Question about Kenmore Refrigerators
Kenmore Elite refrg. constant error FF massage. We try to get everything in and out, rearrange and back and forth, but after running for a while will get the same error again, I even try to relocate the fridge here and few inches no help. < model# 795.77572600 // serial#609KR00153 Thank you
  • 15,935 Answers
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Thanks for using FixYa
Posted on Jan 02, 2011
What er ff mean at Error message on display of Kenmore Elite Bottom Freezer Refrigerator
Hi.
Error ff (er ff) means defective fan detected. Before calling support or before replacing the fan try performing a complete defrost by leaving power disconnected for one day (remove food from inside the unit first). That will fix the problem if the fan was temporarily malfunctioning because of ice formation. If that does not work the fan must be tested before replacement.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 09, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
What does ER FF mean on my Kenmore Elite bottom
Hi
Thanks for using FixYa. Error ff is freezer fan fault. This usually happens when either the rear board has gone bad or the freezer fan itself is bad and needs to be replaced. To check what is causing the error you can start with checking the fan which is located behind the back wall inside the freezer. Also check the rear board as it might not be putting the fridge into defrost long enough and is causing the ice to build up in the freezer and thus stopping the freezer fan from turning and so causing ff error. Leave the fridge unplugged for 24hrs which will melt all the ice then plug it back if still the issue is not resolved and you hear the fan running then it is the rear board that needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 30, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore bottom freezer control panel error ER FF
it is probably the defrost controller and the board on the back. The code means your freezer fan is not working
Nov 11, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite error message er ff
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My trouble codes are Er FF on my kenmore elite
My kenmore Elite 795.77569600 fridge has er ff code
I pulled plug out of the wall socket waited a minute re-plugged unit in and so far error hasn't come back.
Sep 01, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite ER FF
Possible sesor error. Unplug for bout 10 min then plug back up.
Jan 30, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore ELITE error code ER FF
ER FF error is malfunctioning evaporater fan
hope this helps
Oct 18, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Error Code Er FF
ER FF - found in another post = Error Freezer Fan. Removed freezer back panel (inside freezer), defrosted ice build up around fan. Error message gone for now. Easy fix at midnight - 20 minutes. Will be looking into ice-up cause.
Jul 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
57 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
