Question about Maytag EPIC MFW9700S Front Load Washer
I have a Maytag front loader Mod. MFW9700SQ1 - I get an error code of H and then F flashing. The machine stops washing. What could be the problem?
  • 4,323 Answers
Hi
Error HF means that a water inlet problem has occurred. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If the machine is not filling then check whether both valves at water source are turned ON and inlet hose are not plugged. If the machine is filling fine then chec the pressure switch hose and the drain hose for siphoning (also make sure water is not flowing back to the machine from drain hose). Check wire harness connections to: Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU). Hope this helps... Please post back if you need more information.
Daniel
Posted on Jan 02, 2011
What is E2 F4 error code mean on my Maytag front loader washer
Here's a good source for error codes for Maytag washers here:
Maytag Fault Codes
or here:
Washing Machine Fault Codes Tips Tricks Recipes
I hope this helps you :-)!
Apr 22, 2016 | Maytag Washing Machines
My Maytag front loader washer gives an F H reading. Purchased in 2009, cannot locate owner's manual.
In the rear of the console inside is the diagnostic test sheets. They should tell you what error code means.
Jan 20, 2013 | Maytag Neptune MAH7500WH Front Load Washer
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Our Maytag Washing Machine Model number MFW9700SQ1 stinks!
This is a common problem, you can run a few cups of vinager or bleach in a empty load set to hot wash and this will help. To keep it from coming back when your done doing wash wipe the door gasket down with a rag dampened with bleach and never shut the door all the way. Good Luck
Jul 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
Error code 7
The error code 7 is in fact a motor error.
The motor that drives the spin cycle has become faulty. The only solution now is to get an engineer in to fix it or get it sent away to get repaired.
Sep 08, 2008 | Haier XQG50-11 Front Load Washer / Dryer
F05 on Maytag MFW9700SQ1
I have had my epic front loader washer and dryers for 1 year now. I picked them after carefully researching other brands/models and reading many reviews. Epic had the most positive and satisfied reviews/ratings of all at the time.
I have a large house with 6 furnished suites and I do the laundry for all suites weekly, so there is a lot of laundry. The Epic machines have been great, even with some overloading abuse by the cleaning staff.
I did, however, just experience my first problem - the "Control locked problem"
I googled and found this excellent site - and the fix for the problem (hold "cycle end signal" button down 3 seconds). Worked like a charm...
I tend to think that all of the digital front loaders for all brands will have a problem like this once in a while, as they are fairly complex compared to the prior generation of washer/dryers.
However - your problems with your new machine sounds bad - like you may have gotten a lemon.
I bet they would send you a new replacement machine at no charge if you called Maytag... I would try that first before shopping for a different brand/model...
good luck!
Apr 14, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
1,172 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
