Question about Dynamo MartinLogan Subwoofer Speaker
How to remove the back plate of the Martin Logan Dynamo subwoofer ? I need to send in the back plate for repair.
3 Suggested Answers
SOURCE: Bought a used Martin Logan Dynamo subwoofer a
Neither the amp or the sub have grounded power cords.
I have discovered the ML Dynamo takes about 30 minutes to switch to standby in auto mode.
With speaker level inputs connected to the Onkyo A807 amp, both units powered from the same wall outlet, Dynamo sub on Auto, the sub hums for about half an hour after the Onkyo is switched off, then the sub goes quiet. Not so good.
I connected a bonding wire between the two units on 3_7_09. If I smoked some old audio gear I could just look at that as an opportunity, right?
Works fine. Now I have the ML powered from the wall and working normally.
Posted on Jul 03, 2009
SOURCE: I own a used Martin
Did you get the sub fixed? I know someone with the same problem - won't turn on, fuse is fine. May be due to different underlying problem, but wondered if you discovered what it was and if you got it fixed.
Mike
Posted on Oct 29, 2010
How do I brigde a krell show case amp from 5 channels to three channels
Thai will require removal of the top cover to move jumpers or program dip switches in proper order. This will be explained in the owners manual which is located at Krells web site.
Steven Leckrone
The Service Department
30 Unquowa Hill St
Bridgeport CT 06604
203-331-0671
Steven@theservicedepartmentct.com
www.theservicedepartmentct.com
Nov 14, 2014 | Krell Audio Players & Recorders
How can i connect my dynamo 700 w using martin and logan transmitter to my marantz sr5008
You just need one of these though all the sockets would need to be male:
Jul 06, 2014 | Audio Players & Recorders
Mahindra renault logan steering pump repair or new
please tell me about repair mahindra logan staring pump
Feb 02, 2013 | 2007 Dacia Logan 1.6
My small son throwed so many small toys inside subwoofer. How can I open and get rid of them? Philips subwoofer.
he must have done it through the port in the front of the subwoofer.
If you look in the back of the sub woofer you will notice a metal back plate with all the sockets and controls on it. You will notic a lot of screws on it, now remember only to remove all the screws close to the edge of the metal plate ( do not remove any of the screws in the middle portion ) about 8 to 12 screws. After removing the screws pull out the metal plate gently. There will be some cables attached to the plate , do not attempt to remove this !!. Shine a torch into the box and see if you can retrieve the toys from the gap you have created by parting the back plate.
After having removed the toys place the plate back carefully making suree no wire is trapped between the box and the plate. Put two screws on the opposite ends and then lift the subwoofer and shake it to confirm if any more toys are in before you put back all the other screws.
Apr 24, 2011 | Audio Players & Recorders
I have the 1911 and Martin Logan Motion 10 speakers. Why do I have to turn the volume up so hi to get sound?
are the ohms on the speakers and the receiver rated the same, if not theres the problem
Mar 14, 2011 | Denon Audio Players & Recorders
How do you pull the impeller off of the shaft for a Dynamo 1-1/2 sn 1-22-EO3?
After you have the pump broken down. Check for a screw in the center of the impeller. If it has one then you will need to remove it. This will be a left handed screw. If that is done then you will need to remove the back of the motor or the small center plate on the back. Then the shaft will accept a wrench to hold it with. Then you should be able to unscrew the impeller with water pump pliers or a large basin wrench. The brass threads on the impeller will kind of stick to the steel of the shaft so it is just a matter of breaking it free, then it will spin easily.
I usually put a screwdriver in the left side of the impeller and give it a sharp smack downward with a hammer.
There are two methods, good luck.
Sep 27, 2010 | Dynamo ABOVEGROUND POOL PUMP - 1.5HP -
I own a used Martin Logan Dynamo (older series) and just today found out there is no sound coming out/no led light (at the back) either. I opened up the back and saw the 110V power is getting in but no...
Mike
Aug 28, 2010 | Dynamo MartinLogan Subwoofer Speaker
Bought a used Martin Logan Dynamo subwoofer a couple days ago and have a very loud hum when the ac cord is plugged in, even if the speaker is not connected to an audio source. The "hum" can be heard in any...
Jun 30, 2009 | Dynamo MartinLogan Subwoofer Speaker
Loudspeaker Repair or Buy New Replacement?
I have tried the repair thing before. They can be repaired the only problem is they dont seem to hold up as good or for long. I found it better just to replace speekers with new ones
Oct 23, 2008 | Cerwin Vega LS-15 Speaker
Dynamo MartinLogan Subwoofer Speaker Logo
224 people viewed this question
Top Dynamo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Dynamo Audio Player and Recorder Expert? Answer questions, earn points and help others
