Question about Master Heaters Master B115DT 115,000BTU Fan Forced Air Heater with Thermostat
I need to fine what the cover on front of heater is called to order a new one(where the heat comes out) mine is broken and brittle like it got to hot
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 69 Answers
If you are talking about the dome plate at the end of the heater where the flame hits and turns red, that is part of the combustion chamber. You would have to replace the hole chamber.
Posted on Jan 03, 2011
  • T bone 1963 Jan 03, 2011
    Also, if it appears that it got to hot and melted , your air pressure on the air pump is set to high. Make sure you do not have a flame shooting out of the combustion chamber.
Rear Floor Vent heat only
Sounds like your heater coolant hose door flap is broken or loose. May want to check behind the heater controls, if your components are mechanically operated. If electronically, may need to perform more troubleshooting before replacing this component.
Jun 17, 2017 | 2004 Ford Econoline
Boiler
Call in a plumber. Mine did the same, new valve was needed, Possibly Diaphram needs replacing.. Consider how old is Boiler, and does it need replacing anne melhuish
Jan 25, 2012 | Water Heaters
The tankless water heater was working this morning, but now it seems no power is going to it. We've checked the circuit breaker several times but it doesn't seem to want to reset. Is there a fuse that...
If the circuit breaker will not reset it could be a few different things. First, circuit breakers do wear out. The bi-metal strip that makes the breaker function does break down metallurgy wise. A new one would have to be installed to fix this problem. The other possibility would be that a wire inside the water heater has grounded out thus not allowing the breaker to reset. A wire might have gotten to hot and the insulation around it might have melted or became brittle and fell off allowing the wire to touch bare metal inside the water heater.
May 02, 2011 | Stiebel Eltron TEMPRA 24 Tankless Water...
Heater not working for my C180 mercedes, blowing air but no heat coming out
heater not warking for my C180 mersedes, blowing air but no heat coming out, hot water which coming from water pomp doesn,t go throw,
Dec 18, 2009 | 1994 Mercedes-Benz C-Class
All air hot or cold comes from the defroster. will not blow through the vents or on the floor.
Check for broken / disconnected vacume line in engine compartment. they are about. 4mm in diameter made of hard plastic.It will go through the fire wall usually on the passengers side near heater / AC blower box. After years of heat and cold they become very brittle. they carry it at most auto parts stores.
Oct 09, 2009 | 1988 Dodge D-Series Pickups
No heat from heater in front, rear heat works fine, engine is hot
Hello
I recently had a simular problem...try to follow the heater hoses that come from the engine and go into the firewall to the heater core... one of the 2 hoses connects to a plastic valve right before the firewall. This valve shuts off the flow of hot coolant into the heater core when heat is not needed.. Look carefully at this plastic valve, there is a wire pull cable with a small loop at the end that connects to a lever on the valve. Have a helper work the heat controls and make sure the cable pulls on the lever at the firewall valve...I've seen some cables disconnected. Hope this helps with your diagnosis.
Apr 04, 2009 | 2004 Honda Odyssey
The hot water and central heating wont work together
what size of gas line is going into boiler and water heater? is it black iron ? natural gas or propane? have you checked gas pressure at water heater and furnace ? if they work fine individually then you have a problem with incoming gas pressure. Call gas company and ask them if they would come out and check gas pressure.
Feb 03, 2009 | Water Heaters
No heat coming out of blowers
there may be an air lock in the system make sure your heaters are switched to hot when bleeding the system and try again
Jan 08, 2009 | 1998 Ford Escort
Heater valve
there is no heater control valve in this truck, heat control is done through what are called blend doors. So the issue may be the front blend door motor has failed, this is very common on all Ford heatimng systems except the Focus.
Dec 15, 2008 | 2000 Ford Expedition
Master Heaters Master B115DT 115,000BTU Fan Forced Air Heater with Thermostat Logo
37 people viewed this question
Top Master Heaters Heating & Cooling Experts
T bone 1963
Gil Shultz
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Master Heaters Heating and Cooling Expert? Answer questions, earn points and help others
