Question about Dyson Vacuums
My Dyson DC 25 Animal will not stand back upright. Can you help?
  • 389 Answers
SOURCE: Reset Button on my Dyson DC 25 Animal
What do you want to reset? Do you mean the motor has stopped working? There is no "reset button". The motor has an automatic cut-out, which will operate if the motor gets too hot and will reset itself when it cools. If the motor will not work when it's cool, then you have an electrical problem which will probably need professional attention.
Posted on Apr 09, 2009
SOURCE: My dyson 25 animal won't go back into the stand up
I unscrewed the side panel (left side looking from rear of vac), it is gray and shaped a bit like a "C" or elbow joint and that let me get to the metal bar in the red foot pedal. I needed to move the metal bar so that it would slide along the grove in the gray side pieces above the wheels. I just needed an allen wrench and it was easy from there! I don't know if this helps anyone else, but it worked great for me!! Good Luck.
Posted on Aug 31, 2009
  • 4 Answers
SOURCE: Dyson DC 18 Model won't stand upright on it's own
There is a flip lever that locks it in place and redirects the airflow to the hose when you put it in the upright position. It binds, then eventually breaks. I'm not having much luck finding replacement parts to fix mine.
Posted on Dec 02, 2009
Dysonteam
  • 167 Answers
SOURCE: My Dyson Ball DC25 Animal will not stand upright?
Hi its Darran at Dyson.
Its possible that the stabiliser pedal has popped out of place. For help on how to resolve this, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Posted on Apr 19, 2010
VacuumRepair
  • 438 Answers
SOURCE: Dyson animal is giving me fits
Try this quick repair and see if this fixes your Dyson in terms of not going in the upright position: This is a frequent problem that we see come in on Dysons. If this doesn't fix it, please feel free to just use the clarification request and let me know this didn't fix it. The suction problem is happening because when the machine is put in the upright position it diverts the suction from the floor to the hose automatically, and it's probably stuck in between the lower part and the hose part.
Step 1.
Turn power off and unplug the machine.
Tilt the machine backward to a 45° angle.
Step 2.
  • Hold the section under the airway inspection pipe.
  • The black forward lock button must be held down simultaneously, otherwise the valve carriage will not move.
  • Pivot this section upwards until it clicks into place.
  • Release the black button once the valve pipe carriage is moved up into place.
    Step 3.
    • Tilt the machine forward.
    • The cleaner head should now slide underneath the part you have just clicked into place.
    • The machine should now stand upright.
    In terms of the machine not picking up, this could be caused by a few things.
    The first thing you should check is the filter. The DC14 has a motor filter that is recommended to be washed every 90 days. Here's how to access this filter:
    • To remove the washable filter: Remove the clear bin; and cyclone top from your machine by pressing the cyclone release button.
    • Lift clip to remove the filter from the machine.*
    *The post-motor filter located under the clear bin should last the lifetime of the machine and does not need to be washed.
    There are two different types of filters that were used on the Dyson DC14, and One part filter, and a two part filter. Here's instructions on how to clean both of them:
    ONE PART FILTER:
    • Wash the filter in cold water only. (Please do not use detergent, do not wash in a dishwasher or washing machine).
    • Repeat the steps shown below until the water runs clear.
    • Leave to dry in a warm place for 24 hours. DO NOT dry the filter inside a clothing dryer, hair dryer, microwave the filter, place the filter in an oven, or near a naked flame.
    • Please ensure the filter and filter case are completely dry before refitting into the machine.
    1_part_filter_drying.jpg TWO PART FILTER:
    • Wash the filter in cold water only. Please DO NOT use detergent on the filter, or wash the filter in a dishwasher or in a washing machine.
    • Leave the filter to dry in a warm place for 12 hours, until completely dry.
    • DO NOT dry the filter inside a clothing dryer, hair dryer, microwave the filter, place the filter in an oven, or near a naked flame.
    The filter should be washed at least once every 6 months.
    Also, since you have removed the bottom plate, a common problem on the Dyson's is when this plate is reinstalled. It is very easy to put the plate on incorrectly, which prevents the brushes from hitting the carpeting. This can seriously decrease the pick up on carpets. Check the bottom plate to make sure that it was put back on properly. Here's pictures of both the correct, and incorrect way to reinstall the bottom plate:
    Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
    Here's another picture, that is the RIGHT way to install the soleplate:
    I would say probably 6 times out of 10 this is the problem with the customers machine. If you checked the soleplate and it is installed correctly, move on to the second possible problem.
    I hope that this was helpful to you. Please feel free to use the Clarification Request form here on Fixya if you have any questions.
    Thank you,
    Chris J.
    GoVacuum.com
    Posted on May 01, 2010
    Dyson dc25 will not stand up
    Hi there, it's Jack at Dyson.
    If your DC25 won't stand upright, it's likely that the stabiliser pedal needs to be realigned. This is simple to do by following the steps shown in our video guide:
    I'm confident this will resolve the issue, but if you'd like further help or advice you're welcome to call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
    Feb 15, 2015 | Dyson Dc 25 Animal Upright Bagless Vacuum...
    My dyson dc 25 sparks near the rotator roller attachment, what can I do?
    Hi Cindy, it's Jack at Dyson.
    If you can see sparking coming from inside the cleaner head, please do not continue to use your machine until we can help resolve this. It's likely the cleaner head will need to be replaced - once we've taken a few further details, we'll be able to confirm if this is covered under your Dyson parts and labour guarantee.
    At your earliest convenience, please call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU) for further assistance.
    Dec 16, 2014 | Dyson Dc 25 Animal Upright Bagless Vacuum...
    When I tilt my Dyson DC 17 Animal upright so that I can use the hose, the vacuum powers off. As soon as I tilt it back down, it turns back on.
    I'm sorry to hear you're having difficulties with your DC17. When you stand the cleaner upright, the brushbar motor is designed to shut off automatically. However, the suction motor should continue to run unless you turn it off manually with the on/off switch. If both motors seem to be shutting off when you stand the cleaner upright, it's probably best if you get in touch with us directly so we can resolve this issue for you as quickly as possible.
    You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact as soon as possible.
    Kind regards,
    Jack
    Dyson Online Customer Support
    Jun 30, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
    Dyson wont staND UPRIGHT
    So that we can help resolve this, please call our Helpline on 0800 298 0298. One of our advisors can through some simple checks with you which will hopefully resolve the problem.
    We look forward to hearing from you.
    Kind regards
    Darran
    Mar 10, 2010 | Dyson DC25 All Floors Bagless Upright...
    The brush bar wont spin on my dyson dc 25... i
    Simply switch the machine off and stand it upright. Press the brush bar on/off switch once and then turn the machine back on.
    When you release the machine into the vacuuming position, the brush bar should start to turn again.
    If you still having problems, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
    Kind regards
    Darran
    Jan 08, 2010 | Dyson Ball HEPA Upright Bagless Vacuum -...
    Won't stand upright again
    My Dyson DC 25 animal had this problem earlier today, all of a sudden it wouldn't go back into it's upright position. I looked on the bottom and the red pedal has two metal pegs which are supposed to be in a hook shaped track. one peg had slipped into a hole outside of the track (leaving a little scratch indicating the path it had taken), and all I had to do was wrestle it out of that hole and back in place.
    Sep 04, 2009 | Dyson DC25 Vacuum
    Vacuums Logo
    42 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
