Question about Viking Dishwashers
It is filled with water ,I presume the drain is cloged . Is there anything short of calling a plumber? Phil jjcobb @ sbcglobal.net
  • 4,323 Answers
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Hope this helps... Please post back for any further assistance.
Daniel
Posted on Jan 02, 2011
Asko 13th is filling up with water and food will not start cycle help
I am guessing that the cereal has expanded and is blocking the drain below the dish washer hose outlet
use drain cleaner or call a plumber
if the dishwasher hose is above the sink "S" bend remove the bend and clean it out
call a plumber
Jul 12, 2016 | Asko Dishwashers
Amana refrigerator model TX18QW excessive moisture , bottom of refrigerator fills up with water
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref.
If this was helpfu please VOTE FOR ME.
IMUFO2
Leo Ponder
imufo2@sbcglobal.net
Jul 26, 2011 | Amana Refrigerators
Hi My toilet back up so I plunged it ,water went down, then once filled clean water bubbled in toilet, then nasty toilet water started coming in my bathtub which sits next to it. I have now plunged &...
If water is backing up into the tub then you have clog downstream from that bathroom group. If water backs up when you ran water in the rest of the house then you have a clogged sewer service. With either case the house drain and / or sewer drain will need to be snaked. Most of the time it will be the sewer drain.
Jan 18, 2011 | Plumb Pak 1-3/8 Bath Waste/Overflow Assy...
My mother has cancer so needs me to research her problem with her dishwasher. My mother's sink drain water is emptying into the dishwasher. It has to be manually removed since she does not cook much and...
Problems associated with water from the kitchen sink back filling into the dishwasher are caused by the drain line on the dishwasher not having a high end loop. In simple terms, the dishwasher line is too low and is providing a path for the water to flow in the wrong direction. Reposition the drain line so that it loops just above the sink drain. Then, anchor it to the wall so that it does not move. This will provide and air gap and creates just enough resistance to keep the sink water from entering the dishwasher. I have included a link to a webpage that illustrates what I am referring to:
http://homeimprovementteam.com/standing-water-in-dishwasher
If you have any further questions, please post back and let me know. I hope this helps you.
NOTE: If you are experiencing problems with the sink draining as well, then you may have a plumbing releated issue.
Nov 14, 2010 | Maytag Dishwashers
I have a samsung swf p8 that when you turn it on and select a cycle the water runs straight out the drain. Can anyone help?
Drain into fill pipe is lower than the water level in the machine
creating a syphon effect
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
Sep 09, 2010 | Washing Machines
It keeps filling up with water
be sure the drain is clear and that the unit is tilted slightly
backwards off level.
IMUFO2
Aug 31, 2010 | Whirlpool ACP092PR Air Conditioner
All of a sudden the airconditioner started filling up with water and the fan blades started spraying water out of where the air comes out. The unit is draining from the back.
Try cleaning out from under The evaporator (front) coils towards the back so the water can drain underneath the front coils towards the back
Make sure the unit is tilted a little towards the back
Clean drain hole in back too.
Aug 23, 2010 | Kenmore 75050 Wall/Window Air Conditioner
Water leaking from under the fridge
Check drain
This is a sympton of a defective refrigerator cold control (Thermostat) getting too cold and freezing drain
Also check temp of freezer should be below 10 degrees
Aug 07, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
As my washer tub fills with water it also empties to the drain.
must be new whirlpool,drain hose may too far down stand pipe pull up till about 8 inches is in drain ..is stand pipe 36 inches at least above floor?if not call plumber end of drain hose should never be lower than water level in tun also be sure there is air gape around hose to prevent siphoning ..this will usually occur after 1st drain and during rinse fill
May 05, 2008 | Washing Machines
Dishwashers Logo
130 people viewed this question
Top Viking Dishwashers Experts
bandman1967
bandman1967
Level 1 Expert
Mike
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
