Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
Kenmore 53504300 my refrigerator is not defrosting. I had to force the timer to defrost every 2 days, otherwise the ciols will get frozen. I had replaced the bi metal defrost & the defrost timer, but everything seems to be the same still getting frozen. I am not if the relay is doing its work. please I need help.
  • 943 Answers
Hi Thanks For The Question. Did You Say That The Heater Would Come On. If Not Check The Defrost Heater Thanks The Appliance Doc
Posted on Oct 03, 2008
Freezer keeps frosting over and then the refrigerator gets warm. I unplug it and let it thaw for a day and it works great for 2 or 3 days and then it frosts up again. we have a factory installed ice maker...
You have a problem with your defrost system which is made up of the defrost heater (item #14); defrost thermostat (item #21)
And the defrost timer (item #23).
Although the defrost timer is the most likely suspect you need to rule out the other two. If you have an ohm meter you can test the defrost heater and defrost capacitor. Continuity = good Open/infinity reading = bad
Aug 13, 2011 | Refrigerators
The evaporator coil is frozen. can i take off the cover and defrost it?what are the possible causes?
If the entire coil is frozen you can defrost it and it will work for 2-3 days but eventually you will be back at square one. You have a defrost problem and you should replace what is broken. I don't know what you have but it could be the heater, terminator, defrost timer or board, and thermister.
Dec 24, 2010 | Kenmore 53542 / 53544 Side by Side...
Ciols freze up about every three days
this is usually a problem with the defrost circuit,timer or sensor may be bad the timer can not be advanced
i would suggest that you replace the defrost timer first
Mar 28, 2010 | Frigidaire FRS26R4A Side by Side...
Remove the rear panel in the freezer and see if the evaporator coils are frozen over.
If so dethaw coils with a hair dryer.
Reassemble freezer and set controls to the normal position.
Although you replaced the defrost timer if the coils were frozen over in the freezer no air can transfer to the ref. section from the freezer.
If you do not want to dethaw the coils unplug the ref. for 1-2 days and leave the doors open .The coils will dethaw by then.
Jan 17, 2010 | Kenmore Refrigerators
Bottom frezzer is working but fridge is not blowing cold air
Refrigerator gets cold air from freezer compartment. Either the air flow is blocked by food items or ice, or the recirculating fan is not working.
The most common failure is that the freezer coils get all iced up becuase the defroster timer, defroster thermostat, or heater has stopped working.
When it's running, you should feel cold air blowing out of the vents that are in the fridge, otherwise, the 'air tower' (air vent) is blocked with ice.
If you manually defrost the whole thing, and it runs fine for a day or so, then it's not defrosting properly. If you manually turn the defroster timer, and you don't hear the scorching/hissing/gurgling of the defroster working, then that would confirm a fault in the defroster circuits.
Based on the following thread, it's probably a bad defrost thermostat.
Nov 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Frozen coils in freezer side of fridge/ freezer s/s
had the same problem with mine. found out it was the defroster timer circut board. mine was located in the reffidgerator side underneath the panel where the slide controls are. went to parts store and bought a new one for $35.00. it unplugs and plugs in easy. found out it's a commen problem and happens every couple years or so.
May 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water leakage
It is possible that your refrigerator is not defrosting properly. If it has a timer defrost try to turn it slowly clockwise until you hear a click and about one minute you should hear a crackling noise indicating the freezer is in defrost. If the timer does not turn and defrost about every 8 hours I suggest you change the defrost timer. Let me Know, Thanks, Sea Breeze
Feb 26, 2009 | Kenmore Refrigerators
Freezer not defrosting
The reason it is not defrosting is one of three things. First and most likely is that the Defrost Thermestat (aka BiMetal) is open and needs to be replaced, secondly it could be that the defrost timer is bad and lastly the heater can be bad. The bimetal and heater are found behind the back panel in the freezer section. The time is usually located near the controls in the fridge section. I would need you entire model number to tell you exactly where it is. To replace the either part is fairly straight forward. With the full model number I can walk you through the easiest way to test each part.
Nov 01, 2008 | Kenmore 62232 / 62234 / 62239 Bottom...
Refrigerator on the fritz
The defroster is not working. Ice build up prevents cold air from the freezer chest from blowing into the lower part.
The way the defroster works is this: There is a defrost timer, probably found under the refrigerator at the front, that turns on the defroster three times per day or so. That turns on a heater nested among the freezer coils. It keeps heating until the defrost thermostat gets warm; then it quits defrosting.
I think your defrost timer doesn't turn. You can turn it with a screw driver till you hear a click. Now your ice compartment should be defrosting. With ice buildup it may need lots and lots of defrosting. You might not get cooling back into the lower part for awhile, till the ice buildup melts.
By the preceding, you should know if the defrost timer needs replacing.
If you should need to manually defrost the freezer coils, they are, I think, under the floor of the freezer. To defrost them, I'm told, a hair drier works better than boiling water. The defrost thermostat is in there too, a one inch unit with two wires. It should have no continuity warm, closed circuit frozen. If it has open circuit frozen, that would be your problem.
Jun 14, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
