Question about Bosch Microwave Ovens
My Bosch microwave (E no: HMT AU/01) is approximately two years old and has ceased to function! There is power - when set on, say, 1000w for 1 minute, it will activate. All will appear and sound normal and the counter will count the time down on the display. However, after approximately 20 seconds (irrespective of the cooking time set), it will switch off and revert to the clock time on the display. The contents are still cold, which seems to imply that there has been no microwave activity. Help!
  • dparkin Jul 09, 2008
    That you for your quick response. Your comments have confirmed my suspicions - I'll leave it to the technician!
  • 13,433 Answers
This is a internal protection mechanism which turns the device off incase a problem is detected. you will have to take it to a tech for a inspection as we can't really do that over the internet.
Posted on Jul 09, 2008
    Brigadier General:
  • 6,966 Answers
It would appear that for problems similar to yours, the solution was to replace the magnetron. Additionally you may want to check the actual part number and compare prices with Bosch original and those made for and by other manufacturers. You may find it to your advantage to scout around since those meant for other comparable brands are relatively cheaper.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Amana microwave reset button?
Does the power panel have anything on it?? If not. it probably has a burnt fuse inside the unit, one year old should have a warranty on it Check out places that work on microwaves.
Mar 05, 2015 | Amana Commercial Microwave RMS10TS Touch...
Bosch innowave hmt 8625GB My Bosch start button no longer works . When you push it in, it just moves to the left or right ... Can anyone please advise .. Thx Adam It is about 10 years old , not sure...
There are no spares listed for the power button. You may want to see if it came loose as opposed to broke. That means take it apart. However, that unit is not made anymore.
Dec 02, 2013 | Microwave Ovens
Bosch hmt 845k microwave oven
If for some reason you don't still have the installation instructions, their support site should allow you to either download or order a set.
If you can't find their site, try the dealer from whom you purchased the oven.
Jun 09, 2013 | Microwave Ovens
MY 5 YEAR OLD BOSCH INNOWAVE BUILT IN MICROWAVE HMT 8656 HAS JUST DIED. WHAT IS THE LATEST MICROWAVE TO REPLACE IT
Here`s a little fact about microwave`s, they are not healthy - http://rense.com/general70/microwaved.htm
We threw ours out, food taste much better cooked on the stove, oven or grill.
Apr 15, 2011 | Bosch HMT8625GB Microwave Oven
Hmv9305/01 microwave @ 13months old the magnetron blew, authorized bosch repairman, replaced using bosch magnetron. warranty for 90 days jan of 2011 same problem, why does this happen? should i ditch...
With all due respect, what are you doing to it?
If you use it with nothing in the cavity, that will kill the magnetron otherwise it will last for years and years.
Very unusual and Bosch is a well respected name.
If there is a probem with the oven, Bosch will replace it so take it up with Bosch.
Apr 01, 2011 | Bosch HMV9305 Microwave Oven
Microwave works except not heating food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
djh
May 08, 2010 | Bosch HMV9305 Microwave Oven
Panasonic NN- A712 combination Microwave 1000w - Switches off after 20 seconds
The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 14, 2008 | Panasonic NN-S753 Microwave Oven
Bosch hmt9626 gb 1000w microwave cuts out after 20secs
ur mag netron is faulty the reason for cutting out is thermal cutout switch change magnetron
Jan 20, 2007 | Bosch HMT9626GB Microwave Oven
Microwave Ovens Logo
468 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
