Question about LG LFX25960ST Stainless Steel French Door Refrigerator
French door fridge light works intermittently only. comes on sometimes a few seconds after door is opened. seems to be getting worse. freezer light is ok.
  • carrigan_sha Apr 07, 2011
    Rick,
    I am still having this problem. Wires don't seem to be loose. Shaking the fridge or flipping the door plunger switches seems to have no effect. It comes on and off when it wants to. I am thinking it's related to a relay or timer circuit. Is there a board or something that can be replaced?
  • 1,998 Answers
If the light is working intermittently then there has to be a wire that is loosely connected into the light itself check this diagram on piece 410a to assure that it is makeing a good connection http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fK0810256-00001.png
also you can do a power test on the wire with tripping the switch by pushing it in and leaving it out to assure that you are getting power to the light when the switch is not depressed if you have any further questions please message me back and please remember to rank how this opinion has helped when our chat has concluded Thanks again Rick
Posted on Jan 02, 2011
  • Rick Ead
    Rick Ead Apr 08, 2011
    on the lgs i have actually seen that wire that goes to the light be 1/16"away from where it is supposed to seat in the connector and cause the same exact situation use a multimeter to measure what you have coming out of the connector if it is fluctuatiing then also did you do a continuity test by removing the switch and doing this test directly on the switch? the pcb that controls that switch should be at 501 but i dont think it would be the pcb because of the flickering sounds more like a loose wire or bad conection Thanks Rick
    if it were the pcb it just wouldnt work at all
Loud buzzing noise
Yes that is your relay they are pretty common use your model number to track one down may tag is owned by whirlpool so most local places will have them
Mar 01, 2014 | Maytag MFD2560HES Bottom Freezer French...
Water under fridge sometimes
You may want to remove all the food, unplug your fridge, and the out the whole thing...melting the ice and cleaning out all the unwanted water. The drawer will be removable, and you can dry under it. Also check the overflow tray under the fridge, if there is one...it'll be full from all the melting.
Jan 24, 2014 | Whirlpool GX5FHTXVA Bottom Freezer French...
Lights go off and on
your sensor sw is deff call for a tech to replaced
Jan 12, 2014 | LG LFD22860 Bottom Freezer French Door...
KBFA20ER Turns Off
Holding fridge door open allow warm air into fridge/freezer that's why temp is going up .Maybe you device have a temp cutout which in your case 46 degrees.
It is like a energy saving
Jun 01, 2017 | KitchenAid KBFA20ER Bottom Freezer French...
Food keeps freezing in my fridge. Even at the lowest temp.
in the fridge compartment check behind the control panel where the light bulbs are remove this cover and make sure the damper vent door opens and closes when adjusted with the fridge control sometimes they ice up from condensation and freeze in one position and this may let too much cold air in from the freezer for too long,otherwise it also could be a defective electronic control board in this same area
May 13, 2010 | Jenn-Air JFC2070KRS Stainless Steel Bottom...
Inside Dsiplay Not Always on
Hi -
I haven't solved my problem, yet, but i have determined that it's beyond my scope and will require a pro's visit to my house.
thanks for the line.
b
Aug 17, 2008 | GE Profile PFS22 33" Artica French Door...
Amana AFD2535DEW freezer/refrigerator with intermittent tempurature swings
I had the same issue. It was the relay overload which essentially provides the extra boost to get the compressor going. The switch tries for about 10 seconds before giving up and then retries 3 - 4 minutes later. In the early stages of failure, eventually it will work and the compressor will kick on. But eventually the switch will fail and will just cycle through the 10 second attempt every 3 to 4 minutes. The part is about $35 - part number 67005560.
Jun 26, 2008 | Amana AFD2535DES French Door Refrigerator
Refridgerator (Bottom Frzr-French Door) not getting cold....Freezer is o.k.
could be a few issues, id open teh freezerdoor at looka t back panel id tere frost building up??? if so youhave a defrost issue, can you here the fan in freezer conmpartment spinning you may have a bad evap fan
Mar 16, 2008 | KitchenAid KBFA20ER Bottom Freezer French...
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
70 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
