Question about Microwave Ovens
Dacor 304-1 electric cook top Light is on at dacor emblem Cannot change from this child proof setting. Have tried depressing 3 seconds etc
Try unplugging it, wait 60 seconds, and plug back in. Or press the HELP button if there is one, press the number "1", and press STOP. That works on my Sharp microwave.
Posted on Jan 02, 2011
My Dacor PCOR30 only works 58-59 seconds at a time. I've read this could be a control board issue (part No. 66660). Is this correct? Is there any other possible cause?
Not likely.
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Dacor-branded PCOR30-series microwaves are just cosmetically altered versions of the Sharp R1870-series ovens.
These Sharp-made models stop after 59 seconds when there's damper toruble.
See the attached sample drawing below for a typical damper assembly.
We have the applicable service manuals for the Sharp models and have uploaded it to our site here and here to help you in disassembling and troubleshooting your Dacor version.
You can find the Dacor PCOR parts list here and you can order Dacor parts by part number here.
If a switch is all you need, we offer a universal type for only $7.50 postpaid which you can order here.
Nov 06, 2011 | Dacor PCOR30 Convection/Microwave Oven
My unit stops every 58 or 59 seconds and I have to push the start button to get it to resume.
Aug 16, 2011 | Dacor PCOR30 Convection/Microwave Oven
Dacor DMT2420. Light and Display work fine, and you can type in time for cooking, but when you hit start, it does not make the buzz of it's normal sound, and the turntable doesn't spin.
On the DMT2420, that's a bad bottom door switch, or possibly that switch's mount.
The service manual is here and the parts list is here.
You can order Dacor parts by part number from the Pros here.
Jul 22, 2011 | Dacor DMT2420 1200 Watts Microwave Oven
Last night the microwave looked like it was running but turned off in the middle of cooking (you could see the graphics still working but it was not turned on). we pulled it out and plugged it back in (it...
Feb 21, 2011 | Dacor DMT2420SS Microwave Oven
On Dacor cook-top. LP gas, what is recommended pressure (inches of water) in manifold? Have one burner of 6 that blackens cookware.
For LP you should be right around 10" WC....to high of pressure will give too much gas and burn rich... and make the soot that makes the cookware black...
heatman101
Sep 14, 2010 | Dacor Microwave Ovens
It only cooks for 59 seconds and then stops and I have to keep pushing stop every 59 seconds
Sharp (and Sharp-made Dacor and Wolf) models stop after 59 seconds.
See the sample drawing for a typical damper assembly. http://www.fixya.com/uploads/Howto/B27054B.jpg
We have the applicable service manuals here and here.
You can order Dacor parts by part number from Encompass here.
Sep 13, 2010 | Dacor DMT2420SS Microwave Oven
Need help with DACOR Microwave model PCOR30S, w/the minute timer
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
Sharp models (and Sharp models made for Dacor) stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
We have a very close service manual and have uploaded it to our site here to help you.
You will need the
free Adobe Reader to view or print it.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
If your model is PCOR30, and you need a new motor, the part number is 66756 and you can order it here.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 19, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Dacor DCM24 - Security screw/tamper proof hex bit size?
It's a a T20H Torx type or GTXH20-100, available from hardware stores, or places like Lowe's or Wal-Mart.
Some folks just break or bend the post in the middle, then insert a small flat head jeweler's screwdriver in the space between the post & outer edge of the hole. A sharp tap with a hammer will loosen them a bit.
Otherwise, you can use a hacksaw or Dremel tool to cut a groove in them, then use a flat head screwdriver to remove them.
Just be sure that any special grounding screws get put back where they were to ensure proper grounding of the case, an important protection from shock hazard in rare cases of internal wiring breakage.
The Dacor DCM24 is essentially a rebranded Sharp R930A and I have the full service manual here at my site.
As to what's wrong with it, I would say your secondary interlock (bottom door switch) has failed.
The service manual will cover it, but there's additional info here: http://www.microwavedisplay.com/doorsw.txt
The best place to order Sharp parts is Tritronics.
Sep 23, 2008 | Dacor DCM24 Convection/Microwave Oven
Microwave Ovens Logo
66 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
