Question about Makita 12 Volt Cordless Drill/Driver Kit
I have a 6011d cordless Iam trying to remove the chuck appearantly someone has tried removing and the allen capscrew is damaged . Would anyone have a solution for removing the screw?
    Sergeant:
  • 191 Answers
You could try a screw extractor, the only problem is this may likely be a reverse threaded screw (probably why it was damaged in the first place) Try and jam(gently sort of) in a bigger hex wrench If it is beyond a hex wrench you could try to drill it out with a slightly bigger bit then the hex socket, but only drill down a little bit further then the socket hole originally was. Don't drill into the shaft of the screw. then try to screw a sheet metal screw into the hole. You want it to be big enough so it binds to the sides of the hole. Then as you tighten the screw you may loosen the hex screw.
Posted on Jan 02, 2011
How do you get the chuck and change ring off of a 6011D
Chuck: Change ring: you have to remove all screws from handle and chassis.
Juraj
Dec 10, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
How do I change the keyless chuck on a cordless drill/
Remove the REVERSE-THREAD screw at the bottom of the chuck. Set the clutch collar to the highest setting, and set the gear to the slowest setting if this drill has a 2 speed transmission. Remove the battery! I have performed this with the battery in back in my noob days, and getting an allen wrench in your rib because you accidently hit the trigger will only happen once. You will never forget that experience. Get the biggest allen wrench you can fit in the end of the chuck(the shortest leg) and tighten the chuck down around it, allowing the jaws to rest and tighten on the flats of the wrench. Lay the drill on its side(chuck toward you, handle to the left, and allen wrench to the left, horizontal to the deck. Then with a hammer(soft hammer if you care about the allen wrench) quickly and deliberately hit the allen wrench in an attempt to cause the allen wrench to spin counter clockwise. You have only a few to several attempts at this before you risk damaging the clutch, so make the first one count. Follow through like you are attempting to hit something 6" below the allen wrench. If this does not do the trick before you shell the clutch/gearbox, you are looking at an expensive undertaking, most likely a new drill. I have only shelled 2 clutches out of literally tens of thousands of chuck repairs, so don't worry, just be aware. Let me know how it goes!
Nov 23, 2010 | Black & Decker 18V Cordless Drill/Driver
How to remove the chuck from a dewalt cordless hammer drill?
Remove the REVERSE-THREAD screw at the bottom of the chuck. Set the clutch collar to the highest setting, and set the gear to the slowest setting on the transmission. Remove the power source! Get the biggest allen wrench you can fit in the end of the chuck(the shortest leg) and tighten the chuck down around it, allowing the jaws to rest and tighten on the flats of the wrench. Lay the drill on its side(chuck toward you, handle to the left, and allen wrench to the left, horizontal to the deck. Then with a hammer(soft hammer if you care about the allen wrench) quickly and deliberately hit the allen wrench in an attempt to cause the allen wrench to spin counter clockwise. Let me know if this works for you!
Sep 19, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
I need to change the chuck assembly. i have removed the screw from the center,but i am not able to remove the chuck. any suggestions on removing it without damaging the drill will be greatly appreciated.
Get a large 90-degree allen wrench. It's best to use the largest allen key the drill can accommodate, at least 3/8" to 1/2". Put the short end of the allen key in the chuck and, with the long end of the allen key pointing straight up, completely tighten the chuck.
Firmly holding the drill on the edge of a table, you're going to have to hit that allen wrench with a hammer, hard. Use the flat side of a hammer to hit the allen wrench so that the blow will spin the chuck counter-clockwise. Sometimes it can take a real hard swing, so swinging through smoothly helps.
Sep 02, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Would like to replace the chuck on my 14.4 cordless dewalt drill with a 1/2" how do I remove the old one?
Remove the REVERSE-THREAD screw at the bottom of the chuck. Set the clutch collar to the highest setting, and set the gear to the slowest setting on the transmission. Remove the power source! Get the biggest allen wrench you can fit in the end of the chuck(the shortest leg) and tighten the chuck down around it, allowing the jaws to rest and tighten on the flats of the wrench. Lay the drill on its side(chuck toward you, handle to the left, and allen wrench to the left, horizontal to the deck). Then with a hammer(soft hammer if you care about the allen wrench) quickly and deliberately hit the allen wrench in an attempt to cause the allen wrench to spin counter clockwise. Let me know if this works for you!
Jul 17, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
How to remove the chuck?
open the chuck fully and it shoudl have a screw inside. Unscrew it, but be carefull, these screws are usually reversed - to uncsrew, rotate it clockwise. Once done, put allen key into chuck (short side in), fasten the chuck to hold allen key well and hit the key with hammer - counterclockwise direction. You might want to verify this procedure with someone else as I have no experience with Dewalt, but this way it works for Makita, Metabo, Narex, ... then why not for Dewalt? Juraj
Jun 06, 2010 | Dewalt DC727KA 3/8" 12v Cordless...
Need to change a keyless chuck
open jaws for large size bit.look in bottom and there will be a screw slot or phillips head screw or possibly an allen head screw.remove this,by possibly turning clockwise. and then chuck up a large allen wrench. try removing the chuck by tapping wrench with hammer. this may be threaded on counterclockwise.have to try both ways.
Aug 28, 2009 | Craftsman 19.2v 3/8"drill/driver W/ Work...
Hitachi cordless drill, removing chuck
Replacing the chuck on a drill is simple when you know the trick. I worked at a tool rental center while attending college and learned how to repair many tools. Open the chuck enough to remove the screw that you will see inside the chuck. It will most likely be reverse thread. The chuck is threaded on the shaft so just simply close the chuck on an allen socket and impact off with air or electric impact tool. If you do not have an impact tool close the chuck on-to the largest allen wrench that will fit into the chuck.(with the long part of the allen wrench projecting out) You will need to set the drill into a vise or strap to work-bench, then strike allen with hammer. Most chucks are removed with one quick impact of the hammer, counter clockwise. Do not squeese the drill too tightly with vise, we used a piece of leather to protect the drill. Good luck. Enjoy
Dec 16, 2008 | Hitachi NV45AB2S Coil Roofing Nailer
Removing the chuck on a dewalt DC925 cordless drill.
I just changed the chuck on my 18 volt xrp half inch hammer drill,yes first you must remove the torx screw with #15 torx bit,note this is a left handed thread screw,knowing the bad chuck was bad I added some heat from a propane torch to the chuck then making sure it was in 1st gear i took some vise grips and the chuck is screwed on with normal right handed threads,it broke loose (was stubborn but needs a lot of torque )ahhhhhh wat a pain.
Oct 18, 2008 | Dewalt 18 Volt Compact Drill Kit
Makita 12 Volt Cordless Drill/Driver Kit Logo
126 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
