Question about K1200lt Motorcycle Security Alarm System Kit Diy
I have a 2002 BMW K1200LT motorcycle. i am trying to locate the program plug under the seat to reset the alarm system.
HI,
Do you have a factory system or aftermarket? What has gone wrong so that you need to reset it?
motorcycle security chains
http://security-chains.com
Posted on Jan 04, 2011
Will not start
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
K1200LT 2002 Will not start BMW Luxury Touring Community
2000 K1200rs Cranks but wont start Bikes com Excellence in Motion
1999 2009 BMW K1200LT Service Manual Moto Data Project
BMW Motorcycle Parts Fiche OEM BMW Motorcycle Parts online 1970 present BMW http://www.bmw-motorrad.com/us/en/index.html?content=http://www.bmw-motorrad.com/us/en/services/manuals/manuals_main.html¬rack=1
Mar 22, 2014 | 2000 BMW K 1200 LT
BMW K1200LT won't turn over at all, got all ignition lights but will not start 03 reg
Hi, Paul and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Security alarm needs a reset.
6. Starter control circuit, relay, or solenoid faulty.
7. Faulty starter button.
8. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
K1200LT won start BMW Luxury Touring Community
2002 k1200lt won start but battery and electrical is working
https://www.tradebit.com/filesharing.php/search/0/bmw+k1200t BMW Motorcycle Parts Fiche OEM BMW Motorcycle Parts online 1970 present BMW
Mar 29, 2013 | BMW Motorcycles
2005 BMW R1200 RT Alarm System
Hi, Mail2dws for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
http://www.bmwmotorrad.com/fi/fi/bikes/tour/k1200lt/media/Rider_s_Manual_Alarm_DWA_5_2005.pdf
Alarm Reset after New Battery Installation BMW Luxury Touring Community
Bmw r1200rt service manual pdf
Mar 15, 2013 | 2005 BMW R 1200 RT
BMW k1200lt will not start...only blown fuse is alarm system, horn and brake light
Hi, Anonymous if your alarm is disabled your bike will not start you may need to do an alarm reset for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.15amp fuse blowing on Brake lite Horn alarm fuse BMW Luxury http://www.k100.biz/pdf/FAQ/FAQ_K100_tips.pdf
http://www.carlsalter.com/download.asp?p=347
Mar 10, 2013 | 2000 BMW K 1200 LT
How to change low beam light bulb on 2002 BMW K 1200 lt
Hi, Stueckle3 I am sorry you can't find the first and best tool you ever bought for your BMW but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
BMW K1200LT DIY HID Xenon Headlight Installation
2001 BMW K1200LT HID Installation
https://www.rbracing-rsr.com/downloads/K1200LT_Repair.pdf
http://www.bmw-motorrad.com/fi/fi/bikes/tour/k1200lt/media/Rider_s_Manual_K_1200_LT_2008.pdf
May 27, 2010 | 2003 BMW K 1200 LT
I have a 05 k1200lt bmw motorcycle and the
hello,if the alarm does not work it's the fuse you have to change not the alarm.so kindly go to where you have your fuse box in the bike you will locate the alarm fuse there and all you need to do is just to clean it or you replace it if it's burnt.after this is done yyou will have your motorbike working as normal again.
take care.
May 24, 2010 | K1200lt Motorcycle Security Alarm System...
Immobilser and Alarm System
Hi, Rcpirate for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
Disabling 2002 k1200LT alarm BMW Luxury Touring Community
http://forums.bmwmoa.org/showthread.php?76595-K1200LT-Security-System-Issue-Doesn-t-allow-starting
Nov 30, 2008 | 2003 BMW K 1200 LT
K1200lt Motorcycle Security Alarm System Kit Diy Logo
642 people viewed this question
Top BMW Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
greg benton
Are you a BMW Vehicle Part and Accessory Expert? Answer questions, earn points and help others
