Acer aspire 5534 won't boot and will only stay on long enough for the computer to make a beeping noise or for a light to briefly turn on. The power cords are all plugged in.
  • 6,826 Answers
Check that the battery is fully charged or that the power supply to charge the battery is working correctly.
Posted on Jan 02, 2011
  • Duane Wong
    Duane Wong Jan 02, 2011
    Use a multimeter to measure the voltage coming out of the power supply. And, also measure the voltage of the battery when disconnected from the laptop.
Acer aspire ast180
That will generally indicate a major system problem on just about any PC. On your PC it should be indicating an issue with the video subsystem. These problems are not always fatal so it might be as simple as pulling the power and battary for a full system reset or you might need to do a firmware reset. at any rate I am not an expert on Acers so hear is a link to the Acer help site with the exact error you are having and they did get it fixed. take a look.
https://community.acer.com/t5/2013-Archives/Aspire-T180-won-t-boot-and-is-making-a-beeping-noise/td-p/29389
Apr 01, 2017 | Acer Aspire T180-EA350M (AST180EA350M) PC...
Acer computer won't boot has long buzzing noise
The long buzzing sound indicate the nature of the problem. Depending on the manufacture of your bios will determine the problem. With only one long beep you may have memory problem. The computer cannot initiate the boot sequence. Did you add any devices to the computer prior to your problem. if you did undo what you did. Make sure the computer is on, if nothing happens ( no lights, no sound, no fans etc.) the computer has a power failure. Make sure you listen to the beep if it is a numerous beep sequence note it down and check the web for computer beep during boot up.
Mar 25, 2012 | Computers & Internet
My laptop shuts off after i turn it on.why
Does your laptop even begin the boot process where it displays stuff on the screen? Do you hear fans running, disk drives running, see lights, hear the cd drive click once and notice a light that comes on the cd drive door briefly when you press the power button? If not you computer either has a bad power cord, a bad dc power jack where the power cord plugs in, a bad mother board or static build up. 1) lets eliminate static buildup by removing the power cord and the battery then press and hold the power button for 30 seconds. Then replace the power cord but not the battery and hit the power button. If it boots up you had static build up. 2) Take an ink pen and put in in the slot where the power cord plugs into the laptop, if it wiggles loosely then your dc power jack which is soldered onto the motherboard needs to be replaced. 3) If the power jack is tight and when you plug in the power cord if you don't see any lights or hear a fan, disc, cd drive, then you can almost bet your power cord is bad. 4) If the power cord is ok then you have a mother board issue. Normally motherboards will give some beeps or constantly blinking lights when you plug in the power cord and try to boot up. These beeps or blinking lights will tell the technician what is wrong with your computer.
Mar 19, 2012 | Acer Aspire One Netbook 8.9" Notebook
How to reset my ASPIRE 5534 Series laptop do to
I can't get my Acer Aspire 5534 to play movies on DVD
Jan 06, 2010 | Acer Aspire One PC Notebook
Acer aspire one power button comes on but screen doesn't come on.
1/ Take a close look at the display in bright light; can you see anything there? (If so then the CCFL (or its power supply) needs replacing on the display
2/ hook up an external monitor and see if that works (or at least if the light stays green on the monitor)
3/ Any boot beep? any "Windows sound"?
4/ try removing the battery and (using only external power) see if it starts.
4/ remove the battery AND the external supply, hold the power switch in at least 30 seconds. Hoojk it up again, try it.
JOAT
Oct 16, 2009 | Acer Aspire One PC Notebook
My acer aspire one would not boot it would make it
Did you try to start it with the battery removed from the pc?
Jul 21, 2009 | Acer Aspire One PC Notebook
My compaq presario 700z power up but will not stay on
ANY FLASHING LIGHT ANY BEEPING NOISES
THE SYSTEM IS NOT BEING COOLED ENOUGH AND IT IS SHUTTING DOWN SO NOTHING WILL GET DAMAGED
POWER SUPPLY I THE PROBLEM MOST LIKELY WITH AVAILIBLE INFORMATION
ROD THE CANDYMANGANDY
Jan 13, 2009 | Acer Aspire 3680 Laptop
My pc won't work!
Assuming you get 2 beeps on boot up, take the side off your pc and see if the whirring sound is coming from your hardrive, if so you may have a damaged sector on your hardrive where the boot sector is. If you have a Windows XP disc come back here, if not you need to take your hardrive to a friends pc and set your hardrive as the slave drive before connecting up. When booted up go to My computer and right click on your hard drive (could be 'D' drive or 'E' or 'F')depending on other pc. Go down to properties then tools tab and click error checking and let the system check for errors and automatically repair them. Your rating is importanat
Nov 15, 2006 | Acer Aspire T310 PC Desktop
Computers & Internet Logo
233 people viewed this question
David Payne
David Payne
