Question about Frigidaire Dryers
I have a newer frigidaire dryer and the drum came off it was makeing a metal to metal noise. I runs fine now but doesnt heat. Do you know what it could be?
  • Frigidaire Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape and running the dryer to check to see if the element is red or not,
or with an ohm meter check the two terminals of the thermostat/thermister
after you have removed the wires, the thermostat/thermistor should have/show continuity across the terminals.
If the coil heats up, or the thermostat/thermistor shows an open circut
then replace the thermostat/thermistor as it is defective.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the an element go to the following website, it will give you an idea what you are in for:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Jan 02, 2011
My frigidaire fer231cas2 makes a horrible loud noise after its been running for 10 or so mins
There are rollers that the drum sits on. The roller surface or bearing can go bad causing the noise.
Aug 26, 2014 | Frigidaire Dryers
What might be wrong with my gallery dryer #gleq2152eso it does not heat?
Hi friend, I appreciate your post!
Based off the information you have provided your Frigidaire dryer, GLEQ2152ES0, is no longer heating. I understand that you heard a noise like pennies hitting the drum and then it stopped heating. Some possible reasons to why your dryer is not heating could be that your vent is restricted, an issue with your thermostat, or heating element. I would recommend having a technician come out to diagnose and repair your appliance because with the noise you heard he may need to disassemble the dryer. I hope this is helpful. -Matt
Aug 12, 2014 | Frigidaire Dryers
Grinding Noise
Check for warn drum rollers
Jun 05, 2017 | Frigidaire Dryers
Why is my dryer is making a high pitch screaching noise?
frigidaire dryers have a rear bearing that the drum rides on,usually when you hear metal on metal sounds it will be the rear bearing
Feb 22, 2012 | Frigidaire FER641FS Electric Dryer
DRYER MODEL DE7400P FRIGIDAIRE IS MAKE NOISE LIKE RUBBING METAL HOW DO I FIX?
Hi martyski39...
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your dryer drum is mounted in the rear with a bearing, most likely the bearing is faulty and making the grinding noise, or maybe two conditions exist.
1...Bad drum bearing noisy
2...Bad drum bearing noisy, and with play in the bearing allowing the drum to rub the felt seal away at the door making metal to metal contact.Check your door for obvious rub signs...
I will include a parts house webpage link where you can look at you "exploded" view of your dryer and order parts also.
Please take time to rate me
http://www.partselect.com/MultiModels.aspx?ModelNum=de7400p&searchTerm=&RefineSearch=0
Aug 30, 2011 | Frigidaire Dryers
Noise in dryer Frigidaire model fde336res1 when running
Could be the drum bearings are worn. These are what the dryer drum turns on and when they wear out the drum and frame rub together (metal to metal). Also could be the belt idler which keps the belt tight around the drum. In either case the dryer would have to be internally accessed to determine failure.
Feb 17, 2010 | Dryers
Frigidaire Dryer making loud thumping noise in back.
Some things to check.
Worn rear drum rollers, idler pulley, or drum front slide kit.
Click here for illustrations.
Hope this helps.
Aug 12, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Drum making sqeaky noise
The squeak is the rear bearing mount rubbing on the hanger ball. The plastic bearing is gone and that metal piece is cutting a groove into the ball mount. I have a picture. If the ball will be cut off and the drum will fall into the heating element and the belt will break. Not good!
8a3a785.jpgTo get to this bearing you must pop the top and get the belt loose,lift out the drum and inspect the bearing. The kit is fairly reasonable.This is something that a DIYer can easily handle.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 11, 2009 | Frigidaire Electric Dryer
The dryer is making a terrible squeaking sound.
That my friend is the sound of metal to metal on the rear drum bearing. The drum has a ball mounted on the rear of it affectionately known in the biz as a trailer ball. It rides in a grease slathered plastic bearing. The bearing is mounted with a metal bracket. Over time the plastic will wear down and the ball will begin to meet the metal mount.
The mount will begin to act like a guillotine and actually eventually cut the ball off 85a72c7.jpgand the drum will fall into the heating element and the resulting massive breakdown only occurs on a sunday night. LOL
Jan 20, 2009 | Frigidaire Dryers
Dryers Logo
43 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
