Question about Hitachi 53UWX10B 53" Rear Projection Television
3-D picture My picture suddenly without warning, looks like a 3-D picture. I tried the magic focus and it did'nt help. I posted on this web site and was told to adjust the focus knob on the inside of the tv on the left side but I can't seem to find it. I don't want to touch anything other than the knob for fear of getting shocked. Is there any other way to locate this knob? Any suggestions will be greatly appreciated. Thank you in advance.
  • 927 Answers
Good Day, ladyluck5509;
It sounds like the TV is experiencing an auto focus problem. That in other words is a convergence problem, needing to replace the convergence IC's, chips. There is no known focus knob. If you are concern of shocking oneself, I would recommend that you seek a factory authorized service center for repair. Always, always get an estimate first.The normal/average cost for this repair should run between $350.00-450.00.
Good Luck, Big Irish.
Posted on Jul 09, 2008
I need to line up my colors and magic focus does not work.
If picture looks 3d in some way you have a convergence problem.
This set should use two of the STK-392-150 CHIPS FOR THIS.
The repair can be a do it yourself one if you have some skill. Magic focus only attempts to adjust at about 18 points on the screen.
Parts cost will be under 25 dollars. The repair consists of getting at the chips (2) and replacing both--on EBAY they will cost under 15 dollars (I fix sets and use a seller there).
If I can help make a comment here and if this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Sep 15, 2010 | Hitachi 51F500 51" Rear Projection...
Picture looks funny and the magic focus is not working
Model indicated cannot have magic focus--it uses a lamp---Confirm actual model number and let me help you. I am here to help.
REGARDS, SD TECH
Sep 10, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 43fwx20b Convergence Problems
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 25, 2010 | Hitachi 43FWX20B 43" Rear Projection...
I purchased a tv repair kit and replaced the convergence ic chips to fix my convergence problem. put everything back together and now, no picture. I tried magic focus and it works great, the colors are...
As per statement, "the magic focus works great, the colors are bright and aligned" it means the tubes are working ..you need feed a signal to see the picture...the tv video goes muted without signal
Dec 29, 2009 | Hitachi 60SDX88B 60" Rear Projection...
Poss. convergence problem with Hitachi 53UDX10B Ultravision
You have convergence problem. Either bad connections on ics, ics are bad or voltages to convergence circuit are missing. There are no bulbs in this set. 3 picture tubes,red,green and blue produce a picture than when alighned(converged) correctly on top of each other gives you a color picture.When not you get the effect you are describing. Frst you can try the magic focus in the menu.
Apr 20, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Looks like the picture is in 3D...magic focus won't adjust green
Replace Both of your STK ICs they are Big Black ICs Also CK and replace these resistors RK42 3.3 /RK46 1.8 /RK50 2.7/ RK54 1.5 RK54 1.5/ RK58 3.9 /RK62 2.2
Feb 15, 2009 | Hitachi 57F500 57" Rear Projection...
Will not show red color in picture, magic focus shows red though
You have a projection light element out. I had the green element go on mine. I had a service agreement so a repair tech changed it.
Feb 07, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Colors are separated on the top from the left to right
Probably the color convergence is off. I had a similar problem. Have you tried the magic focus button yet? That is located at left in the small front control panel. Power on TV, wait 20 min (according to user guide), then press the magic focus. If that doesn't fix the problem, you could try the service mode alignment procedure. But that's a little trickier. I don't have a link handy for that procedure right now, but will look for it if magic focus doesn't re-align your color convergence.
Jan 02, 2009 | Hitachi 53UDX10B 53" Rear Projection...
No picture, have sound
Dude, you dont have the same problem thanks for junking up my post.
Ok, so I have replaced the SUB power assembly and the SUB Defconvergence board, picture looks decent however magic focus just blanks the screen out and cannot adjust manually does the same thing.
Is there a way to enter the service menu and initialize the magic focus functions after servicing.
It must be using the saved ROM settings, but it wont let me adjust anything convergence wise.
Thanks,
Joe
Dec 28, 2007 | Hitachi 46F500 46" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
87 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
