Question about Coleman Cable Coleman Twomantle Dual Fuel Powerhouse Lantern ()
Acts like a check valve is stuck open below the plunger assembly. It lets all the pressure out while im trying to pump it up..is this something i can fix? the lantern is relatively new.
    Sergeant:
  • 191 Answers
It sounds like you are correct. While I don't know much about the new lanterns I have worked a lot on older ones. My first suggestion is the easiest. Try putting some 3 in 1 oil on it. First relieve any pressure in the tank- open the valve then slowly loosen the fill cap- watch out as it will likely spill fuel so do this outside Remove the plunger, there is a black plastic piece that holds it in it will come of either by a push and twist, or by removing a little metal bail across it. (you remove the metal bail (small wire loop) by gently pulling it outward with a small pliers.) then the plunger should come right out look into the hole and you will see a check valve at the bottom, try a bit of oil or wd40 on this, let it sit for a while, it may just be rusted open, and will take some time for the oil to work. Make sure it is working well before you light the lantern. you Do Not want this to fail when the lantern is going. Do this outside and away from any flames. Pump it up and see if it can hold pressure overnight
Posted on Jan 02, 2011
After adding gas to my Toyota Corolla 2002 LE the engine dies when I start the first time. I start again and it is cranking and after few sec it starts again...it's getting worse
It sounds like the fuel pump is going bad. If you had a fuel pressure tester you could check dead head pressure with the vehicle off and in the run position. A good operating pressure is about 41psi estimation. If you see the pressure drop right away and does not hold the pressure then the check ball or fuel pressure regulator is bad and you need to check those. Im giving proper diagonis procedures before buying somethimg you dont need. You can check a fuel pressure regulator with applying a vacuum to the valve and if the valve diaphragm holds pressure then it is good. Then all you have left is a bad checkball inside the fuel pump assembly. Unfortunately, if the ball valve is bad the whole fuelpump needs replaced. If you replace the assembly replace the filters too. A good tip to save the life of fuelpumps is to never allow the tank to run below a quarter tank because the fuel acts as a cooling system for the pump.
Oct 08, 2015 | 2003 Toyota Corolla
KARCHER 2400 PSI HONDA ENG GC SERIES 160 RESIDENTIAL PREMIUM
Hello there.
If the washer is loosing pressure then it needs to be looked at under warranty, im not sure where the fault would be, but another expert may well know.
If you don't get any suggestions then i would take it back and ask for a replacement or repair.
Hope this helps.
May 09, 2008 | Karcher 2500 PSI Pressure Washer
Tip
Backwashing A Sand Filter with A Push/Pull Slide Valve or Multiport Valve
Lots of people are first time pool owners and pool professionals forget to teach these "newbies" about the simplest aspects of pool ownership.
One of the biggest questions we receive from new homeowners is "How do I go about backwashing my sand filter exactly?"
It doesn't matter if you have a Hayward, Pentair, Jandy, Sta-Rite or any other number of Sand Filters on the market they all utilize the same basic valves for backwashing; a push/pull slide valve or a multiport valve.
To backwash with a multiport valve:
1) Shut off pump motor.
2) Press down on valve handle, rotate valve from FILTER to BACKWASH position.
3) Roll out any backwash hose or open any waste line valves.
4) Open air bleeder assembly on filter, and turn pump on.
5) Watch pressure gauge for backpressure and hose for kinks. Be prepared to shut off pump quickly.
6) After hose fills with water, run for 3 - 5 minutes or until water runs clear.
7) Shut off pump motor and move multiport valve handle to RINSE position. Run on rinse for 15 - 25 seconds.
8) Shut off pump motor and move multiport valve handle to FILTER position.
9) Turn pump back on and note lower pressure.
10) Roll up backwash hose so the dogs use it as a chew toy.
To Backwash a sand filter with a slide valve:
1) Shut off pump motor, roll out backwash hose.
2) Twist to unlock plunger T-handle, push or pull(depending on manufaturer) the plunger 2" - 3".
3) Open air bleeder assembly on filter, and turn pump on.
4) Watch pressure gauge for backpressure and hose for kinks. Be prepared to shut off pump quickly.
