My WeatherKing A/C heat pump is 5 years old and friday I was told it shorted out and burnt my compressor. Because of government specks today, I was told that I would have to replace the outside unit and the inside unit also because a new unit was not compatible with the furnace inside. My home is 2300 sq. ft. What is my best buy for new equipment, and what kind, Lennox, Rheme, or Trane, or am I being conned?
  • 43,501 Answers
Yes!! You are being conned.... that compressor can be changed without changing the whole outdoor unit or anything else....
Get another company to look at it and find one that will just change out your compressor... then there is no need to change both the indoor and the outdoor units...
heatman101
Posted on Jan 02, 2011
I have a Speck Pump, model E71, only a year old. It suddenly stopped working - it was fine at the start of the season. The problem is that it just hums when turned on.
Since it hums it has power. I believe there is a start capacitor on it, that or the start switch may have failed.
Speck Pumps Pool Pump Parts
usa speck pumps com
have Speck Pump model E71 only year old It suddenly stopped working it was...
Speck Pumps Pool Products Inc
Jul 02, 2016 | Speck Pumps Pool & Spa
Compressor short cycling
If the condenser fan works , try replacing the compressor relay and overload (it;s the most common problem) but if the compressor still goes on and off , probably is burnt or jammed and has to be replaced.
Nov 03, 2009 | Refrigerators
LG LHD30 the compressor does not cycle on
Compressor won’t Start
The Main reasons that this will happen
1 - A bad run capacitor (silver or metal capacitor)
It’s either shorted, grounded or open.
If it’s shorted a lot of times it will bulge out, (sometimes slightly)
2 - A bad start kit ( plastic capacitor and Relay connected to it )
The capacitor is either shorted or open
The relay either has an open coil between terminals #1 and #5
Or the relay is stuck.
Any time you change the capacitor or relay you should change
the other, especially if they are over a year old.
3 - A loose, burnt or disconnected wire
4 - Wired wrong
5 Compressor is open (windings burnt open)
6 Low on charge not getting enough cooling back to compressor, (Feel top of compressor to see if it’s hot it shouldn‘t be)
7 Some compressors have a black plastic overload under the compressor cap which could be bad.
Aug 07, 2009 | LG DH30 GoldStar Dehumidifier
Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Aug 04, 2009 | Amana PTH123B25AJ Heat Pump Air...
Ac is on but its not pumping out any cold air
Compressor is probably not running.
4 - Wired wrong
Jul 29, 2009 | Honeywell ER150B Air Conditioner
Compressor won't start
4 - Wired wrong
Jul 29, 2009 | Ebac BD150 Dehumidifier
Compressor don't kick in
4 - Wired wrong
Jul 28, 2009 | Frigidaire FAA068P7A Air Conditioner
Compressor Problem WeatherKing 13AJA36A01
Your warranty on your WeatherKing is five years on the compressor. When you buy a compressor to go in your unit it is 1 year. Several resons for bad valves. Dirty evaporator coil, overcharged and bad evap fan motor. James
Jul 10, 2009 | Heating & Cooling
Replaced my 5-year old 3-ton 12 SEER Goodman outside condensing unit with an older 3-ton RUDD condensing unit because of lack of funds. Now the compressor has gone out on the RUDD. Is it better to replace...
at 5 yr on goodman unit rhe comp should of been under warrenty if theat is what was bad with it on the rudd that was a 3.5 ton out door unit are you sure the pump is bad pulling locked rotar amps or shorted to ground check the wires on the comp to make sure not burnt check the capicitor as far as replacement i always lean twoards new unit unless not going to live there long due to comp is 1 yr and labor around 850 +325 for pump i would go with another used unit over comp replacement 13 seer goodman w 99yr pump and latley have 5 yr free labor and I normally dont recommend a brand of unit on this site go to a hvac store and ask who may have a used unit I have had some still w warrenty before that came from remodel jobs in up scale areas! if helpfull rate me good luck
May 12, 2009 | Ruud UAKA042 Air Conditioner
2 TON WEATHERKING HEAT PUMP VIBRATION AND NOISE.
Your friend is correct. Installing a sump or p-trap in the suction line will probably help. The oil may be leaving the compressor but can't get back.
Feb 23, 2009 | Weather King 10AJA6001AH Air Conditioner
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
