Question about Nikon Laser 600 Rangefinder
My rangefinder worked perfectly for two years. Not, when I try to get the range of something, my rangefinder only shows a line of 3 dashes instead of the range. I have cleaned the lenses and put in a new battery, but the problem persists. Any ideas?
  • 10,515 Answers
This is a common problem on these rangefinders. If your range finder has a mode button and a power/range button try holding both of these buttons down at the same time for about 20-30 seconds. this acts a "reset" option on some of the Nikon rangefinders.Unless you need to send it to repair to Nikon. The charge would be around $175. So, the ball is in your court whether to get it repaired or buy a replacement.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 02, 2011
Blurred numbers on Bushnell range finder.What's the problem?
Bushnell V3 display question - Toronto Golf Nuts - Greater Toronto ...
www.torontogolfnuts.com > Golf Discussion Forum > Golf Gear & Equipment
Apr 8, 2014 - 22 posts - ‎3 authors
Bushnell V3 display question Golf Gear & Equipment. ... When I start it, the numbers are clear but it does not stay like that the whole time. ... Yea I used that and turned all the way counterclockwise (all the way clockwise was very blurry). .... to read and drive and has a real problem using my rangefinder.
Bushnell blurry display Rangefinders Questions & Answers (with ...
www.fixya.com > Forum > Tags > blurry display > Rangefinders display the display appears but does not display yardage Here is the link to the instruction manual if you need it; ... Sight target needs adjustment When i look ...
DIY Fix For A Malfunctioning Rangefinder On The Cheap
fardevice.com/diy-fix-for-a-malfunctioning-rangefinder/ 4 Common Malfunctioning Rangefinder Encountered (and How to Fix Them), or blank ... Bushnell Tour V3 Jolt Standard Edition Golf Laser Rangefinder .... This could be rooted to a blurry focus lens or laser output, so it's really important to ...
Bushnell - I am having difficulty seeing through my scope, all images ...
bushnell.com/global/customer.../i-am-having-difficulty-seeing-through-my-scope,-al I am having difficulty seeing through my scope, all images seem blurry. How can I properly focus ... What battery does my rangefinder take? All my pictures are ...
Bushnell Golf - Bushnell Golf
bushnellgolf.com/ The undisputed #1 Laser Rangefinder in golf ... Bushnell Tour Domination. The #1 Rangefinder in Professional Golf For Over A Decade. Learn More. The #1 ...
Bushnell Tour Z6 Laser Rangefinder - Review - MyGolfSpy.com
https://www.mygolfspy.com/bushnell-tour-z6-laser-rangefinder-review/ 6 posts - ‎4 authors
The Final Contender In The Rangefinder Round Up: The Bushnell Tour Z6 ... Our second entrant is the Callaway RAZR Rangefinder dropped a .... I have near perfect eyesight, but when target is clear, number is blurred and vice ...
Blurry vision Range finders - GPS/Range Finders/Mobile Apps - GolfWRX
www.golfwrx.com > ... > Equipment > GPS/Range Finders/Mobile Apps May 14, 2015 - 5 posts - ‎5 authors
What causes a range finder to have blurry vision through lens? Im looking to purchase a used Bushnell tour v2 in a couple minutes and I've ... Which Laser Rangefinder
2 Aug 2014
Pro 1M Slope = Bad, Bushnell = Good
1 Aug 2013
Problems with Bushnell Pinseeker 1500?
24 Jan 2009
More results from www.golfwrx.com
Jan 07, 2017 | Bushnell Optics
Range finder fell in a cooler
My tablet got wet. I put it away in my room and forgot it for 3-4 weeks. When I found it and tried it - voila! It worked perfectly.
May be thats a solution.
May 09, 2014 | Bushnell Tour V2 Pinseeker Laser...
Rangefinder does'nt register new battery
Then they sold you a battery, that was on the shelf for years, or the contacts in your rangefinder are not clean and shiny. If so, you could try to clean the contacts with a dry cloth. Never use anything sharp on contacts, because that will damage the apparatus and will make the rangefinder unusabl
Nov 18, 2013 | WGI INNOVATIONS Halo R400 Rangefinder...
Leuplod rx111 rangefinder
This problem is caused by the 'step' inside the battery cover which prohibits the tip of the battery from contacting the nipple inside the cover. I fitted a thin piece of aluminium strip (20thou) and the rangefinder now works perfectly. Most brands of CR2 battery now have higher sides which shield the tip - bad design.
Sep 03, 2012 | Leupold RX-III Rangefinder
I have a leupold digital rangefinder RX IV Boone and Crocket edition, and suddenly stoped working, I changed the battery and nothing happened
This problem is caused by the 'step' inside the battery cover which prohibits the tip of the battery contacting the nipple inside the cover. I fitted a thin piece of aluminium strip (20thou) and the rangefinder works perfectly now. Note that most new CR2 batteries have higher sides which shields the tip too effectively - check it out.
Mar 10, 2011 | Leupold RX-IV Rangefinder
How do I use the range finding graph reticle from barska?
The IR Rangefinding Reticle is based on the military reticle that ranges tanks, believe it or not, front to back--whatever line the tank fits between will give the range to it...but the reticle has been adapted for use in some riflescopes. Trying to define the math behind rangefinding and downrange zeroing with multi-stadia reticles is complicated and takes some study to fully grasp the concepts, which is why I have a constantly available on-line article, entitled, "Tactical Ballistic and Ranging Reticle Analysis," right here--
http://specialtypistols.infopop.cc/Reticle_Ranging___App.pdf
Jan 27, 2010 | Barska Optics Barska® 8 - 32x50 mm IR...
Won't range even after reset
Well after going through the reset procedure (holding both buttons down for 30 seconds) the unit didn't appear to be working. Being somewhat new to the proper use of this device it appears that it might be sensitive to low light conditions or certain objects. After playing with it more I'm now able to get it to work but there are still certain conditions where it won't give me a reading.
Feb 12, 2009 | Nikon ProStaff Laser 440 Rangefinder
Range finder does not register distance 99.9% of the time
I had the same problem, rangefinder would work only sometimes and only at short distances. Called customer support and was ready to send it in. Tech guy told me to turn off "First Target" ( or "last target") and turn on"LOS" (line of sight). Range finder now works perfectly at all distances. Apparently the first target feature doesnt work properly.
Dec 26, 2006 | Leupold RX-II Rangefinder
Nikon Laser 600 Rangefinder Logo
483 people viewed this question
Top Nikon Optics Experts
Mark Campeau
Level 1 Expert
Are you a Nikon Optic Expert? Answer questions, earn points and help others
