Question about KitchenAid KCM511 Coffee Maker
I have a KCM5340B coffee maker and every time I try to brew it says error2 What should I do?Andy
Coldcut
  • 1554 Answers
SOURCE: turn off beeping alarm when the coffee maker is done brewing
you can't ,its up in the top behind the controls.
you have to take the pot totally apart.
only a trained tech should attempt this.
Posted on Apr 02, 2008
  • 3 Answers
SOURCE: Coffee won't brew
It is probily the thermal switch between hot wire and element. Check to see if you are getting power through this switch.
Posted on May 19, 2008
  • 4 Answers
SOURCE: One year old coffee maker won't brew
I had the same problem, only this happened on the last 3 dcc-2000 I purchased. I called customer service today, and they informed me that there is a 3 year warranty on this product. Wow... This time they really helped. I have made 2 phone calls to customer service, and was put on hold for over 20min. each time they found out what machine I was calling about. Call customer service, and don't give up!
the number is 1-800-726-0190. you will need the serial # from the bottom of the unit (stamped in) and the model #.
good luck! Bob
Posted on Jun 10, 2008
dutchman05
  • 487 Answers
SOURCE: brew time
this is not the norm. Sounds like a blockage problem. Descale the machine twice!!!! one after the other. and that should take care of it
Posted on Jun 20, 2008
EsWorld
  • 1618 Answers
SOURCE: bad taste
There might be some residue in the machine, you can try using some ScaleKleen which is activated citric acid, use a very small amount diluted in water(about 1/4 teaspoon). Run brew cycle with solution, after cycle complete, rinse reservoir, and run about 4 cycles with fresh water. This will clean out your machine.
Posted on Apr 08, 2009
Slow brewing
The coffee maker has three contributory factors for brewing experiences. First, putting enough water in container prior to brewing is expected to dispense in to coffee capture cup. Second, installing the component parts after inserting coffee leaflets should not hinder brew seepage into the cup. Third, allowing enough time for the brew to dispense is a requisite means to coffee impressions. Furth, coffee leaflets require appropiate numbers inserted at the container area lest the machine takes time to sock and dispense. However, refer to the device user guide for appropiate manufacturers instructures to user as expectations during brewing. Also, refer to the user guide to ascertain any conditions that may be signs of damage preventing fast brewing.
Jan 22, 2011 | Oster HDX23 12-Cup Coffee Maker
Cuisinart COD-4000 Stopped brewing coffee; lost clock and timing
I have no solution, however I have the same problem. Wondering if you have resolved the problem yet?
Feb 16, 2010 | Cuisinart Brew Central 12-cup Coffee Maker
Coffee too weak what are normal knob settings
Function Knob For setting time of day, and auto on and auto off times. a. Auto On The Auto On feature is used to program the start time of the brew cycle. The auto on time can be set for any time, day or night. The “PM” indicator is displayed on the LCD for nighttime program times. b. Auto Off The Auto Off feature is used to shut off the coffeemaker at a preset time, anywhere from 0 to 4 hours. c. Program Set The Program Set function is used to set the time for the Auto On function. d. Brew The brew function is used to start the brew cycle directly. e. Clock Set Used to program the time of day. f. Audible Tone (not shown) The Brew Central™ Coffeemaker is equipped with an audible tone which will sound 5 times when the coffee has completed brewing (coffee will continue to stream from the filter for a few seconds after tone).
If yours is a Vienna Digital Coffee Maker please click the link below. it is manual of Coffee Maker, it would be helpful to in the future.. http://www.cerinicoffee.com/Saeco_User_manuals_free.asp
Jan 20, 2010 | Saeco Vienna Digital Coffee Maker,...
Our coffee maker is only brewing half of the amount of coffee it should. Half way through the brewing, it shuts off. We've cleaned it with vinegar, but it still happens intermittently. It's actually...
Run a 1/2 pot of vinegar through it 2-3 times (I reuse it) and then run water 1-2 times to get the vinegar smell out. This cleans the mineral deposits from your water that are clogging it.
Dec 13, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Clean light won't go out, can't use delay brew feature.
Try unplugging it for several minuets & see if it clears it..
Jul 08, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Mr Coffee Maker FTX25 - coffee tastes bad
Try running a 1/3 white vinigar -2/3 water mix into the brewer, let it brew, then run several pots of clear water through it. This should clean up any bad taste.
Feb 09, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
I have Err 4 on my coffee maker... help
If “Err4” appears on the brew
timer display:
A button is jammed. Unplug the
Coffee Maker, press each button
several times, then plug the Coffee
Maker back in. (If the Coffee Maker
has been stored or used in a cool
environment, warm the unit to
normal room temperature before
doing this.) If “Err4” appears again
on the display, repeat this procedure.
• If “Err1”, “Err2”, or “Err3”
appear on the brew timer
display:
Press the On/Off Button to reset the
Coffee Maker. If the error codes
reappear, there is a problem with the
Coffee Maker electronics. Please refer
to the Warranty and Service section
beginning on the following page.
If the problem cannot be fixed with
the steps above, please refer to the
Nov 25, 2008 | KitchenAid KCM511 Coffee Maker
Coffee maker shuts off too quickly
It seems this coffeemaker insists on shutting itself off after 4 hours,
or whatever "auto-off" time you've programmed in. The only work-around I've found is to switch it to "Brew" and cycle the power switch off and on every time you pour a cup. That will start a new
4-hour timer cycle. Since the pot's still hot, it will go quickly to the
"brewing done" state and render 5 beeps.
Jan 08, 2008 | Cuisinart DCC-1200 Coffee Maker
KitchenAid KCM511 Coffee Maker Logo
164 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
graybeard32301
Ismael Rodriguez...
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
