ACER PD113 DLP PROJECTOR I have Replace a New Bulb to my projector, When I Turn On it get fine and it projects the Visual But After 10 Minutes it get turn off automatically, and it glows the LAMP INDICATION. I have checkek Several time the Placement of the Bulb all fine.... Is there any ting to update its Firmware or any thing else...?
  • 1 more comment
  • Denesh  Chakkaravarthy
    Denesh Chakkaravarthy Jan 05, 2011
    As I have Cheked the Bulb, As the Bulb is bought from Acer, I have Reset the Counting Hours of the Lamp.
    As i Have rested it for several times, afer then only i have came to Fixya to get a correct solution.
    As the lamp had been replaced by the Authorized Service Center only. He says as the Lamp and projector are fine.
    After saying such answers in service centers i'm not wish to go there again.
    Waiting for a Correct and perfect solution.
    Denesh Chakkaravarthy Jan 07, 2011
    Thanks for your good solution to my problem.
  • 13,433 Answers
It is possible that the projector is overheating, if the dust filters have not been cleaned clean them out and make sure the air can flow easyly in and out from the projector.
here is a list of error conditions, find yours from the list and identify what is happening:
Posted on Jan 06, 2011
    President:
  • 1,139 Answers
Hi there, what you may need to do with this projector is reset the lamp hours timer. Sometimes on certain projectors if the lamp hours timer went above a certain amount the machine will not work fully until this is reset. It is an option within the menu that you can access yourself. Once this is reset I am sure that it will work again properly.
Hope this helps and thank you for using FixYa
Posted on Jan 05, 2011
    Guru:
  • 1,833 Answers
About your Projector problem
First check your bulb properly matched with your projector.
After changing the lamp reset the lamp hour (counting from 0hrs)
adjust the osd transparency.
This settings may solve your problem.
Posted on Jan 04, 2011
  • Aloke Das Jan 05, 2011
    Then there is some problem in the bulb prower supply. You have to visit a service centre to rectify this.
Can I project outdoors with an Acer PD113 ? and How big will the image be?
Not sure of the lumens or brightness of this model but in the dark it should be bright enough. Most projectors will do up to a 300" diagonal image.
Sep 01, 2014 | Office Equipment & Supplies
The Temperature light comes on after replacing bulb.
I am experiencing the exact same problem. hope someone comes on worn a solution. projector worked fine before replacement - all fans have been cleaned and are working properly. ..
Mar 31, 2014 | Mitsubishi HC3800 1080p Home Theater DLP...
Stars on screen of acer x1160pz
Sean ,the problem is not the bulb but is the digital micromirror device (DMD chip) is aging,that sends pixels directly to projected image.So you can replace it depending on the price you will compare.if expensive then buy a new Data Projector.
Apr 12, 2013 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
I replaced the bulb of an ACER PD116PD DLP Projector but it still does not work (no light), the manual does not tell anything about reset or any fuse replacement. I can I do?
Make sure you plugged the bulb in securely, and replaced the cover. If this is fine, you may have a faulty control board. I would contact Acer for warranty repairs, if it is still under warranty. Even if it isn't, I would still contact Acer to have them fix the problem. Here is their support site: http://support.acer.com/us/en/product/line.aspx?pid=2074
Mar 09, 2011 | Acer Projectors
When I plug in the projector to the mains and to the computer then start the projector followed by the computer, the projector projects the image of the windows start up screen but once windows has started...
Hi ;
  1. click right botton on your desktop
  2. choose Nvidea control pannel
  3. configure multiple displayer
  4. choose the second displayer projector and apply the change
Oct 19, 2010 | Acer PD113 Multimedia Projector
Projector shuts off
try reseting the lamp timer and then replace the lamp if it works
May 05, 2010 | Planar PR3010 DLP Projector
NEC LT265 Multimedia Projector will turn on, but does not fire up
the bulb needs to be resetted after fixed or the other problem is that the bulb is not fixed.or the ballast is faulty. check out all the options 1 by 1 in the given link how to replace the colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
how to replace the ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Mar 11, 2009 | NEC LT265 Multimedia Projector
Acer PD113 DLP Projector
If you can work an the micro level of troubleshooting, have access to the the necessary instrumentation and tools, have the proper surface mount soldering station, test jigs, and also be able to have the access to the factory diagnostics software, and required replacement parts, then I would say you can troubleshoot and service this module. The factory service centers replaces this module. They don't spend the time and cost to service it at the component level. I have serviced some types of projection screen systems. They are very complex, and are normally serviced at the modular level. After replacement of some types of modules, some factory adjustments are required to match the new module, or parts. In the end you will have to send the unit out for factory service.
Jan 24, 2006 | Acer PD113 Multimedia Projector
736 people viewed this question
k24674
