or not,
or with an ohm meter check the two terminals of the thermostat/thermister
after you have removed the wires, the thermostat/thermistor should have/show continuity across the terminals.
If the coil heats up, or the thermostat/thermistor shows an open circut
then replace the thermostat/thermistor as it is defective.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the an element go to the following website, it will give you an idea what you are in for:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Jan 02, 2011
My dryer isnt heating
That could be a bad element, the motor runs on 120 the heater need 240 you might have a bad breaker, the timer could be bad. A safety limit could be tripped. Lots of reasons for no heat, mostly though
it turns out to be the element but not always.
DRYER PROBLEMS AND SOLUTIONS repair page for American dryers
Dec 17, 2012 | Dryers
The unit is running but is not drying the clothes.
notreading in your question that the dryer isnt heating i will assume it is heating yet not dryer the clothes and have ya check for a blocked and or chrushed vent
Jul 02, 2011 | Whirlpool LER5636P Electric Dryer
The dryer isnt putting out any heat but is running any suggestions?
Yep, your heating element broke. If you open up the back of the dryer you will see what look like springs surrounding the drum. Follow the springs until you find the break. Replace the element. Hope this Helps.
Jan 04, 2011 | Kenmore 67632 Electric Dryer
The everything in the dryer is running fine but the heat isnt working
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 14, 2010 | General Electric DBSR463EGWW Dryer
I have a kenmore elite he4 dryer and it is running but isnt getting hot. Need to know where the fuses are located to check them
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Sep 04, 2010 | Kenmore Elite HE4 Electric Dryer
My dryer willl tumble but does not heat up I worked fine last time
first thing go to elc panel breaker box make sure breaker isnt triped if it isnt u either have a heating coil out or the heat sensor out
Oct 23, 2009 | Dryers
My whirlpool duet dry isnt heating the laundry.
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 15, 2009 | Whirlpool GEW9250 Electric Dryer
My dryer run but it isnt giving any heat
Need someone to check the temperature. high limit switch or the elements. I will help someone from here search and find problem. Let me know, Thanks, Sea Breeze
Mar 19, 2009 | Kenmore Dryers
KitchenAid elec. dryer not heating
check and make sure your breaker isnt part way flipped .... dryer will run on 110v but wont heat unless it gets 220v ,,,, break may look to be on but not ,,, turn off breaker, wait 30 sec and flip back on hard / larryyb
Dec 05, 2008 | Dryers
Dryer problem
What brand of dryer is it? Model number? The lack of heating could be a number of things. Be sure the vent tube isnt clogged or pinched. The other options are bad element, bad thermostat or bad thermofuse. Depending on what type it is would also depend on how to make the repair, how to get to the parts, etc. Get me a little more information and we'll get you heated up. Jim
Sep 08, 2007 | GE DBXR463GB Gas Dryer
Frigidaire FEQ1442ES Electric Dryer Logo
43 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
