Question about SanDisk Sansa e250 MP3 Player
Unable to format the Sansa e250
I have been reading through all the solutions to formatting the Sansa. I can get to the recovery mode, tried renaming the text document. Nothing. Then who knows what I did, but I keep getting lock and unlock messages and am unable to do anything. I can't format the traditional way. .. . this really stinks. Can you walk me through this? I have tried to find firmware. . .I have no luck with that. I have the updater loaded. . .but have no clue what it's supposed to do. HELP. . . Oh, I was able to see the Sansa on the windows media player, but not the music section... could see photos and video.
When unplugged it tells me that I have to unload 6 MB of info in order to work.
  • pamperwithmk Jul 10, 2008
    That's odd. I actually go the answer from Sansa. . . but thanks.
Get a memory card idk
Posted on Jul 09, 2008
USB2.o and MSD mode
You need a memory card.
sincerely, Britani
Apr 19, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 firmware problem
Verify that the device DOES NOT say RHAPSODY on the back or E2**R. This would indicate the rhapsody version, whereas the firmware is totally different.
If it is simply a E200, try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Please RATE my solution at the bottom.
Nov 28, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 not workking
This is the generic solution for most problems.
** if it doesnt go into recovery mode, there is nothing else you can do other than have it replaced if its less than 1 year old.
Best of Luck.
Nov 22, 2007 | SanDisk Sansa e250 MP3 Player
Bad Track
Change the Mode on the device and try to format again.
SETTINGS>MODE or USB MODE.
If that doesnt work. This will;
Best of Luck.
Nov 19, 2007 | SanDisk Sansa e250 MP3 Player
Downloded recovery from sandisk website now get error msg
That software only works with the non-Rhapsody versions, hence the error message. You can call technical support and they can walk you thru the fix. Its too much to type. SanDisk Technical Support 1-866-726-3475 Best of Luck.
Sep 10, 2007 | SanDisk Sansa e250 MP3 Player
Sansa Raphsody 250R 2GB
It is very dangerous in formatting the 16MB format of the device. After learning it a hard way, i also learned the the 16MB format is a second partition of your player where is installs the firmware of the device. Formatting it will ruin your player and it will never function again the way you want it to work.
Jun 15, 2007 | SanDisk Sansa e250 MP3 Player
Sandisk sansa e200
I had this same problem on my sansa and tryed the previous solution with no luck. Out of frustration i email the sansa technical support. Try these steps to format the player: -Turn on the player and access MENU > SETTINGS > USB > MSC - Once the player is set to MSC mode, reconnect it to the computer and open the My Computer window. - Once you see the Sansa icon in the My Computer window, right-click it and choose FORMAT - In the Format window, choose FAT 32 and make sure that Quick Format is NOT selected, then choose START -Once the format has completed, disconnect the player from the computer to allow it to refresh. If you plan on using Windows Media Player to transfer files, return to the USB menu and set the player to MTP mode. Otherwise, leave the player in MSC mode and you can now resume transferring files. Formatting your player will deleate all files but you can putt them back on!!! Best of luck!
Apr 25, 2007 | SanDisk Sansa e200 MP3 Player
Sansa e250
I did not get the "Swtich to Recovery mode" screen, my screen was stuck on "Bad Track." I formatted the drive (which deleted EVERYTHING), and then i put the songs back on, and it works just fine. Try this, it might help.
May 07, 2007 | SanDisk Sansa e250 MP3 Player
Help!!!!
SAME THING HAPPEN TOME NEED HELP
Mar 27, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
