Question about Samsung LN-S4692D 46 in. LCD HDTV
Do i need a new power board?
Lightning storm took out my HDTV...clicking sound only when try to power on? Do i have to replace the PCB or can it be fixed at component level?
Insignia 37 inch....no sound after lightning storm and HDMI's are not working
Dude! You fried it! Sound board can be replaced, but what else was stressed? Replace it, use a good surge protector, and turn the thing off during storms, light a candle and cuddle with your sweetie.
Jul 15, 2014 | Insignia Televison & Video
Polaroid FLM-3701 power
Unfortunately modern televisions and monitors are full of electronic semiconductors of which many are likely have got destroyed along with your original power supply during the storm. A nearby lightning strike will send high voltage spikes down aerial cables as well as through socket outlets.
If you have contents insurance you should be able to claim for a new monitor.
Nov 09, 2013 | Polaroid FLM-3701 Television
Vizio M420nv LCD TV Black Screen
lightning can do extensive damage to electronics equipment especially flat panel TV's. I would really recommend a professional diagnosis instead of board swapping. You could have several boards that are damaged!
Feb 13, 2013 | Vizio m420nv 42 in. LCD HDTV
Red light flashing
That problem is usually have 2 causes..Its either power supply board or main board..
Please take this steps on how to determine the problem:
1. Open the back cover.
2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..
3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..
4. If the power supply output is normal..The problem could be on the main board...
5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..
6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..
Hope this solution will be helpful..
Thanks for using fixya...
Jun 05, 2012 | LG 42LC2D 42 in. LCD HDTV
Green power light flashes 3 times then repeats
The defect is likely a sensitive component to over voltage (lightning) on the main power supply. But you should not exclude other boards too, since ohter board also have local power supplies and sensitive CMOS integrated circuits. Check all MOSFET transistors on the the main power supply, since they are the most sensitives. Also the regulator IC to control the PWM sent to the MOSFET is made of CMOS (sensitive). Then check all the diodes even if they are more robust to lightning. There is a MOV that absorb the lightning that could be shorted but in your case it seems to have survived.
Sep 21, 2017 | Toshiba 55ZV650U 55 in. LCD HDTV
MAY HAVE BEEN HIT BY LIGHTNING. BLACK SCREEN AND 2 COLORED LINES
Replace the deflection board. Sounds like the vertical deflection was knocked out thats why you still have sound. You can get replacement deflection boards from www.tvrepairworld.com
Aug 02, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Samsung LN-S4692D 46 in. LCD HDTV Logo
93 people viewed this question
Henry  Thomas
Henry Thomas
