Question about Honeywell Heating & Cooling
I need help identifying a honeywell three way valve which is leaking. The actuator is a honeywell VC4012-34 but the valve itself has no part number I can see.
3 Suggested Answers
  • 5 Answers
SOURCE: he220a honeywell humidifier water actuator valve broke
Hello I had the same pbm, I could not find it anywhere other than ordering it through the net. You will find info & picture at http://images.google.com/images?hl=en&q=Solenoid++valve&um=1&ie=UTF-8&sa=X&oi=image_result_group&resnum=4&ct=title
For a humidifier issue, you do not need the same exact original part, it is best of course but another brand will work.
Posted on Dec 25, 2008
  • 22 Answers
SOURCE: Water inlet valve appears to
240531101
Posted on Mar 07, 2011
Tip
Honeywell V8034F1036 Zone Valve
The Honeywell V8043F1036 zone valve is a simple two way on-off low voltage valve that consists of two parts. There is an actuator that has a motor and an end switch, and then there is the valve assembly that controls the flow of the water.
The valve assembly is normally a straight through design that is built in such a way so that the valve can be installed without disassembly. The simple ball design is such that the ball is suspended inside the valve without touch any metal in the fully open position. This allows the valve to be soldered in the piping fully assembled. Each time the valve is opened and closed the ball is turned slightly which keeps dirt from building up at one spot and creating a leak. This also allows for even wear on all surfaces and therefore this valve virtually does not ever wear out from use.
The actuator contains a small 24v synchronous motor to open the valve and hold it open as long as power is supplied to the motor. When power is turned off the spring loaded return pulls the valve back shut. The power to the motor can be control through any low voltage thermostat. Power consumption is only 7.7va so up to 6 valves can be controlled from one 40va transformer. The actuator also has a manual open feature that allows you to manually open the valve in the event of a power failure. The valve will then return to normal operation when the power is restored.
In the event of an actuator failure the motor or the whole actuator can be replaced without removing the valve or draining the system. The replacement process is very easy and can be performed in a matter of minutes. The process only requires the loosening of two screws and the change over of the wiring.
The V8043F1036 Honeywell zone valve is one of the most common zone valves installed on many hydronic hot water heating systems. This zone valve has been a rock solid staple in the heating industry for many years.
There are some failures in these valves after years of use. The most common things that go wrong are the failure of the motor and the wearing out of the gears inside to the point where they skip and do not open the valve. The end switch will give problems on rare occasions.
Overall after installing hundreds of these valves I rate them as one of the best zone valves on the market. They are easy to install and service. Considering the wear and tear that a zone valve receives the total number of failures seen with these valves is very minimal
http://www.fixya.com/support/r3901905-honeywell_v8043e_v8043f_zone_valve
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
on Jan 16, 2010 | Heating & Cooling
Tip
Honeywell v8043e1012 Zone Valve
The V8043E1012 Honeywell zone valve is one of the most common zone valves installed on many hydronic hot water heating systems. This zone valve has been a rock solid staple in the heating industry for many years.
It is a simple two way on-off low voltage valve that consists of two parts. There is an actuator that has a motor and an end switch, and then there is the valve assembly that controls the flow of the water.
Overall after installing hundreds of these valves I rate them as one of the best zone valves on the market. They are easy to install and service. Considering the wear and tear that a zone valve receives the total number of failures seen with these valves is very minimal.
on Jan 15, 2010 | Heating & Cooling
Hansgrohe shower valve leaks
If the shower drips constantly after you turn it off you will need a volume control cartridge of some sort. Without being abe to properly identify your valve I do not know what type of cartridge you will need. Feel free to contact me at Hansgrohe Tech. 1-800-334-0455 press 2 for tech and ask for David Scarborough. I can help identify the valve and if it is ours I can get you the part numbers you will need to make repairs.
Jan 20, 2013 | Home
Led status 3 trouble shooting advice
More information is needed.
Water heater is not identified.
Add a comment with more information from label on side of tank.
If you have gas water heater, then open following links to identify gas valve, and download error code diagnostic and possible service manual:
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
For power vent water heater with Honeywell gas valve: three flashes indicate pressure switch or blower temperature switch not working.
Typical causes appear on page 13 on manual: can be bad blower, bad switch, blocked vent, exhaust temperature too high.
http://waterheatertimer.org/pdf/Icon-gas-valve-error-codes.pdf
Sep 24, 2011 | General Electric Water Heaters
Replace Reliance Water Heater Gas Control Valve
there are no instructions for doing this.
how do you know it needs replacing? its rare that they need to be replaced.
I can help you, but need to know what is going on with the unit first
Apr 17, 2010 | Reliance & LP Gas Water Heater Control
We have got honeywell em150 motor operated actuator. however its wiring diagram is missing. can you provide the same
I searched all over the Honeywell website and was unable to locate any information on a Honeywell EM150. Perhaps there is another number on the part? I'm including their Customer Support number in this message. They should be able to help you identify the part number and help you locate a wiring diagram through their technical support department.
For further questions, contact Honeywell Customer Care at 1-877-271-8620
https://yourhome.honeywell.com/home/Applications/ContactUs.aspx
Mar 06, 2010 | Heating & Cooling
He220a honeywell humidifier water actuator valve broke
The screw does turn and will open the valve, take the hex nut off and turn the screw to see if water leaks between the valve portion and the hexnut housing. They used that same valve on many models, including the newer models. Make sure you are getting water to the valve.
Nov 26, 2008 | Honeywell HE220A1019 Whole House...
Heating & Cooling Logo
113 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
