Question about Yamaha Full-Size Keyboard
I recently purchased a yamaha PSR-E223 YPT-220 keyboard from Argos.when we got it home and opened it there was no adaptor.We are unable to find the one we need.The manual states we need a PA-3C adaptor.Where can i purchase one from?
    Guru:
  • 1,705 Answers
Does the user guide tell you should have got this adaptor along with the keyboard? Often there's a "what's in the box" page. They normally do include one.
I would suggest firstly going to Argos and getting a replacement or ask them to supply one. You'll need your receipt.
If not then any universal AC mains adaptor which can supply 12v DC and the correct plug (2.5mm) will do the job.
You should be able to get them from Maplins, Ebay or here's a web site:-
http://www.uk.best-price.com/search/landing/query/Pa+3c+Adapter/s/google/koid/3442910623/
Posted on Jan 02, 2011
Testimonial: "i went back to argos with a reciept and although the box states adaptor supplied none of the boxes instore had adaptors in them.i will try e-bay.thank"
  • dgsturt Jan 02, 2011
    I did mention :-
    http://www.uk.best-price.com/search/land... 3c Adapter/s/google/koid/3442910623/
    Finally, you could try the Yamaha website, here's a url to the dealership network, just enter the required details.:-
    http://yamaha-corporation.force.com/deal...
    P.S. I'd also try and get the cost out of Argos when you finally get one ......... good luck.
Can't figure out how to set this up as a midi controlling unit, for Yamahas YPT 300 and PSR 620. Can you give me any guidance ?
UX16 MIDI/USB Converter (not included) necessary to connect keyboard to computer.
May also need to download the midi driver from yamaha.
Apr 15, 2015 | Music
Power falier
Power failure?
First check the power supply / adaptor to ensure this is working correctly. Measure the voltage using a multimeter - if this is correct move on ( if not replace power supply )
Does the keyboard work if you hold the plug in the socket or move it slightly ? If so this is a common problem as the power socket on the pcb fails at the solder joint and will need to be repaired / replaced.
If this appears to be solid then you may have done some internal damage by either plugging in a power adaptor with a too high voltage or wrong polarity. If this is the case you may have blown some circuitry inside which controls voltage regulation.
Please report more if you have more information.
Jan 22, 2014 | Yamaha PSR-E223 keyboard
Http://music.yamaha.com/registration
soy usuario de un teclado yamaha y queria saber si me pueden enviar las partituras de iniciacion al teclado. gracias mi nombre es Pedro Guardia Berrueco. Mi direccion de E.MAIL: pguardia2@gmail.com. el modelo es psr-E223-YPT-220
Jun 05, 2012 | Music
Repairing Yamaha psr-12
If the power adapter is not the original adappter- check to make sure the polarity is correct- it should be marked on the keyboard near the adapter socket, and also on the adapter itself.
The keyboard should have an internal fuse- check that. Then with keyboard open, if the fuse is okay, trace the power flow from the power pack and look for broken wires, bad solder connections, stressed components like bulging capacitors, etc. It may have a burned out zener diode in the power supply regulator portion of the main circuit.
Mar 29, 2012 | Yamaha PSR-E223 keyboard
Hi My yamaha PSR S500 keyboard is not turning on! I bought a new adaptor but it still wont come on
Check that your adapter is a 12VDC with a current rating of at least 1 amp (1000ma) AND that the center pin of the connector is the POSITIVE.
Feb 07, 2011 | Yamaha PSR-S500 Digital Keyboard
I need to know the polarity diagram for the ypt-220 so I can use a replacement power tip
The YPT220 is similar to many of the PSR keyboards and will use the same adapter. MOST, like your YPT220, use an adapter with the center pin positive AND are protected by a series diode in the keyboard such that damage will NOT occur if wrong polarity is used. You should use an adapter that provides 10 to 12 volts with positive on the pin and negative on the shell capable of 1 amp (1000ma).
Dec 18, 2010 | Yamaha YPT220 PAK 61 Key Keyboard wAC...
No volume at all out of speakers PSR-E203. Plugged in to AC supply. Yamaha Portatone PSR-E203 YPT-200
Make sure you use correct power supply.
Try headphones. If they work, then the switch on the headphone jack that disconnects the speakers may not be working properly and not connecting the speakers.
Oct 13, 2009 | Yamaha Music
Yamaha Full-Size Keyboard Logo
819 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
