Question about ZAGG Invisibleshield Nokia N95 8GB (NOKN952) Case Flash Memory Card Case
I changed my lock code for my phone, the phone locked automatically,i inputed my code and it didn't open the phone. what do i do?
    New Friend:
Waht can ido
Posted on Jan 01, 2013
Changed bcm because auto door locks and driver window did not work, when i changed it everything work like it should but had to relearn key , when the key was relearned the locks and window stopped working...
Taking your vehicle to a qualified repair shop instead of mess with thing's you have no clue about ,is what you should have done . Replacing BCM'S - needs to be programmed .
If the body control module (BCM) is replaced, the following procedures must be performed in the following order:
BCM reprogramming--Refer to Body Control Module (BCM) Programming/RPO Configuration in Computer/Integrating Systems.
Theft learn--Refer to Programming Theft Deterrent System Components in Theft Deterrent. A new BCM will learn the Passlock™ information automatically but the powertrain control module (PCM) must still learn the theft information from the BCM.
Plus the bcm has nothing to do with the power window's DDM -the driver door module controls the window .
Programmable Automatic Door Locks
The automatic door lock feature can be programmed to control the door lock system. The automatic door lock feature is factory programmed to have all doors lock and unlock. For detailed instructions on programming the automatic door locks, refer to Vehicle Personalization in Personalization.
When the automatic door lock feature is programmed to control the door lock system, the driver door module (DDM), passenger door module (PDM) and body control module (BCM) will lock the vehicle doors if the following inputs are true:
• Ignition 1 input is active.
• All door jamb switch inputs are inactive.
• Cargo door or liftgate/liftglass ajar inputs are inactive.
• Transmission is shifted out of park.
This automatic door lock function will only occur once per ignition cycle unless, a door jamb switch input changes state to active and back to inactive. Then the DDM, PDM and BCM will lock all doors again.
Once the automatic door lock feature has locked the doors, the BCM will then unlock all the doors when the transmission is shifted into park.
Before replace these componets hooking up a factory scan tool an checking data input's an DTC'S - diagnostic trouble codes .
Dec 05, 2017 | Hummer Cars & Trucks
I need to reset my combination to my mesa safe
This safe was shipped with a factory Master Code of 1-2-3-4-5-6-7-8.
If you changed the Master Code you will need to use the code you changed it to.
Deleting your current User Codes:
Input * - * lock will beep twice
input 6-6-6-# lock will beep twice
Input current Master Code - # lock will beep twice
Input user number - # lock will beep twice (not user code, user number is which user number you want to delete 1,2,3,4 or 5)
Re-input user number - # light stays green for 3 seconds
Example: * - * - 6 - 6 - 6 - # Master Code - # - 5 - # - 5 #
This will delete user 5
Unsuccessful code change: five beeps, repeat the steps.
Changing User Codes: Code length can be 3 to 8 digits long
Input 4 - 4 - 4 - # lock will beep twice
Input Current User Code - # lock will beep twice
Input User Number - #
Input New User Code - # lock will beep twice
Re-input New User Code - # light stays green for 3 seconds
Example: * - * - 3 - 3 - 3 -# - User Code 2 - # - 2 - # -New User Code - # - New User Code - #
That example will change user code 2.
Unsuccessful Code Change: five beeps, repeat the steps.
There are other things you can do with the MSL-500 lock that comes on the MFL-2014E. You can change the master code, activate user codes, change user codes, delete user codes, set single user or dual user modes (dual user modes requires two user codes to be entered each time you want to open the safe, set the time delay.
The Mesa safe company has a website which does have the operating instructions for the MSL-500 electronic lock. A Google search of "Mesa MSL-500 Operating Instructions" would get you there quickly.
Oct 18, 2013 | Mesa Safes MFL2014E Safe Depository Safe...
Micromax q75 how to release input phone lock code, I didn't given any password and all. but the is locked automatically. kindly help on this.
The following URL will provide you with a copy of the user manual for the phone. If you are unable to unlock the phone, contact your service provider for assistance. Good luck!
http://micromaxinfo.com/products/product_downloads/guide/Q75_UM.pdf
Oct 03, 2012 | Swiss Tech MicroMax 19in1 Multi Tool Clam...
Videocon v1575 qruz2 phone lock code
44162121413064 try this one, will definetely work for videcon mobiles
Jun 08, 2012 | Cell Phones
Micromax i am forgotted my phone lock code
Micromax q75 phone lock ? : Solution: If you have not changed the default phone lock code for your micromax q75 phone. Then use "0000"(four zeros is the default code) and press the home button(top left most button and not the green sim 1 button). If you press the green button it will say " Emergency calls only" it means you are clicking wrong button. hope this helps you.
Nov 03, 2010 | Swiss Tech MicroMax 19in1 Multi Tool Clam...
How do i set password to access my phone (V9)?? I want to set a password on my phone so that no one else could just open it and start fiddling with my personal stuff. I can easilydo that on a nokia but i...
usually your able to go into the menu and the either options or settings and click on security! but some phones are so dang complicated. lol here is what ive found its a razr 2 v9 right?its from the motorola website
codes & passwords
Your phone’s four-digit unlock code is originally set to
1234. The six-digit security code is originally set to
000000. If your service provider didn’t change these
codes, you should change them:
Find it: s >wSettings > Security > New Passwords
You can also change your SIM PIN or call barring
passwords.
If you forget your unlock code: At the Enter Unlock Code
prompt, try entering 1234 or the last four digits of your
phone number. If that doesn’t work, press s and
enter your six-digit security code instead.
If you forget other codes: If you forget your security
code, SIM PIN code, PIN2 code, or call barring
password, contact your service provider.
lock & unlock phone
You can lock your phone to keep others from using it.
To lock or unlock your phone, you need the four-digit
unlock code.
To manually lock your phone: Presss>
wSettings > Security > Phone Lock > Lock Now, then enter
your four-digit unlock code.
To automatically lock your phone whenever you
turn it off: Presss>wSettings > Security > Phone Lock >
Automatic Lock > On, then enter your four-digit unlock
code.
Oct 02, 2009 | Cell Phones
My security code and i want to unlock it
Enter the lock code instead of the security code. After then to change the security code.
  1. Go to menu and there open settings.
  2. There open security settings.
  3. There will options such as change lock code or change security code etc.
  4. If you have forgot security code then you can't change it, better change lock code as your desired password.
  5. To change first get into change lock code and enter old lock code and after that input new password and its all done.
Aug 14, 2009 | Lands Phones
Nokia 1100
Try this:
Go into security settings/change security code/
-default code is usually 12345
-enter new code and repeat
go into keypad auto lock
-input yes
go into phone auto lock period
-input time(e.g 10seconds)
Now when you are out on the main menu,after 10s it should automatically lock.
When your sim card is removed or when you turn your fone on it will ask for the security code.
hope this helps
Apr 30, 2009 | Nokia 1100
Nokia 5310 Phone Locked
if the security code was manually set by you,then there is no way to find that with imei or serial number...
reinstalling the phone software is the only way
thankyou
Jan 06, 2009 | Nokia 5310 Cellular Phone
ZAGG Invisibleshield Nokia N95 8GB (NOKN952) Case Flash Memory Card Case Logo
Top ZAGG Cameras Experts
Are you a ZAGG Camera Expert? Answer questions, earn points and help others
