I have a Wirpool washer. It make sloud noise during spining. I remembered it happened few years ago. A serviceman just tight a screw on the agitator or somewhere-anyway it's simple. Please advice which screw it could be? Thanks.
  • 91 Answers
The top of the agitator take off the cap and there should be a platic piece you also pry off to get to it just tighten the bolt.
Posted on Jan 02, 2011
During wash cycle the agitator only goes one way instead of left / right. all washing ends up wrapped round the agitator.
first thing to check would be the agitator dogs on the agitator here is a video on how to replace the agitator dogs in a top load washer click here http://www.youtube.com/user/RepairClinic?v=0GQh8JLqVv8&feature=pyv&ad=5457341621&kw=agitator usually if the agitator is only spining in one direction this would be what you would have to replace if you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to continue helping others in similar situations in the future Thanks
Rick
Jun 04, 2011 | Washing Machines
I have a washer machine wirpool and dasnt change to the cicle spine
If your timer goes normally until it hits the spin cycle then it is your clutch on your motor. If your timer stops during a cycle then it is timer. Either way this problem should be able to fix around $150 to $200 depending on labor costs.
Apr 15, 2011 | Washing Machines
Washer makes loud grinding noise during agitation and does not agitate - it is a maytag atlantis.... fix or replace?
I suspect the thrust bearing kit is bad. This comes with great instructions and is easily replaced. I would recommend changing this before replacing the machine. You are not out much if it does not work, but I am confident you will get it going by replacing this! This is a VERY common problem with these washers and the new kit has been redesigned.
Kelly
Mar 21, 2011 | Maytag Atlantis MAV9750A Top Load Washer
I have a 2 y/o Maytag Bravos MVWB700VQ0 top-loading washer that is suddenly making noise like there's either a) a chain loose in the drum of the machine, or b) a coin or other metal object is bouncing...
it is probably money in the pump. I have had my washer for two years now and an on the second pump. I had to call a serviceman to take the pump loose and dump out the change. It had 81 cents the first time and 26 cents the second. I need to call him again but I think I am going to try to do it myself. $85 a service call is just ridiculous when I know what the problem is.
Oct 12, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
Agitates but won't spin
either bad clutch / brake or bad transmission
Jul 19, 2010 | Whirlpool GCAM2792LQ Top Load Washer
AAV7000AWW washer
sounds like the thrust bearing is worn causing an imbalance on the shaft. check herehttp://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=AAV7000AWW&mfgModelNum=&fkMfgID=1:- for a schematic on this machine and parts as listed.. hope this is of some help
Oct 22, 2008 | Admiral AAV7000A
During agitation it sounds like it is slipping and grinding
It could be a number of issues really.  Smaller issues could be something under the agitator, etc, to moderate problems, like a motor coupler, loose basket, etc.  Could also be a major problem like a motor or transmission.  A lot of times its the motor coupler or pump making the noise.  Both are pretty easy to replace.  Maybe some more information.  Do you happen to know where the noise is coming from?  Is it coming from the front of the cabinet or in the basket area?  Any small water leaks?  Does the spin cycle work ok?  Let me know some other information and maybe we can narrow down the problem to one particuliar area.   Jim
Oct 17, 2007 | Kenmore 24032\24036 Top Load Washer
Agitator fall off and knocking noise during spin cycle
there should be a rubber washer with the bolt. if it is missing the bolt may back of during agitation. also the threads on the transimision may be stripped. Some Green lock tight found in most hard ware stores should help. the knocking noise is probably due the agitator coming loose.
Sep 16, 2007 | Maytag PAV2300 Top Load Washer
Washer make a clicking noise
Zoobs, you could have something stuck under the agitator. The agitator will pull straight off. Grip it on each side and pull up hard, but don't hit yourself in the face. If that don't work, try slipping a belt under it and pull. Check for something caught under it. Another possibility could be the nylon suspension rod socket supports in the back. They will make a noise during agitation if they are dry. Put a little 3 in 1 oil to quite them down. Take the front panel off and check the pulley and belt, see if anything is out of whack. I also often find the motor support hitting the bottom panel during agitation making noise. Take the front panel off and observe during agitation. See if the support is striking the bottom. If so, just bend the bottom panel down. Catriver..post back.
Nov 30, 2006 | GE WHSE5240D ENERGY STAR Super Plus 3.2...
Kenmore top loader washer noisey agitator
it sounds like the gear dogs in the agitator. pop he top of agitator and check. its a easy repair.
Aug 28, 2006 | Kenmore 22422 Top Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
