Question about KVH 01 0277 01sl Tracvision A7 Mobile Satellite Tv Antenna System
WHEN I TURN THE UNIT ON THE MOTOR CONTINUES TO RUN FOR A LONG TIME. SOMETIMES IT WON'T STOP RUNNING SO I TURN THE UNIT OFF. IT SOUNDS LIKE THE LNB IS SPINNING AROUND AND AROUND. I HEAR A COUPLE OF INITIAL MOVEMENTS AND GET A PICTURES, BUT THEN IT STARTS TO SPIN AND SOMETIMES WON'T STOP
  • 20 Answers
There are many possible reasons of this problem. Maybe antenna didn't see satellite, maybe satellite setup is wrong (frequency, bitrate and so on). The best way to solve your problem is to get logfile from antenna.
Posted on Oct 10, 2012
Dryer intermittently not starting.
The rat chewed up the power line and caused it to short out. Kill the rat!
Jul 14, 2013 | Whirlpool Dryers
My new Bosch B26FT70SNS fridege which i got delivery yesterday morning compressor motor won't turn off. Since yesterday afternoon around 5pm until now 11am. More than 18 hours continue running, the...
HI JAMES.ummmm new bosh...should work.if not and motor running cont.then it sound to me like is out of refrigerant or motor faulty.check condenser unit.should hot.if cold call under warranty or replacement i would say.good luck Ali
Jun 30, 2012 | Refrigerators
The AC unit when turned on will run properly for about 20 min. At that time the fan will stop. The unit continues to cool. If I turn off AC and turn back on, the process repeats. Could it be the run...
If it was the capacitor, the capacitor would be shorted which you would be able to tell by your meter. It sounds like the motor is getting hot from either worn bushings (bearings) or the wiring in the motor has a partial ground or short. In either case, sounds like you may be replacing a motor.
Jun 27, 2011 | Goodman CPLE24-1 Air Conditioner
Goodman GS9 propane furnace inducer motor runs continuously
it sounds like the low temp limit switch, the one that cools the furnace down with the burner off and the thermostat open, when it cools to a point the fan stops, the other switch in burner area turns burner off/on, hope this helps
Jan 31, 2010 | Goodman GMS90703BXA Heater
The CV750 stopped working. It will come on sometimes but most of time it will not work. I installed new bag and cleaned filter. Green light on side of unit is on. Switch on side of unit will not make it...
The motor may have a sticking brush or a dead commutator segment. Turn off power to the unit to check for sticking brushes. Reapply power, does it now run? If not, shut it off, physically turn the motor a few degrees, and reapply power. If it still doesn't run, look for loose wiring around the motor. If it does run, replace the motor armature or the entire motor if the armature is not available as a separate part.
Oct 18, 2009 | Broan-NuTone CV750 Central Vacuum
My outside unit runs a little while then shuts off.
More likely the out door fan motor has bad bearings and that would cause the out door unit to run for 15 to 20 min but it could be low on freon
when the out door unit runs after 3 to 5 min the larger of the two copper lines going into the unit should be ice cold
If the thermostat you just installed has a time delay that will keep the indoor blower motor running for up to 5 min after the unit shuts off
Sep 01, 2009 | Honeywell Heating & Cooling
The a/c unit cooling fan shuts down shortly after unit kicks on.
If a fan motor quits working during a cycle it usually means that the thermal protector is turning it off. If you had an amp meter on it, you would notice that it is exceeding the listing on the nameplate, Nine times out of ten this is irreversable, the motor needs to be changed. Sometimes if there are oil ports on the motor, you can add a few drops of zoom spout oil and that does the trick. But usually the motor is already damaged. Good luck.
Jul 11, 2009 | Carrier 38CKC036 Air Conditioner
Motor sometimes will run and sometimes not
If the motor is still turning, good. It is not burned out. IF the motor is not turning with the unit on, it is either a reset switch (not all units have them) or the motor is burned out. New motors need to have the pulley adjusted so it is not too tight or not too loose.
May 14, 2009 | Mastercool 67471 Evaporative Cooler Air...
Dish 311 won't detect switches
dishnetwork is kind of tricky on the detect switch thing. sometimes if you are having troubles on just one receiver you have to run detect switch over and over again, sometimes as much as maybe 20 or 30 times. if it still doesn't work, hope you have a service plan so they will send you another unit to switch out. also try a different LNB ( low noise block downconverter) and check switch a few times. i know that sounds kind of stupid, but it works sometimes.
Feb 17, 2008 | RCA DISH Network(r) 311 Satellite System
Kenmore 110.78932790
Bob, glad you stopped the check, sounds like you need a even heat board. If you press and hold the start button the unit will run. As soon as you release it it stops. Tell the pro you would like a refund. Your part number is 3402605. The board is easy to replace. check out the pic. Catriver
Aug 14, 2007 | Kenmore 72062 Gas Dryer
KVH 01 0277 01sl Tracvision A7 Mobile Satellite Tv Antenna System Logo
271 people viewed this question
Top KVH Boating Experts
steve morris
steve morris
Bill Boyd
Are you a KVH Boating Expert? Answer questions, earn points and help others
