Question about Kenmore HE2 Plus Front Load Washer
What is F-21? - Kenmore HE2 Plus Front Load Washer
  • 4,323 Answers
Hi
F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Error code SD means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump. Hope this helps... Please post back if you need more information.
Daniel
Posted on Jan 02, 2011
How can i apply on cput online application and what should i do to get accomodation?
http://www.cput.ac.za/study/apply
Check out Frequently asked questions or contact us:
Call centre
Tel: +27 21 959 6767
Email: info@cput.ac.za
Admissions Office
Bellville Campus:
Tel: +27 21 959 6256
Tel: +27 21 959 6270
Cape Town Campus:
Tel: +27 21 460 3393
Tel: +27 21 460 3861
Nov 20, 2017 | Higher Education (University)
Tip
Hi there.... I have tried the above, but nothing happens after I have clicked on...
Hi! I have noticed a lot of people have this problem that they actually forget there Sony Ericsson mobiles' Phone Lock Code. If you want to recover your phone lock code please go through the following procedure. This procedure will tell you your mobile's lock code without flashing and resetting of any kind!..
I have also have a Nokia version of this tutorial here: Nokia
Follow these steps;
  • Open this link, select your phone and download the software. (PLEASE CLICK HERE)
  • Follow the onscreen instructions to install the software.
  • Once installed, turn off the mobile and remove thebattery. Now reinsert the battery and insert the cable (DCU-60 thatcomes with the box) while holding the 'c' or '@' button on your mobile.
  • Your computer will detect a new device and install it.
  • Once installed please unplug your mobile, remove the battery. Now reinsert it.
  • Download xs++ from here
  • Extract this file and run XS++.exe
  • In XS++, click Connect.
  • Hold 'C' or '@' key on your phone and then insert the USB cable.
  • u can get some information about your phone when it's connected
  • click or tick GDFS at the bottom.
  • Then click Phone Lock, it will show you the code on right hand side. Note that code.
  • click Settings at the bottom, then Disconnect.
  • unplug the USB cable, remove then reinsert the battery.
  • You are done, enter 0000 or the Noted one (In the 3rd last step)
    If I was Helpful, Kindly Do Rate!
    Regards,
    Waqar.
    on May 16, 2011 | Sony Ericsson Walkman W810i Cellular Phone
    Need repair manual for Komatsu D31EX-21,D31PX-21,D37EX-21,D37PX-21,D39EX-21,D39PX-21 Dozer Bulldozer
    Downlaod Komatsu D31EX-21,D31PX-21,D37EX-21,D37PX-21,D39EX-21,D39PX-21 Dozer Bulldozer Service Repair Manual
    https://sellfy.com/p/fmBE
    Nov 23, 2015 | Cars & Trucks
    Find the y and x intercept of this equation 3x-6y=-21
    To get the y-intercept of a line you set x=0. So 3(0)-6y=-21. Solve for y: y=(-21/-6)=7/2.
    For the x-intercept, set y=0 in the definition of the function, then you solve for x.
    3x-6(0)=-21. or 3x=-21 and x= -21/3=-7
    Oct 31, 2011 | MathRescue Word Problems Of Algebra Lite
    3u/u^2-14u+49-21/u^2-14u+49
    Solution is
    3u/u^2 - 14u + 49 - 21/u^2 - 14u + 49
    =3/u - 14u + 49 - 21/u^2 - 14u + 49
    =- 21/u^2 + 3/u -14u-14u +49+49
    =- 21/u^2 + 3/u -28u + 98
    Jul 28, 2011 | Computers & Internet
    Same Problem Again - Mega Raid.... Unknown Error
    Hi
    The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
    However, the extract posted in your suggests network problems.
    Any number of physical to driver and configuration issues can result in network problems.
    Try the basic checks;
    1. Change or try a known patch cable
    2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
    3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
    4. Can you try another switch
    5. Check and load correct or latest manufacture's drivers
    Reply with more info.
    Mike
    Jan 23, 2008 | Dell PowerEdge 1800 Server
    Kenmore HE2 Plus Front Load Washer Logo
    97 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
