Question about Blitzz Technology (BWA611) Router
Laptop will not connect to blitz router
Wife's laptop can no longer connect to blitz wireless network. Worked fine up until now. I don't think its a problem with the router because I'm connected to it right now. We have not changed any settings on her and have not downloaded anything lately. Any help would be appreciated.
  • 1 more comment
  • dualjase Jul 09, 2008
    Yes we checked that. What her computer is saying is "wireless association failed because windows did not receive any response from the wireless router or access point. I don't know if it helps but she is using Vista.
  • catherinehc Oct 07, 2008
    I have a Blitzz Super G 108 Mbps Wireless Firewall router
    model: BWA 711
    Most of the time I can't connect, and even when I do I end up losing the connection. Ugh!!!! Also, when I click on wireless properties, it says that my BWA711 is an UNSECURED Network??!!!
    Help!!!!
  • Anonymous Dec 24, 2008
    I have the same problem wat should i do ???
My laptop cannot connect to the blitzz wireless network. Worked fine until we moved the computer. The router is working.
Posted on Sep 23, 2008
    Sergeant:
    Champion:
  • 250 Answers
Make sure the laptops wireless card has not been turned off. Many laptops have a button where you can turn off the wireless card.
Posted on Jul 09, 2008
  • Frank Gant
    Frank Gant Jul 09, 2008
    I would start by turning off any encryption and wep key etc you might be using on the router and trying to get connected that way. If that works you at least know the wireless card in the laptop is working. Vista is a pain for getting wireless to work sometimes.
At&t wireless router and magic jack setup
It could be the router which is giving you issue. Press and hold the reset button for 30 second and this makes the configuration to go back to its previous settings. The reconfigure the router with a new SSID and security key. Try connecting to the wireless network, the computers will consider it as a new network and will connect without any issues
Apr 09, 2010 | 2wire 1800HG Router (RG1800HG00)
I am trying to connect my macbook pro 4.1 to a wireless printer. That printer works fine - when on wireless with my wifes windows machine and it works fine if i connect my mac to the printer- just not n a...
IN the case of the Mac what I have had to do in the past was shut down the other laptops and computers, delete the printer program from the Mac and start over. During the setup of the printer make sure nothing is connected to the printer. Only connect what you are instructed to at the appropriate time. It will eventually ask you how you are going to connect to the printer from that particular printer, answer ethernet cable and attach the ethernat cable to the printer from your router, make sure your laptop is connected to the router with an ethernet cable. Always set your computer up to the printer vis a hard line, then onve it is done you can swap over to a wireless setup. Once the setup is complete and a test print is accomplished bia ethernet cable, then disconnect the cable from the laptop to the router. Once you are connected to the network wirelessly, attempt another test page, you have already set the printer up at this point to be your default printing device so the laptop will find the printer on the network and initiate it. You may have to watch close for a pop up window asking to allow the connection or access to the program. Maybe think about dropping the firewall temporarily until the connection is secure.
Nov 29, 2009 | Computers & Internet
My wireless laptop worked fine until i returned from vacation. Now i can't sign onto the internet. It says isp or no newtwork. What happened when I used this on vacation under my cousins router?
Check under network connections and see which network is set to default You may be trying to sign on and connect to the wrong network.
Please rate my help++++ Thanks for using FIXYA
Nov 24, 2009 | Microsoft MN-700 Wireless Router
Motorola SBG900 Assign network address to computer
I guess your modem router was already configured well since it worked already previously. It seems that your motorola router is set to broadcast dynamic IPs (DHCP enabled) and your last connected Pc and laptop were configured with static IP. Please check your "network connection" setting and make sure it is set to "Obtain IP automatically"
Reagrds!
Jun 30, 2009 | Arris SURFboard SBG900 Wireless Router...
Laptop not connectiong to wireless network
Connect the Laptop to the router with ethernet cable
Verify the wireless LAN
  • Open a browser and type http://gateway.2wire.net; the Home page opens.
  • Click the Home Network tab.
  • Verify the wireless status located on the right panel (Status at a Glance) is Disabled.
  • When the status is disabled, then enable the wireless LAN .
May 27, 2009 | 2wire 2700HG-B Router (2700HGB)
Unable to connect my wifi laptop to my existing wireless b/band
Your wife's laptop is setup to connect to another wireless network. It must be set up now for the wireless network that you are trying to connect to. This means that your wife's laptop is trying to connect to the wireless network somewhere else. You need to let the laptop look for available wireless networks. It should be able to see your wireless network. It will then require you to enter the password that you have set in your Zyxel. If you don't know the password, call Zyxel.
Feb 23, 2009 | Zyxel Prestige P-330W Wireless Router...
Cannot get wireless connection through router
Hi MistiShay,
You did mention that it was working fine for several weeks suddenly your wireless computers stopped functioning and your getting a message that the security key in incorrect. This only means that its either your entering the wrong encryption key or someone changed the previous security key to something else. By the way what type of wireless security did you configured on the router initially was it WEP or WPA, if its WEP(64 or 128 bit) and your using a bulit-in wireless adapter on your laptop you need the default WEP key because the passphrase only works with a Netgear WLAN Utility.
Know if your having difficulties accessing the setup page of the router you may need to check on your browser settings, turn off the pop up blocker and firewall temporarily, also try another computer. Now if all fails you may need to press that reset button on your router and set it up again.
I
Jul 28, 2008 | NetGear RangeMax WPN824 Wireless Router...
IE will not connect to internet
First I am not connected with the product that I am recomending in any way shape or form.
On a wired PC download Network Magic (the free version is all you will need). Burn a CD with it and install on the laptop. Bring up Network Magic and use it to connect to the network. If it can not find the network, run Network Magic on your wired PC and bring up the Network Map and look to see if you can see your router on the network. Log into the router and start by reseting the wireless.
http://www.networkmagic.com
I use this product on all my laptops and desktops it makes networking simple.
Dec 14, 2007 | Linksys Wireless-G WRT54G Router
Blitzz Technology (BWA611) Router Logo
249 people viewed this question
Top Blitzz Technology Computers & Internet Experts
Michael Galve
Michael Galve
fred capra
fred capra
Are you a Blitzz Technology Computer and Internet Expert? Answer questions, earn points and help others
