Question about HP DeskJet 3322 InkJet Printer
I have a Hp Deskjet 3322 and cannot figure out why when I want to print a black and white photo that a blank page is being printed out. My Color is low so I want to print in greyscale because I have a lot of black ink in the printer. When I want to print out text in black everything is printed out okay. I do not see in the printer settings to set the printer at greyscale. How can I make my printer use only the black ink??? I have never had any problems with other HP printers like I do with this one.
  • 193 Answers
  1. In the software application that you are using to print, click the File menu.
  2. Click Print . The Print dialog box opens.
  3. Make sure that the name of the HP printer you are using displays in the printer Name box. If necessary, use the drop-down list to select your printer.
  4. Click the Properties button. The Properties dialog box opens.
  5. Check the options on the property tabs to make sure that there is a checkmark in the box by Print in Grayscale and then click OK .
  6. Try printing again
Posted on Jan 13, 2011
I have HP deskjet F4488 printer which is all in one method. but i have problem that whenever i am trying to print the color(document)page in black & white type but i cant get the black & white...
hi..
in when you click on the print botton a dialogue box opens which shows the print properties. in that you have to select the grey scale then only it prints in black and white
if my answer was usefull please vote me
Jul 14, 2010 | HP Office Equipment & Supplies
HP Deskjet 990cxi Printer NOT printing B/W, only red.
To customer of HP deskjet 990cki: I purchased the HP photosmart Plus B209 ~ January 2010. 3 months into, I have learned that when the color ink that you don't use evaporates, the black ink will not work at all, no matter what you adjust or clean.To make it work you have to purchase more color ink...on & on & on..$$$$. Neither HP nor Best Buy will refund my investment. Spoken with HP customer service reps. in the Philippines & Canada both being outside of the US. NO customer satisfaction. No refunds. I suggest Boycotting both corps.
Jan 24, 2010 | HP DeskJet 990cxi InkJet Printer
How can I print a color picture without using a black catridge?
Black ink is an essential part of the printing process. The black color is only made by the black cartridge, the color cartridge does make "black".
One or more optional photo cartridges may be available, depending on your printer model.
  • Use the photo cartridge with a tri-color cartridge for best-quality color photos and graphics, and sepia or antique photos.
  • Choose a gray photo cartridge to print black and white photos with truer grays and richer blacks.
Nov 21, 2008 | HP DeskJet F380 All-In-One Printer
Printer only prints out in blue
change the color cartridge and instead of Black,,use Photo Cartridge..
Nov 01, 2008 | HP Deskjet 3845 InkJet Printer
How do I install an ink cartridge? HP photosmart c5280 All in one
To replace the print cartridges Perform the following steps to replace the print cartridges:
  1. Make sure the HP All-in-One is on. CAUTION: If the HP All-in-One is off when you open the print cartridge door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. The HP All-in-One can get damaged if the print cartridges are not docked safely when trying to remove them.
  2. Open the print cartridge door. The print carriage moves to the far right side of the HP All-in-One. Figure 1: Opening the print cartridge door c00956268.gif
  3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. Figure 2: Removing the print cartridge from the slot c00956269.gif 1 - Tri-color print cartridge slot 2 - Black and photo print cartridges slot
  4. Pull the print cartridge toward you out of its slot.
    NOTE: Remove the black print cartridge to install the photo or gray photo print cartridge, and store the black print cartridge in the print cartridge protector or an airtight plastic container.
  5. Remove the new print cartridge from its packaging, and carefully remove the black plastic tape by using the pink pull tab Figure 3: Removing the new print cartridge from its packaging c00956270.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad electrical connections. Figure 4: Do not touch the copper-colored contacts c00956271.gif
  6. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into the empty cartridge slot. Make sure to push the print cartridge firmly until it snaps into place. If installing the tri-color print cartridge, slide it into the left slot. If installing a black, photo, or gray photo print cartridge, slide it into the right slot. Figure 5: Installing the print cartridge c00956272.gif
  7. Close the print cartridge door. Figure 6: Closing the print cartridge door. c00956273.gif HP All-in-One prints a print cartridge alignment page if a new print cartridge is installed.
  8. When prompted, ensure plain white paper is loaded in the input tray, and then press OK .
  9. The HP All-in-One prints a test page, aligns the print head, and calibrates the printer. Recycle or discard the page. A success or failure message appears.
    NOTE: If colored paper is loaded in the input tray when aligning the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support at www.hp.com/support If prompted, choose your country/region, and then click Contact HP technical support.
  10. Press OK to continue.
May 15, 2008 | HP Office Equipment & Supplies
HP Deskjet 712c prints only blank
I had the same problem and what worked for me was to make a PDF and then check the box "print color as black" I only say this is a fix because I was desperate. I realize this is a time consuming workaround. also if you are going to do this make sure that your printer settings are for Color but then the print color as black box is checked. hope that helps.....
Jan 25, 2008 | HP DeskJet 712c InkJet Printer
Wont print
some printers share the ink from color to black but you can select if you wants to use only black just go to printer than properies than select to use only black but you probably have to remove the empty color one
Dec 18, 2007 | HP DeskJet 3940 InkJet Photo Printer
Printing only blank pages
you have to go to the printer settings start printer properies ink or color than change to color because you can set your printer to print color or just black does not matter if that one has color if the setting is for black it will print just black
Dec 02, 2007 | HP DeskJet 3940 InkJet Photo Printer
HP Deskjet 640c
I am sure that you can go into the properties for the printer setings and choose an appropiate colorseting ..it is probably set to save ink......so u can go to printers in control panel and right click on your printer that shows there and probably just mess with teh setting a little .... another idea is to just delete the printer from there and reinstall it again.......
Apr 25, 2007 | HP DeskJet 640c InkJet Printer
HP DeskJet 3322 InkJet Printer Logo
70 people viewed this question
Ben Johnson
