Question about Bosch Water Heaters
I have a PHCC ProTankless heater (model GWH425HN) which is not producing any hotwater. I tried restarting the unit by setting the on/off button to off for 5 minutes and turning off the water source to the unit. Still not igniting the safety pilot. Thank you!
  • 33 Answers
SOURCE: burner will not light
Try this web site!
http://www.protankless.com/BoschProHome/GasProducts/BoschGWH425HN/tabid/506/Default.aspx
Copy & Paste to Google search engine.
Posted on Jan 27, 2009
  • 234 Answers
SOURCE: I have a probally ancient hotwater heater rheem
You will find two covers on the front.Behind each cover the you will find a thermostat ,there will be adail on it. It might be numbers like 120,150 or it might be letters,like A,B,C and so on.You take screw driver and turn to the right until you get the tempture you want.
Posted on Mar 23, 2009
SOURCE: pilot light going out on whirlpool hotwater heater-Fgif403t Flam
This is not a solution to that problem, but the dripping water is just condensation from the cold water in the tank. Like a coke can on a warm day. It goes away after everything warms up. It is more than likely a gas valve, but I have fooled mine into working by not turning the valve all the way up to the full on position.
Posted on Apr 11, 2009
  • 363 Answers
SOURCE: Whirlpool hot water heater serial#0426117756
sounds like you need to replace the thermal coupling. This component sends a signal to the gas valve that there is a pilot
Posted on Jul 30, 2009
SOURCE: noritz tankless water heater gives error code 11
This worked for me in the same situation. There is a filter inserted into main gas/ water control valve that senses water flow restriction. The sensor is connected to the gas valve. If it senses inadequate water flow it tells the gas valve to shut down so the water in the heater won't boil. Very expensive part. If you do find the filter clogged, a sediment water filter shoud be install on the inlet side of the water piping.
Posted on Oct 13, 2009
I have a tf325 bosch hotwater heater , problem is the flame will not stop when hotwater is turned off ?? Why and how to fix
After hot water has been drawn, the refill contents have to be heated to a set temperature in anticipation of the next demand. Otherwise, there would be a rush of cold or lukewarm water instead of hot.
Jan 27, 2015 | Bosch Water Heaters
My GWH 715 ES cannot restart after hot into cold water crossover
Check for obstruction in your watervalve. It has a flow meter, that needs to spin freely. Remove the watervalve and blow through it, you should hear it spin.
Also make sure you dont have an error code showing. Hold down your reset button for 5 seconds to reset an error code and get back to your set temp.
Jan 02, 2014 | Bosch ProTankless GWH 715 ES LP Tankless...
How do I get hotwater.. I did not receive owners manuel
Do you have the original packaging? Search on-line for the manufacturer. Sears sells these. If possible, visit a Sears store and get a website or help number from a package.
Then, make sure you have all parts assembled correctly. There is possibly circuit breaker or re-set button somewhere on the unit. Make sure the voltage matches your outlet.
Dec 15, 2013 | Ragalta Countertop Hot / Cold Water...
On A.O. Smith water heater model BTH 199 100 where is the heat sensor rod located ?
Parts list:
http://www.hotwater.com/lit/partslists/197728-004.pdf
Flame rod, flame sensor sits next to igniter inside combustion chamber. This can be cleaned with sandpaper. Do not touch with fingers. Purpose of flame rod is to detect whether ignition has caused actual, sustainable fire inside the combustion chamber.
If sensor is bad, or no ignition is detected after 2-3 attempts, then 'no ignition' error is given.
Bad gas control valve, bad-or-dirty flame rod-sensor, low gas pressure, misaligned rod, dirty combustion parts, etc
Service handbook:
http://www.hotwater.com/lit/training/316586.pdf
High gas pressure spikes can daMAGE gas control valve p7
Product manual:
http://www.hotwater.com/lit/im/com_gas/197727.pdf
Word-search for 'failure'
Low gas pressure. p14 and p54
1-3 trials before declaring 'ignition failure. p48
bad flame sensor (clean with sandpaper) #10 p58
unit must be grounded (check outlet with circuit analyzer) #12 p58
Sequence flow chart p59
Rough starts = ignition failure p60
Troubleshoot chart - ignition failure p62
Mar 12, 2013 | A.O. Smith BTH-199 BTH-199 100 Gallon...
I have an instant hotwater system with the futher most bathroom about 45' away. I am looking at adding a recirculating pump on a timer at the furthermost bathroom to get hotwater quickly in the...
Maybe I am not understanding your problem exactly, but if you have the instant hotwater system installed it should be measuring the temperature of the water in the hot water line and if it drops below the set level it should open the hot water side until the temperature is reached. If it was installed correctly it puts the hot water back into the cold water line so it isn't wasted.
Sep 18, 2011 | Grundfos RCP-96 Recirculation Pump for...
E4 code on a bosch ghw 715 control unit
Before calling service technician, open following link for Bosch troubleshooting resources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Error codes are starting point for troubleshooting, and solutions vary by model and unit.
E4 is Backflow temperature sensor over 309 degrees F. Appliance will close burner and lock.
Check combustion air and backflow vent piping for blockage.
Check if secondary fan connections are disconnected.
Check venting specifications are met. Long vent lengths, venting with more than three elbows, blocked vent or combination venting may cause this failure.
Check sensor resistance
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 29, 2011 | Bosch ProTankless GWH 715 ES LP Tankless...
Mar 23, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Burner will not light
Try this web site!
Jan 27, 2009 | Bosch ProTankless GWH 715 ES LP Tankless...
Small seepage underneath hotwater heater.
soetimes its gaskets around flanges and heater element fixings that fail
have a good look round after drying the area with tissue etc.
leave a dry tissue round the based so you will see tell tale trace stains where its perhaps leaking from
Nov 29, 2008 | Water Heaters
Water Heaters Logo
268 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
