Question about Carrier 38BRC060 Air Conditioner
Compressor not doing much
We have a carrier 38brc060 and the outside compressor isn't doing much. The fan inside does notspin. We hear like it it trying to do something but it is not. Is this something that we can do on our own?
Hi. I have 38brc060 outdoor and air handler, today the compressor gave out according to the technician and I need to replace it. How much is a compressor for my carrier system? Its a 2 ton unit that was installed in 2000. I am also trying to figure out if there is a warranty for this...
Thanks in advance...
Posted on Sep 01, 2008
I am assuming that you are talking about a central ac unit. On a central air unit the outside fan must be running whenever the compressor is. If it's not the compressor will shut off from overheating withing minutes. First you need to shut off the unit for several hours and let it cool completely down. Then turn it on briefly to see if the compressor starts and see if the fan tries to start.( I am assuming the compressor starts and runs.) If the fan won't start try testing the capacitors. There are usually two one for the fan one for the compressor. Sometimes there will be one combo one. Mark the wires and remove the capacitor. Get it tested and if bad replace it. This will probably do the job. If not test for current at the fan motor. Also test to see if it turns freely. The motor may need to be replaced. This will run about $50. The capacitor should always be replaced when the motor is changed anyway.
Posted on Jul 09, 2008
Indoor fan contactor pulls in but both compressor and condenser fan contactors wont pull in ?
You either have a problem with the wiring/fuses/ breakers/worn contactor. If someone goes inside and sets the stat to cooling you outside should hear a click and maybe a small hum. If this is what you find the power feeding the condensor is tripped or fuses are blown.
Apr 25, 2011 | Carrier Heating & Cooling
The fan on my carrier a/c model 38brc060360 does not move when the compressor kicks on. it will start of i give it a small push
That is probably just a bad capacitor...that is what gives it the kick to get it going...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 17, 2010 | Carrier 38BRC060 Air Conditioner
Ac unit clicks outside but nothing engages fan or compressor on unit furnace still runs for heat setting and fan still blows but ac will not engage just hear a clicking was running for three days this...
Have you check the outside breaker? If its ok then you got a problem in your electrical system inside the unit probably the contactor is not engaging this is where the 24 volts from the thermostat calls for the 240 volts to run the condenser fan and compressor. Be careful checking this out because of the high voltage.
Jul 09, 2010 | Carrier 38CKC048 Air Conditioner
Very hot outside. blower comes on but outside fan
Check the voltage source for the fan and compressor
Check the start capacitor for the compressor.If its over heating :bad compressor
Jul 05, 2009 | Carrier 38BRC036 Air Conditioner
Compressor fan and compressor not running new 2 yr old system puron
No power to outside unit. Check to see if contactor on outside unit is pulled in. Most AC units inside have float switch. When the drain stops up it shuts off outside unit. Located in overflow or underneath unit. No Problem Rusty
Jun 05, 2009 | Carrier 38CKC036 Air Conditioner
Carrier central ac high efficiency
usually capacitor,burnt wires or bad compressor.kill the power and check the terminals at the compressor.they have been known to burn off if the connection is loose.
Sep 06, 2008 | Carrier 38CKC042 Air Conditioner
I have a carrier infinity system. On the thermostat it reads "sens error" where the outdoor temp is normally displayed. The inside unit is running but the outside unit is not. Any suggestions?
A burned or pitted contactor will/can cause a unit to not run. Outside fan. Just thinking out loud. Start with low voltage check at t.stat then check outside low volt. Set t.stat to on. If fan engages at least your transformer is good. Next set calling for cool. Drop t.stat 68-70. If nothing happens go outside and with a screwdriver depress the contactor in. If fan and compressor kicks in change the contactor. If contactor is pulled in check outside fan. Remove the wires from the compressor and see if the fan will run . If it does you have eliminated start components as good. The compressor has to be check. It needs to be ohmed out. Turn off power at disconnect. Pull the cover on the compressor. Check between pins; then pins to ground. Open or infinite is good.Have you checked fuses. Like small 3-5 amp fuses
Jul 03, 2008 | Carrier Heating & Cooling
Carrier 38BRC060 Air Conditioner Logo
450 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
