Ovens Logo
A
Anonymous Posted on Jan 02, 2011
Have a WFG374LVQ 1 it has no oven ignition (gas). Snapping sound but will not ignite. Broiler works find.
Ryan Nguyen
Level 2:
Sergeant:
Champion:
  • Expert 342 Answers
  • Posted on Jan 02, 2011
Ryan Nguyen
Expert
Level 2:
Sergeant:
Champion:
Answers
342
Questions
0
Helped
70406
Points
993
You issue has to be the gas valve because it seems like it will not open try to see if there is a manual control for this and if there is then open it and try to light it.
DCS RSC305 gas range oven and broiler won't heat
Ours did that and I had to replace the igniters that did not work.
Apr 28, 2018 • Ovens
1helpful
My gas oven is not working-just used this afternoon for bread and chicken-it was fine-broiler and burners work ok
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 29, 2010 • GE Ovens
The oven & the broiler don't work. There is
You will need to get a new igniter kit. If there is gas and no spark, then igniter is most likely faulty. You can go to repairclinic.com for parts and manual
Sep 09, 2009 • Ovens
1helpful
Oven won't ignite but broiler does
If your oven won't bake, check these:
Bake igniter
Other causes
Bake igniter Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
Aug 11, 2009 • Ovens
2helpful
The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 09, 2008 • Ovens
GE Oven does not ignite, bute Broiler does.
Your problem is with the oven igniter. You have the stove MODEL# so you should have no problem finding the part you need.Shop around to get your best price. Good Luck Friend.
2answers
Top Broiler works, oven does not work at all
hi yes you could replace the broil for the bake but they are very fraglle so i would buy a new bake igniter replace
1helpful
Broiler Works/Oven Doesn't
Jrzy, even though you can see the bake igniter glowing, that doesn't mean it's good. Igniters actually get weak (unlike a light bulb that simply burns out). It's hooked up in series to a safety valve (the valve that allows main gas into the oven) which actually reads the amps flowing through the igniter. If the igniter is weak and the amps are too low, the valve won't open up. Replace your igniter and you'll be cookin' with gas again. Tip---> before you unscrew your old igniter, put a little liquid dish soap on the threads for lubrication. This'll ensure it comes out with no problems.
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
