Toshiba e-Studio 16 I can ping printer but it wont print
  • 126 Answers
The right printer driver is not loaded. toshiba drivers are very complicated so check the drivers again.
Posted on Jan 05, 2011
E studio 352 unable to print, works well as copier, admin panel and log is accessible on network but does not print, no error
check same IP is given elsewhere remove RJ44 while ping is on if still replay is on,then change the IP no.
Feb 06, 2014 | Toshiba e-STUDIO 352 Black and White...
Increase the toner density toshiba copier e-studio 16
clean scanner drum unit change with good toner.
Sep 10, 2013 | Toshiba e-STUDIO 16 Printer
Toshiba e-Studio 350 - How to Print?
Did u install printer kit? It looks like a mini thumb drive, hooked to usb port?
Mar 07, 2010 | Toshiba e-Studio 350 Copier
I have a toshiba e-studio 352 as a network printer on a win 7 system, I am able to scan from the printer to the pc, but when I try to print on the printer nothing happens. I did ping the printer and the...
try following
- download the newest printer driver from http://www.copiers.toshiba.com/support/index.jsp
- uninstall current driver
- delete port if it is still present
- restart the machine
- start setup (choose XPS printer driver and PCL printer driver)
- setup should offer the machine with IP automatically, if not enter IP manually
- print test page
- it should be working if not let me know, write in comment what happened
regards
Feb 24, 2010 | Toshiba e-STUDIO166 Printer
I can not use it in network.i saw it pink it but i
Do you have the Print/scan enabler option?...a small device that looks like a usb key plugged into the rear right hand side of the copier.
Otherwise, it looks like it's going to print but it just disappears into cyberspace.
Jul 07, 2009 | Toshiba e-Studio 350 Copier
NETWORK
Does your copier have a Network Interface Card ( NIC ) installed in the printer? If not, and if the copier has the Parallel port option installed, you can purchase an HP JetDirect EX network print server, and then connect it to the printer parallel port, and then into your ethernet network. This option is very effective, and a very "Green" solution vs using a computer as a print server for example, or the high cost of adding a Toshiba ethernet option if not already installed.
Nov 07, 2008 | Toshiba e-STUDIO 16 Printer
Network printing issues - Toshiba e-studio 16s
try this:
start, printers and faxes
right click on the print driver , go down to properties click
click on ports
click configure port
click lpr in protocol
Lpr queue name PRINT
LPR byte counting enable
SNMP enabled
Try this and make sure your ip address is correct
Jan 21, 2008 | Toshiba e-STUDIO 16 Printer
jasbo
jasbo
