Question about Vacuums
The upper two elements do not work and I was wondering if they should be replaced or if I should just get a new oven. If the parts are replaceable, where would I get them or is there a place near Brampton Ontario I can get it fixed?
  • Arno Ilic Jan 02, 2011
    I have spent considerable time looking on the internet for parts for this oven. I didn't think it would be that hard. Someone else was willing to provide a solution for $27.00. Already having paid $6.00 and $12.00 on this website, just finding the information is already starting to add up to more than the cost of this oven. Any other suggestions?
    Yes it is a small one (Bravetti TO241B).
    It sounds like I should prbably trash it.
    Thanks
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Jan 02, 2011
  • D. Floyd Kolb
    D. Floyd Kolb Jan 02, 2011
    What is the make and model of the oven???? Is it a toaster oven or a regular rannge type oven....
    If it is the small type then yes.. trash it and buy new... you will not find parts for that...
  • D. Floyd Kolb
    Even if you can find the parts... they will be too costly versus the price of a new one...
UNEVEN AND OVERHEATING ELECTROLUX OVEN
Can you be more concise? Baking and broiling? upper and lower element if electric? model? age?
Apr 01, 2014 | Electrolux Vacuums
Part where belt attaches to is missing
The belt goes around the brush roll and around the shaft sticking out of the motor. If one of those two items is missing it must be replaced
Jan 25, 2014 | Electrolux Vacuums
I have a vintage GE coffee perculator made in the 1930's and 1940's Cat No. 119P102 which I bought from an antinque store in Chicago 2 months ago. It has worked beautifully until yesterday morning...
The first problem is the time you will use a product of the very old time , and ask you not wonder what it mains happened in the interval between 1930 and 2016 maybe its not only the changeof 110V to 120 volts it is not much difference but far enough to worry and what the effect is on the heat dissipation of the heating element inside (the coffee must be too hot 90 and 95 degrees are normal all the cables and more parts of Should Be Replaced if it was not modifiedin all Those years, it Should Be modified, and it was modified there must be for shure a big wire resistor be Placed in serial to release to the high aC power on the heating element. and maybe many more parts. gaskets cables and more must Be Replaced iif not safety for all. preventinfo and usefull to a hot Become bitter tasting coffee temperature.
Sep 25, 2011 | GE Vacuums
Delonghi toaster elements are losing their heat
There are three likely problems:
1. The toaster and/or heater elements need to be cleaned. If they get coated with food material they will not function correctly.
2. The heater element could just be going bad. You would need to search the web with your model number to find the appropriate replacement part then open up the unit sufficiently to disconnect the old elements and replace the new elements. You need to ensure that the connections are correct because loose connections would not permit sufficient electricity to enable the elements to heat up.
3. The thermostat could be going or gone. This controls the amount of power provided to the elements and thus determines how much they heat up. Again, you would need to search for replacement part.
Aug 11, 2011 | Vacuums
Brand new electrolux range oven wont work, all that shows on display is F15
F15 means : signal lost between oven relay board & EOC(main computer board)
1. Test the harness and connections from EOC connector P16 to oven relay board J2.
2. Replace the oven relay board.
3. Replace the EOC.1. Test the harness and connections from EOC connector P16 to oven relay board J2.
3. Replace the EOC.
Hope this help. good luck to you.
Feb 07, 2011 | Vacuums
Need replacement part for PIZZA baker mod: PS75891, it is a thermo switch No.E211649. this is counter top pizza oven
I don't see any parts available for this, most parts are propriotory and can't be purchased seperatly. I checked online and this is selling for around $60.00 new and it seems that this oven has been discontinued. If you know what part it is you might be able to match it up at a local electrical supply or appliance repair. I have no idea what a new switch would cost but at $60.00 replacement of the oven might be a better choice.
Dec 23, 2010 | Vacuums
Power Unit VX475 Stops Working
The problem is definetly the motor. make sure the filter is not covered in the hair, if not you need a new motor. i fixed plenty of them.
Jan 31, 2009 | Broan-NuTone VX475 Bagged Central System...
Hoover Savvy wand holder upper how to replace it
if you look at the bottom of the holder on the inside you will see a tab just take a small pocket screwdriver and pull out on the tab it should come off.the new one will just snap in
Jan 26, 2009 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Vacuums Logo
43 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
