Question about Ariston Technologies Washing Machines
Ariston AVL95 will not drain water and door is locked.
4 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: my ariston washing machine door not locking
I recommend replacing the door latch. It is a fairly common problem. You can get one at repairclinic.com or partselect.com
Posted on Jan 02, 2010
  • 160 Answers
SOURCE: I have an ariston A1437 washing machine and when
Fault is a motor one...Motor jammed / tacho detached: check motor & module connections for loose or broken wire..
Posted on Jan 04, 2010
  • 6277 Answers
SOURCE: Ariston AVL95 washing machine--Will not do the
This sounds very much like the belt is slipping. Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person.
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If it turns out to be the motor, it is false economy to just have the brushes changed. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished.
Now- to drain the water out you could follow the relevant parts of my (generic/standard) notes-
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope this is your problem solved.
Good luck,
John C
Posted on Feb 16, 2011
Door locked,cant open
just get an old door from any ariston..hotpoint or indersit machine make sure it is the same size
Jan 12, 2014 | Ariston Technologies Ariston AWD12 Front...
Ariston AVL95 washing machine--Will not do the spin cycles just has 2 flashing buttons (superwash &900-500). Intially we could re start it and it would finish the cycle. However now it has a burning...
Good luck,
John C
Feb 16, 2011 | Hotpoint Ariston AW125 Front Load Washer
Door won't open
if you can still see water in the machine, check the drain hose. If there is no blockage or kink, try to drain machine by lowering the drain hose below the machine level. Once the water is gone, door lock should release.
Mar 28, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
My ariston washing machine door not locking
Jan 02, 2010 | Ariston Technologies AWD121WH
Moved the machine, put in the locking bolts , when i did the first load it stopped after the first cycle ...now its full of water and washing and i cant open the door?
Try laying the drain hose down to floor level, and let the water drain out into a bucket or similar.
You should then be able to open the door.
If you can't, then it will have to be released from inside the washer, this means removing the top cover to gain access to the door lock.
Hope this helps..
Dec 13, 2009 | Ariston Technologies AW 149 NA
Hotpoint Aquarius waher dryer
possible blockage ' filter or could aslo be water coming back from the sink if drain hose too low , you may need to raise this....
Nov 13, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Ariston 121 door won't open
Sounds like broken door ******/ or pin securing the door kit has moved as happens on aristons.....Make sure all water is drained first..Good luck
Sep 29, 2009 | Ariston Technologies AWD 121
How do you drain the Ariston GL4
is there a pet **** on the bottom under a plastic cap? you might have to take the cover off and I would recomend putting some boiler drains in the line for future draining,, all units of water heaters have drains and looking at the picture I see something sticking down on the bottom see if thats not the drain
Jun 09, 2009 | Bosch Ariston GL4 GL4 Point-of-Use...
Door Stuck after wash completed
You will have remove top cover, and release door latch from inside the front, with a screw driver pushing against the latch to open door.
It does mean that you probably have a faulty door lock, or broken door handle.
Please rate my fixya solution.
Thanks
Jan 11, 2009 | Ariston Technologies Ariston AWD12 Front...
Washing Machines Logo
115 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
