Question about Linksys EZXS55W EtherFast 10/100 5-Port Workgroup Switch (12503060)
I have Linksys Switch Model # ezxs55w, 2 computers and one xbox 360. Got ist comp online, configred xbox ok, but 2nd comp having troubles with. Clicked on network connections, properties, selected manual ip address, duplicated "ip config" from primary comp and dns server info. Status says connected, 100mbps. but can't get online? Also yellow caution pops up stating" ip conflict". Can you help out a noob ? What am I doing wrong?
5 Suggested Answers
ted1430
  • 339 Answers
SOURCE: Cant find IP address
You need to make sure that DHCP is turned on for the router and the the Xbox is set to automaticallly get network settings. If not, then you will need to manually configure the adress and settings. If this is the case, please post back the address of the router and all other devices on your network and we can help you make a suitable choice and get it configured.
Posted on Aug 28, 2009
bob_computer
  • 3153 Answers
SOURCE: problem using sd208
A switch will allow you to see multiple computers and use multiple connections at any one time.
It will also allow you to PING other computers connected to that switch.
Ensure it a powered swictch and that the power is ON.
Double check that you do not have any IP conflicts and that both computers are in the same domain or workgroup.
Also check that the subnet is the same
My home network consists of xboxes, media centres, servers, laptops, other computers so I can confirm my information to you as correct.
Posted on Sep 19, 2009
  • 10 Answers
SOURCE: i use this router to get internet for live on 2
Could be a few different problems. One is your internet connection speed. If its below 5Ms I would say you are blowing out your bandwidth and it your ISP can't keep up, thus causing a slow connection or even some time-outs. If you are at or above 5M, check what ports you have your connections in. Some hubs are set specifically to take the ISP in a certain port and have it looped through another port. I'd start there.
Posted on Oct 04, 2010
SOURCE: I run 3 computers connected to the internet using
Hi, I would recommend downloading the latest firmware for this device and then se if your "crashing" goes away.
If you plug directly into the cox modem do you have problems?
If that doesn't work I would replace the Cat 5e network cable from the switch to the cox modem.
If that doesn't work replace the coax cable from the cox modem.
If you continue to have issues replace the switch.
Posted on Feb 28, 2011
How do i connect two computers so they both have the same ip address i have a linksys 5-port workgroup switch will that work ? also i had hooked it up but only one of my computers had internet
They cannot have the same IP address due to the mechanics of DHCP. Buying a cheap 50$ router (not switch) will fix your problem as your internet service provider will see that device as a single unit that it will assign an IP and then the router will give out internal ip addresses so that they can get online. The switch does not have this functionality.
Feb 16, 2011 | Linksys EZXS55W EtherFast 10/100 5-Port...
I want to add a LINKSYS workgroup switch EZXS55W behind my wireless routher LINKSYS BEFW11S4 v2 via uplink cable connection. When hardwiring my anything to the switch port 1-4 does not get internet access
Are those 4 ports in different Vlan ?
If you connect your wireless access point to the 1st port are you able to access the internet through 2nd port or 3rd port ?
Are the ports 1-4 admin down ?
Dec 23, 2010 | Linksys Bundle: BEFW11S4 802.11b Wireless...
Xbox and laptop cant connect at the same time
your ethernet cable from comcast gets plugged into the wan port of the linksys switch. plug the xbox and laptop to one of the lan ports. the comcast box is a modem/router? without the router it won't assign dhcp addresses
Aug 19, 2017 | Linksys EtherFast EZXS55W 5x10/100 Mbps...
I'm having problems with my Linksys ezxs55w switcher. The plugs are not lined up with the correct lights. For example, I plug the uplink into the uplink plug, but it shows up as number 5. Same with other...
You have a 5-port router. The 5th port can be used either as an "uplink" port (with a cross-over Ethernet cable) or as a "data" port (with a straight-though Ethernet cable).
You've not provided enough details to trouble-shoot the "staying online" problem, i.e., IP-addresses of each of the connected computers/printers, whether you're using CAT3 or CAT5 or CAT5E cables, whether you've tried different Ethernet cables, and whether the router is connected into a UPS that provides "smooth" power.
Dec 27, 2009 | Linksys EtherFast EZXS55W 5x10/100 Mbps...
I have my internet through my cable company and i want two com hooked up but are not going to have them online at the same time so can i use the 10/100 5-port model#EZXs55w by using the line coming out of...
Hello Friend
You could definately use Network Switch-10/100 5-port model#EZXs55w to Connect to Network Router or Modem using Uplink Port at back Panel of 10/100 5-port model#EZXs55w Switch.
Simply Connect Modem cable to Uplink Port of Switch and connect computers to other 2 ports of switch. Allow computers to get Automatic ip addresses..if computers still not getting ip addresses auto--contact cable company and config your cable modem to use NAT or enable NAT--
Oct 10, 2009 | Computers & Internet
Linksys switch question
You certainly can. In a real network you have one router and x amount of switches or hubs. Because whats going to happen is your equipment will automatically will ask the switch which will bounce to the router and your router will issue the address to that device.
Jul 20, 2009 | Linksys EtherFast EZXS55W 5x10/100 Mbps...
Can't get two computes to run internet at the same time
If you login to your router and make sure DCHP is enabled, and then go to Services (services.msc) on your computers and make sure that the DCHP Client is running, it'll automatically assign IP addresses for your computers and they'll both connect okay.
Hope this helps
Chris (ziraffa)
Jan 17, 2009 | Linksys EtherFast 10/100 5-Port Auto...
2nd controller on xbox not working
no big deal u have to snc the controller with 360 there will be a white button on the back of the controller click it and on the front of the 360 the same btton will be there and there u go it might not work the 1st time but it will work
Dec 14, 2008 | Microsoft Xbox 360 Console
Xbox 360 to Linksys wireless modem...
OK I think the easiest way to connect the xbox to the linksys, is if you configure your XBOX to have a static IP address, because the xbox will not have to pick an IP address every time you connect to the internet using the Linksys router and will not have conflicts with other PCs on your house, if you have any. What the linksys does is to convert your Public IP addres into a Private IP address, so example if your ISP gave you an IP address of: 209.235.205.30 that is your IP address for you, then the Linksys converts that number (NAT) into a private IP address so it can be share with many computer inside your house using a single Public IP address. The Linksys always transform it into 192.168.1.?=any number between 1-256 thats the defaults IP address from the manufacturer but you can change it if you want. Ok enough info about NAT or IP jeje.
Where going to use the default IP addres for an easier setup.
First: On your XBOX 360 dashboard go to SYSTEM, then Network Settings, then Edit Settings, then choose the option manual, here put the IP address= 192.168.1.33 (if 33 doesn't work use another numer like 20 or 45 just pick a number between 2 and 250) ; Subnet Mask = 255.255.255.0 ; Gateway = 192.168.1.1; DNS options put Automatic. And see if it connects. If it doesn't work just post it here, any problem that you have.
Aug 22, 2008 | Microsoft Xbox 360 Console
Computers & Internet Logo
90 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
