Question about Refrigerators
Kenmore Side by Side Refigerator. Freezer drain is blocking up and ice is building up in the bottom of the freezer section. We have thawed everything three times until we hear the water draining from the drain but problem returns immediately.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
You can install a drain heater, available at http://aplusapplianceparts.com/searchquick-submit.sc?keywords=279827 to prevent it from freezing. It simply wraps around and secures to the defrost heater assembly to prevent freezing. Use coupon code 1050 for a discount on your order!
Posted on Jan 02, 2011
We have a new whirlpool refrigerator....there is watering collecting in the bottom of the freezer side and it is running out onto the floor..do we need a repairman or is there something we can adjust to...
Sometimes the drain can clog with ice. If this is it - simple fix. Empty the freezer and find the drain. Put hot water in the drain with a turkey baster or try using a hair dryer to thaw the ice and let the water drain. A small amount of water drainage through this drain is normal. The water sits in a tray underneath and evaporates helped by heat from the compressor. If the drain plugs, the water will build up in the bottom of the freezer and become an ice block.
Feb 25, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
Daewoo side by side freezer leaking even though water turned off also icing up at bottom of freezer
Probably a blocked drain outlet or pipe. At the bottom rear of the unit, mine had a drain pipe blocked with a plug of mould (5/6 years old machine), apparently quite common. I detached the pipe and cleaned it out and replaced it.
From inside the freezer, I removed the lower back panel and thawed the ice build up on the drainage tray below the defrost heating element, leading to the pipe outside. The puddles of water that was appearing every defrost cycle have now stopped - permanently I hope. Hope this helps you
Aug 30, 2012 | Daewoo Refrigerators
The Refrigerator isn't cooling. The Freezer works fine. There is ice build-up in the drain resulting in a drip inside the refrigerator. After being thawed, it re-iced within 48 hours. The fan is...
Due to the blocked drain it sounds to me as if the vents in the ceiling of the refrig. has frozen over so no air can be circulated from the freezer into the refrig. section. This tip i wrote will show ya how to clear the drain and addation to clearing the drain the ice build up would need to be removed from the vents. Here is that tip, http://www1.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
GENE
Sep 23, 2011 | Kenmore Top Freezer Refrigerator
I have an old side by side we notice water on the floor every couple of days when we looked inside there is a ice build up and I guess when the fridge defrost ice bilds up and freezes and then water comes...
Hello, The drain behind the back panel in the freezer is frozen or blocked up. Remove the back panel remove as much ice as possible and pour boiling water in the bottom section under the evaporator. be careful not to touch the aluminum it will cut you or break. you will see the drain hole sometimes it takes a while to thaw all the ice. Hope this helps and please rate me Thank You.
Jun 07, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
The freezer is fine but the lower fridge is at 58 f
There is ice build up blocking air flow to the refridgerator compartment. Put everything in a cooler, turn fridgfe off, thaw OVERNIGHT with BOTH DOORS PROPED OPEN and then rinse freezer with a liter(big slam) of water. Let sit 5 minutes and pull bottom drain pan . Empty it. IF YOU RUSH THIS THEN The internal ventalation will still be blocked. 12 hour thaw minimum even with doors open.
Jan 27, 2011 | Kenmore 63712 Top Freezer Refrigerator
Ice build-up in bottom of freezer section.
your defrost drain on the freezer side is stopped up causing the drain to freeze over then eventually running out on the floor during the defrost cycle. Locate the drain at the back of the freezer and thaw it out using hot water. Using a screw driver or other object gently push down into the defrost hole and dislodge whatever is stuck there.
An air hose with good air pressure may also work well. When the drain line is clear you should be able to pour water through it freely.
Jun 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Side by Side Freezer - Ice Build Up in Drain
After the drain thaws , ( I use about a 4 inch aluminum fence tie or if need longer , aluminum wire with no insulation ,) insert it into the drain hole as far as it will go with no force , and wrap the top end about 1 turn around the calrod defrost heater , This transfers heat to the hole so the ice will not freeze up the hole . Before doing this step , use a hose and blow into the drain to possible clear out any debris which could have accumulated in the drain trap .
Jul 21, 2009 | Whirlpool GC5THEXNS Stainless Steel Side...
Ice build up on bottom of freezer
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Sep 25, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Freezer works frige dont
check for frost in freezer section. If frosted up your air flow is being blocked. Must thaw and determine why it is not defrosting
Jan 05, 2008 | Kenmore 56539 / 56532 / 5653 / 656534 Side...
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