5) After hose fills with water, run for 3 - 5 minutes or until water runs clear.
6) Shut off pump motor and push T-handle back down into locked position.
7) Turn pump back on and note lower pressure.
8) Roll up backwash hose.
Now you are a backwash Guru!
More tips and tricks are available form The Ugly Pool Guy, www.WeFixUglyPools.com
on Dec 14, 2010 | Pool & Spa
Pump not adding pressure to water flow
stuck valve ( only needs one ) or plungers not moving . check each value methodically , then go deeeper if necessary.
Feb 01, 2014 | Annovi Reverberi RSV4G40HDF40EZ Pressure...
Dewalt compressor builts pressure but doesn't supply hose and tool with the air
Dewalt sells a rebuild kit for the regulator (my be part # N008792). You could try lubing the internal parts before ordering the kit. With no air in the tank, remove the plastic knob assembly and pull out the small piston. In the center of the valve body will be a small brass plunger. You should be able to push this plunger in with thumb pressure. If stuck, remove the nut on the back of the valve and lube the plunger with grease (pull the plunger off the back-nut if stuck in place). Lube the piston and cylinder (black plastic piece) with grease and reinstall. The small piston has a lip seal that should point toward the body of the manafold. For emergency air, remove the safety pop-valve and install a tee fitting. On this tee fitting reinstall the safety valve on one port and a quick disconnect on the other. You can draw air out of the tank at full pressure untill you repair the regulator. Good luck
Mar 29, 2013 | Dewalt D55141 Heavy Duty 2 Gal, 150 Psi...
Porter-cable plunger extended and will not reload new nail
could be a jammed nail in the nose assembly, try removing all the nails and dry firing. If still the same after making sure nothing stuck in the nose, you probably have an issue with the firing valve or piston.
Dec 31, 2011 | Porter Cable Tools & Hardware - Others
SSR EP 40 SE shuts down on low unload sump what is probable cause
I would look at the minimum pressure check valve first. If it is stuck in the open position you can not build sump pressure before the unit shuts down. MPCV is located on the top of the separator tank. You can remove it. Check to see if the plunger with the teflon disc is free and not damaged. These valves often seize up due to dirt,rust and condensation. If it is stuck it will need to be disassembled, cleaned and lubricated. It needs to be free enough to slide in the valve body by hand. If the o-ring is bad or damaged you will need to get a kit from IR. I have not been able to find one with out buying a kit. Next I would look at the blow down valve. It is located beside the MPCV at the top of the separator tank. If this solenoid is open it will not let the sump build pressure. Next I would check the Inlet valve actuator cylinder if so equipped. With out the serial number I dont know which type inlet valve is on the unit. If it does have a cylinder does it operate correctly. Is there any free play in the cylinder. If so replace it. Is the cylinder to inlet valve coupling cracked. Remove and inspect. Is the bolt tight at the rear of the cylinder. Will it let the cylinder move. If so you will need to loosen the bolt. Set the controller so you can see sump pressure. Start the unit and Slowly open the inlet valve by sliding the cylinder in and out to get 25psi sump pressure. Then tighten the bolt. if sump pressure drops below 15 psi it will shut down on sump pressure alarm. Good luck !!!
Aug 30, 2011 | Ingersoll Air Tools & Compressors
My pssure washer the pump will not kick on so i have very low ater pressure
If you take the valve body on the pump apart very carefully you may found a broken return spring or a blown out rubber o-ring if the engine runs but the pump doesnt pump high pressure check your pressure relief valve sounds like its stuck open.
Apr 17, 2010 | Comet BXD2527 Pressure Washer Pump
My 2004 dodge 3500 diesel , when i am driving is reving from 500 rpm to what ever speed im driving rpm range is. it act like its not getting enough fuel .....could it be some bad fuel
stop up fuel filter or fuel injection pump. pressure low.make sure air filter is not stopped up.diesel engine need to get air in order to run well .check the egr valve and pvc valve .make sure they are not stuck open.
Apr 28, 2009 | 2004 Dodge Ram
Coleman Cable Coleman Twomantle Dual Fuel Powerhouse Lantern () Logo
425 people viewed this question
Top Coleman Cable Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Coleman Cable Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
