Question about ViewSonic VA1912wb Monitor
Monitor is on but no Picture. ComPutter is running. I get a wick picture on start up then it goes black
  • 3,400 Answers
Replace the monitor. Common problem with that and sister versions Westinghouse and others. It costs more to repair.
Posted on Jan 02, 2011
HD3870x2 dont run on my P5kpl-AM
Are you sure your monitor is OK ? I had similar issue, but monitor was fault. It showed picture then went black.
Try in dark, when it goes off, with the LAMP (LED or something) and point it to your monitor, if you see picture, I believe your monitor lights are out ..
I would suggest to try with another monitor to rule out monitor, after that you should check graphic card, try runing some benchmark tests, .. usually issues are connected with temperatures or bad memory.
Oct 14, 2013 | ASUS Computers & Internet
Vaio LCD problem
Periods.......Nice little items because they denote the End of a sentence.
See how this works?
"I have a vgn cs36gj, I was working with it, suddenly the LCD became pale black, I connected it to external monitor and it has a picture, sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
Now you try it.........
"I have a vgn cs36gj. I was working with it, suddenly the LCD became pale black.
I connected it to external monitor and it has a picture."
Okay, I got that part.........
"sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
WHICH LCD?
Laptop LCD?
External monitor LCD?
Man on the moon LCD?
1) If the external monitor LCD goes 'pale black', the problem is the graphics chipset.
This I do not believe
2) If the laptop LCD goes pale black, this I believe.
Post back in a Comment.
Regards,
joecoolvette
Apr 25, 2013 | Computers & Internet
My dell monitor will only turn on for a few seconds then it goes black. it doesnt turn of it just goes black and I can keep doing it and it will keep going black.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jun 29, 2010 | Dell E193FP 19" LCD Monitor
SCREEN TURNS OFF AND GOES BLACK
The picture board on your monitor is faulty or bad, since it goes black after few minutes, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board or any service center because the fault is not something you can fix yourself. in order not to complicate issues.
Take care.
Apr 21, 2010 | HP w1907 LCD Monitor
Screen appears on for three seconds then goes black
Try the monitor on another computer that you know works, If it works on another computer then that means you have no video output on the original computer and you'll need to reseat the memory on that computer.
If you get the same response on another computer, then that means the monitor is bad and you'll need to replace it.
Apr 19, 2010 | Samsung Syncmaster 2033SW Monitor
When i plug my monitor up it it comes on then when i get to desktop it goes black. How do i keep picture there?
This maybe just a startup picture, You never said what operating system your running so i will assume xp home, go to start,control panel, display, and select a picture, click apply, ok, and then return to main screen, I have sent this under solution but it may not be, as it is just a guess, so sorry if i am wrong.
Jan 03, 2010 | Acer AL1917 LCD Monitor
My monitor keeps going to a black screen a coulpe of seconds after being turned on
Video (picture) must be constantly entering a monitor for a monitor to continue to display a picture after it self tests (goes on for a second or, two) Your monitor is fine; check it using another known good computer.
May 20, 2009 | Vision Computers & Internet
The l226wtq goes black
Try shining a flashlight on the screen, or without the flashlight, try to see if you can distinguish anything on the screen at all, if you do, the backlight is dead, or the monitor has an internal most likely unfixable problem.
May 01, 2009 | Computers & Internet
I hooked up my monitor to my Sony Viao laptop.
when upower up press F8 key also check there u set laptop as primary dispaly and second as monitor.
Jan 05, 2009 | HP Pavilion F1703 17" LCD Monitor
ViewSonic VA1912wb Monitor Logo
42 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
