Question about Singer 2263 Mechanical Sewing Machine
It's making lots of noise and the stitching is very loose and cut
    Genius:
  • 1,788 Answers
How about doing a thorough cleaning, I mean also taking off the throat plate, and cleaning that out. It is amazing to see lint that looks like felt in that area, I was shocked that I had it. I thought that only happened when you sewed alot of fleece. Hummm. Now, lubricate and insert a new needle. See if putting your machine on a bath towel makes it quieter. If, you need a copy of your manual go to www.singerco.com to customer support and download a free one. They also have a free oiling guide listed to download, save both to your computer and then you don't have to worry about where did I put that darn book. You can also enlarge the diagrams, yeah!!!! Happy New Year.
Posted on Jan 03, 2011
My machine is making a strange noise when I am sewing. The bobbin stitches are way too loose. I cleaned the bobbin case and the feed dogs and the problem persists.
What's the make & model of the machine? Does the manual specify oiling instructions? My machines make funny noises when they need oil.
Jul 10, 2017 | Sewing Machines
I do a lot of hemming on my machine, the underneath stitch is real real loose, I tried adjusting stuff, still is so loose I have to cut it and begin again, thanks
Is your top thread not pulling the bobbin thread up? This would be top tension too loose. FYI--be sure to ALWAYS RAISE the presser foot when threading the upper thread so it will seat properly in the tension disks.
If the bobbin thread is loose, then the bobbin tension may need to be tightened.
Understanding Thread Tension Threads
Mar 06, 2017 | Sewing Machines
Not stitching correctly after using pattern selectors - zigzag very messy stitch
Describe in more detail a messy stitch. It may be the cam follower that creates the patterns is not aligned and is contacting two different cams at the same time. The machine then sews both patterns at the same time. The solution may require an expert.
Apr 03, 2014 | New Home Sewing Machines
A "clunking" noise when stitching
some sewing machines have more sounds than others, check to make sure the bobbin is setting securely in the bobbin case,and if that doesn't
solve the noise problem then ,it would be a good idea to have the machine serviced
Dec 31, 2012 | Sewing Machines
Loose stitches and blade is not cutting
you might need a new blade
try tightening the tension one number at a time and
use a scrap piece of fabric to sew on checking the stiches till they look
normal
Nov 08, 2012 | Sewing Machines
With each stitch the machine makes a loud clacking noise and needle broke
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time--needs to be checked at a repair
shop
Sep 10, 2012 | Brother Sewing Machines
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
I am trying to do a rolled hem using a singer ultralock 14sh654. Do I disengage the knife? The stitches are uneven and some are quite loose no matter how much I adjust the tension. I am positive I...
no, you need the blade in place and cutting to give an even cut fabric edge. Set up for a three thread using the right hand needle, take out the left hand needle. move blade over to the right so it is cutting wide. Most overlockers there is also a thread finger you need to change on the foot, or a little lever you flick to move this finger forward into the stitching area. Check this on your manual as each make is a bit different.
If you can source it, put wooly nylon thread into the upper looper (knot it onto existing thread and just chain it through, the knot should go through the looper eye fine). Now turn the tension on top looper down so it is looser and tighten up tension on bottom looper, so needle 5, top looper 2 and bottom looper about 7.
Now test serge, the fabric cut edge should be wider than the overlocking seam so the fabric rolls under inside the stitching. Adjust the two looper threads so that this is happening, you want the bottom looper thread to nest right up against the needle stitch and the top looper thread to wrap all the way around too.
Once you've got this happening, turn the stitch length down to 0.5, to close the stitching right up. On some fabrics you'll need to adjust the differential feed too if the fabric is "waving" a bit.
Uneven stitches or sometimes loose when serging could indicate that one of the tension devices is faulting, so if this machine is not new and its doing this, it could need a service. Can you get a regular smooth three or 4 thread seam out if it???
It is always good to just recheck the threading path, make sure the thread aerial is up and that a thread hasn't got caught back on the thread stand somewhere if you're getting something wonky happening, threads stream off overlocker cones through the machine so anything wrong in the thread path will throw off the stitching.
Jun 25, 2011 | Singer 14SH654
I have a janome 8050 sewing machine. It has started making loose stiches underneath and making a noise. I have changed the needle, bobbin, thread, cleaned the bobbin area. It will not make any stiches at...
The key to proper stitches is that tension on the bobbin must equal the tension on the upper thread spool as well. The bobbin has a tension screw that may have come loose or the thread is not properly in the tensioner. For example, the bobbin could be in backwards. Or the tension of the top could be too light and allowing the tension on the bottom to pull the thread down too much.
Open the bobbin tray and watch while you slowly rotate the hand control to see it make a stitch.
You will probably be able to figure out what is wrong.
Apr 08, 2011 | Janome Sewing Machines
How do i adjust the loose thread on top? Using the 3 thread stitch the top loop is loose and bulging over edge instead of smooth with rest of stitches. Setting is set to recommended setting but is still...
I always adjust my overlocker stitch in several ways. I start test serging with the blade set right out to the right so that it "fills" the stitching. I'll set all the thread dials to the middle setting, ie. 5. Then I test serge, and check the stitch formation. If the needle is looping underneath, then I'll tighten it "A LITTLE". If the looper threads are lying off the cut edge of the fabric, then I'll dial both the top and bottom looper numbers up a little to make those threads tighter.
Each fabric behaves differently depending on its "hand" so the right stitch settings do vary, ie. organza is different to heavy weight cotton or denim. So if my inital setting is then "bunching" up the fabric within the stitching, I will then lower the numbers for the top and bottom looper to release the thread some. And if the fabric is very soft and light and still bunches up, then I will move the blade over to the left some, cutting a narrower edge within the overlocking so the threads lie better.
So revist the settings, check that the cones are flowing freely, thread is into the tension devices fully, then retest the stitching. If it is the top looper only that is looping off the edge, and not the bottom as well, and they are both set to the same number, then I'd be a bit suss about the tension dial.
Feb 28, 2011 | Singer 14SH654
Singer 2263 Mechanical Sewing Machine Logo
113 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
