When fast spinning my hotpoint aquarius has become very noisy, sounds like its grinding
    Sergeant:
    Champion:
  • 342 Answers
It sounds like the bearings have gone bad try to look for repair parts for that washing machine
Posted on Jan 02, 2011
Hotpoint wdpg8640 very noisy on fast spin, noise has increased in the last week. Should I be concerned?
yes very concerned it could be a loose weight or bearings failed both need attention asap.
Jun 26, 2014 | Hotpoint Aquarius WD640 Front Load...
I have a Hotpoint WF540 washing machine. When it goes into fast spin, the spin cycle is quite noisy....on slow spin it is fine......could this be a bearing problem? If so how easy are they to replace?
Sounds like drum bearings most cases you need to buy half drum with bearings fitted if your very good at diy no problem if not call engineer.1st check concrete weights are not loose top and bottom.............you can buy parts @ espares.co.uk this will give you idea of cost which maybe quite high.
Apr 21, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WF220P has become very noisy during spin, especially at high revs. Can it be worn brushes or motor, or bearings? Otherwise all is OK.
Remove drive belt, and spin drum by hand, if it feels rough or noisy, then the main drum bearings are worn.
If no noise from drum, could be a motor prob.
Please rate ,my solution.
Thanks.
Nov 02, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Very noisy when spinning
hi
it may be the belt making noise,,,check it,,,
thank u,,,//////please rate it
Jul 12, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint Aquarius WMA37 - the drum is not turning, even by hand
Remove rear panel of washer, slip the belt off, then try the drum to see if it turns, if it does, then the motor is the problem, if it does not, then the main bearings have siezed, or there is something fast between the inner and outer drum..
If it was noisy on spin prior to this happening, then it is more than likely the main bearings that have siezed.
Plz rate my solution.
Thanks.
THAN
Jan 10, 2009 | Hotpoint Aquarius WD640 Front Load...
Started having a noisy rinse & spin cycle, then stopped.
Open the washer door and spin the drum by hand, if it feels rough or noisy and rumbling, then the main drum bearings have failed. There should be little or no noise when you spin drum
This is a major repair, and I would not recommend a D.I.Y solution.
Other possibility is there is something in the pump, but you would only hear this when the pump is working.
Plz rate my comments.
Thanks.
Jan 07, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint aquarius 1100 bangs while spinning
Several possible reasons for this. M/C not level, causing it to move about.
Overloading of m/c.
Loose concrete balance weight, there is one at top and one at bottom.
Suspension spring broken or unhooked.
Suspension leg loose or broken.
Main drum bearings worn, to check this, turn drum by hand and if it feels noisy or rough , then bearings have gone (expensive repair).
There are other possible causes, but these are the main reasons.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Drum makes grinding noise when turning
Hi.
spin the drum by hand, if it feels rough or is noisy, then you probably have drum bearing failure.
Another possibility is one or more of the drum paddles may have come adrift..
These can be replaced.
Nov 24, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Bearings very noisy on the drum
aquarius w f 541 1400 spin drum bearing noisy
Nov 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
88 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
