Question about Maytag Atlantis MDE7400AY Electric Dryer
My maytag atlantis dryer is making a loud squeaking noise. sounds like metal on metal. possibly a bad bearing? any ideas...
  • Maytag Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch.
Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt.
Remove the drum and belt and this will expose the drum rollers, idler arm
pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the
idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go
to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Posted on Jan 02, 2011
    Problem Solver:
  • 14 Answers
I recently replaced the rear drum bearing on this dryer, and once you find the part, the change is a snap. The dryer actually uses Whirlpool parts, and the rear bearing is just a plastic bushing that the shaft of the drum rides in. It is accessible behind a small cover on the rear of the machine. Pop the top off the machine (so you will be able to support the drum, to remove the old bushing), remove the five Robertson screws holding the rear cover and bushing in place,remove c-clip at end of shaft, remove old bushing. After applying some high quality lube (I used a molybdenum based product), reverse assemble, and enjoy the now quiet machine.
The part # is 35001012, made by Whirlpool (Maytag/Samsung), FSP on the bag.
Posted on Feb 26, 2011
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Maytag Atlantis Dryer model MDE7600AYW. when on has severe sqeeking sounds metal to metal what part would you suggest I replace and can I do it myself. Or is a repairman needed.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 01, 2011 | Maytag Dryers
Washer makes loud grinding noise during agitation and does not agitate - it is a maytag atlantis.... fix or replace?
I suspect the thrust bearing kit is bad. This comes with great instructions and is easily replaced. I would recommend changing this before replacing the machine. You are not out much if it does not work, but I am confident you will get it going by replacing this! This is a VERY common problem with these washers and the new kit has been redesigned.
Kelly
Mar 21, 2011 | Maytag Atlantis MAV9750A Top Load Washer
Maytag altanis dryer is making a loud sound when started like there are shoes in the dryer but its just clothes.
heatman101
Nov 22, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE 7400AYW is squeaking bad. Not sure, could it be a rear drum bearing grinding on the roller
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 28, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Loud Rubbing noise from my Maytag Performa Dryer
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Jul 20, 2010 | Maytag Dryers
Makes a loud squeaking noise when drum is turning
The felt on the front of the drum is probably worn out or the bearing on the rear of the drum is getting bad.
May 05, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
I have a Maytag Atlantis gas dryer. It makes a squealing sound when it's on. The longer the dryer is on, the more intermittent the sound is. What could the problem be, belt or bearings?
All dryers have to have a way of allowing the tumbler (that's the thing you put the clothes in) to turn freely, not all of them are the same tho,some use bearings, some use slides,others use rollers. Over time these rollers will need to be oiled,the slides will get thin and start metal to metal contact causing a noise, The rear bearings will then start to make their way to china and cause the tumbler to rub into the heating element and OUCH! These things will cause the motor to prematurely DIE! Its best to examine the dryers, rollers, and slides when you first hear the noise, but who does?
Sep 13, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer noise
A drum support wheel bearing could need lubrication or be replaced.  Also some drum support wheels have a rubber coating that wears off causing misalignment and noise.  Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced.
Jun 02, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
1,601 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
