Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
The brush stoped rotating - Dyson DC07 Bagless Upright Cyclonic Vacuum
  • 78 Answers
There are a couple of reasons that the brush bar will not spin on a Dyson DC07.
1. The carpet / hard floor selector is set to hard floors.
2. There is material wound around the brush to the point that it is jammed.
3. The brush roller bearings are full of dust and **** so they have siezed up.
4. One of your
belts has snapped (there are 2)
5. The clutch is faulty.
Now to describe how to check each of these is a full essay so I have made a video instead. I have gone through each of these except maybe point 1 because it is self expainatory.
Have a look at the video and if it is helpful then please leave me a thumbs up, a comment or a testimonial.
If you find out that you need parts have a look at
Nelson Vacuums or VacuumSpot.
Hope this is helpful!
How do I check the clutch or brush roller of my Dyson DC07?. (video)
Posted on Jan 08, 2011
Spinbrush not working on eureka as1104
If the belt is intact, the brush roller ends may be so jammed (usually with hair) that it cannot rotate. Also, if the brush roller cannot rotate, the motor shaft may be rotating in one spot on the belt and eventually will burn it out. The solution in the case of the brush roller is to remove it and check for free rotation. If the ends are binding, the brush roller will have to be disassembled to remove debris.
Aug 10, 2014 | Eureka Vacuums
My brush is not rotating
Hi there, it's Jack at Dyson.
I'm sorry to hear your DC33's brush bar is not rotating. This is likely to be because the brush control on the cleaner head has accidentally set to 'Hard floors'. In this mode, the brush bar will not rotate. Please recline your machine into the vacuuming position, turn it on, and make sure the brush control is set to 'Carpets'.
I'm confident this will resolve the issue, as using and replacing the wand will not have any effect on the function of the brush bar. It's also important to note that the brush bar will never rotate when the machine is standing upright.
If you would like further assistance after you've checked the brush control is correctly positioned, please get in touch with us directly. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Jul 21, 2013 | Dyson DC-33 MultiFloor Upright Vacuum...
Brush bar doesn't rotate.
Either the bearing in the rotating brush is bad and isn't allowing the brush to turn, or in the majority of cases, the belt is broken.
May 20, 2012 | Vacuums
Carpet brush not rotating
Did you check the drive belt for the roller? If not do so, the smell was the belt drive burning up.
Jan 16, 2012 | Kenmore Vacuums
Need to replace belt and cannot figure how to take it apart to get at the belt --- Took Screws off on the bottom but could not get to the belt
You have already removed the screws so lift the brush cover off. Then grasp rotating floor brush at both ends and lift. Clean strings,hair and other debris from rotating brush, paying close attention to the brush ends. Clean the debris from motor pulley and drive belt areas.Grasp old drive belt and remove from motor pulley. Place new drive belt over motor pulley and stretch other end over rotating floor brush in the space between the bristles. Place the ends of the rotating floor brush down into slots on the sides. Turn the rotating floor brush by hand several times in the direction of motor pulley. If installed properly, drive belt will center itself on rotating brush. Reposition brush cover and screw back into place. I hope that this helps you!
May 26, 2011 | Bissell 3591 CleanView Bagless Upright...
My model F5906-900 --- problem is the brushes have stoped working... I pulled the brush assembly out by holding the two tabs, and all seems clean and the brush assembly rotates easly... onced the brush...
(1) Assure the Brush Control on the hood is NOT set to the OFF position.
(2) Remove the brush assembly by pulling/unlatching it from base on each side.
(3) Does one of the brushes have the drive pin present? It should be about ¼ inch square, and two inches long. It attaches the brushes to the drive mechanism.
(4) Remove and clean the intake filter. One the base of the cleaner, behind the brushes, squeeze the two red abs together and pull the panel down to access the screen. Clean the hair/debris off the screen and reassemble.
Mar 10, 2010 | Hoover F5906-900 Upright Steam Vacuum
Kenmore 116.23513301
If the motor on the power brush is running the belt is bad, if the motor on the power brush only runs when you push the overload, the overload is bad.
Sep 14, 2009 | Kenmore 22812 Bagged Canister Vacuum
Brushes wont rotate
the belt has streached go to walmart and get a new one.
Aug 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
G4 kirby
ensure the safety switches are made properly by making sure the front brush assembly is fitted properly, you will see a tag that enters the machine making the front switch, secondly make sure the bag bottom housing is on properly and fully rotated so that its tag makes the switch on the side.
The only fuse is in the plug (UK).
Common fault is the mains lead broken internally, unplug from the side of the machine after removing the little cover where the wire goes in. You can use a kettle lead to test the hoover.
If this does not cure it most likely the motor brushes are worn.
Jul 24, 2008 | Kirby G4 Bagged Upright Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
46 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
