Question about Microwave Ovens
I am looking for replacement bulb that is found under the microwave 125 volt 25 watt appliance bulb and can't find them anywhere
    Brigadier General:
  • 8,909 Answers
Most appliance repair workshops will have this type of bulb. Check the base, is it ES, Small ES, Little ES or a manufacturers special.
Contacting the manufacturer will guarantee a spare part.
Hope this helps.
Posted on Jan 02, 2011
What kind of light bulb for an Emerson Microwave, MMWG9115SB?
Normally, small Edison Screw (ES) cap, and 25 watts appliance bulb. Take the old one out and look.
Feb 15, 2017 | Emerson Microwave Ovens
How do you change the internal light bulb please?
there is a cover on the rear with one or two screws. Remove the screws and unscrew the bulb. It is usually a small Edison screw SES 'Appliance Bulb', and 25 watts.
Sep 10, 2015 | Microwave Ovens
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
Emerson red 900 watt microwave glass turntable
Replacement trays cost around $30.00. The cheapest I found was on Ebay for $28.00. By the time you pay for shipping you can almost buy a new appliance. Also take care that you find one for your model, you can't always tell by looking if it is going to fit.
Try your local Goodwill or other thrift store for a used one.
Good luck
Feb 17, 2013 | Emerson MW8102SS 1100 Watts Microwave Oven
I have replaced the bulbs underneath the microwave, but the lights are still not working.
HELLO.
This is the solution to the problem as detailed below.
instruments needed
* Appliance bulb
* Screwdriver.
Unplug the microwave. Remove the lamp cover by unscrewing the mounting screws. Turn the bulb to tightly screw it in. Then plug the microwave back in to test the light. If the bulb still will not illuminate, it is likely broken or defective. Replace it with another 20 to 40 watt appliance bulb.
Sep 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
What type of replacement quartz bulbs for the under counter lights?
could be 10watt or 20 watt i for under counter lighting. If too high could burn out low voltage transformer assuming its low voltage....12 volt...
Apr 08, 2010 | GE JVM2070 Microwave Oven
Kenmore over range microwave oven / no power at all
Unfortunately, there is a good chance that when the bulb shorted out, it damaged the control board. The only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. The relays for the fan and the lights are part of the board. The power should always be disconnected when these bulbs are replaced or the board will be damaged. We would have an appliance repair person take a look to see what the deal is with the microwave.
Go here for Kenmore Microwave Parts: http://www.repairclinic.com/Kenmore-Microwave-Parts
www.RepairClinic.com
Feb 05, 2009 | Kenmore 62622 Microwave Oven
I have a GE Profile ModelJVM187OSK04 Serial # DM902972B The bulbs went out, they are 120 volt 20 watt. Can I use a GE 120 25 watt bulb as I am having trouble finding a 20 watt??
You should be able to use the 25 watt bulb as long as they are compatible with the socket they mount in... Hope that helps...
Aug 16, 2008 | GE Microwave Ovens
Microwave Ovens Logo
41 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
