Question about Honda Mmd 5000 Watt Electric Start Generator W/ Engine Ngk 6000HE
Have a EB5000X generator which has staring problems, aprx 8 yrs old and not used a great deal until hurricane Ike came thru here and it ran for several days with minimal down time. Afterwards I changed the oil (replaced with honda oil) and started it as usual every month for aprx 15 min run time. recently I had to change the fuel to fresh since it has been sitting for several months, always have StaBil fuel additive in my equip. ie lawn mowers motorcycles etc.that sit idle during the winter months. Now the problem is after replacing the fuel I had to clean the carb now it starts better but won't idle up when a load is in place.
    Sergeant:
  • 191 Answers
If I understand the problem correctly, it runs fine after you cleaned the carb, but the auto idle will not engage when you put a load on it. First if it has a switch to turn the auto idle off try that. if it does not rev up, then the magnetic controller is stuck. There is a magnetic coil which is connected to the throttle and this either pulls or releases the throttle when load is applied. My guess is that this is hung up a bit. Look for a small round coil with wires coming off it that is connected to the throttle assembly. You could also try tracing the wire from the auto idle switch backwards. This may just be stuck in the idle position by corrosion. especially if you live in a humid area or one near the ocean. gently try to work it a bit by hand (when the generator is not running) and try a bit of wd40 or the like.
Posted on Jan 02, 2011
  • ernestboger May 03, 2012
    My eb5000x is all good except the auto idle is inop. Worked 3 or 4 times while switching a drill on and off this year. It has power to the solinoid, 20 volts, when engaging the drill it slowly tapers the voltage down to about 13 volts. But never releases. When I unplug the solinoid it instantly goes to governed speed as it should on it's own. No binding linkage detected. Any thoughts? EB, Dallas Tx.
Hurricane names
Mitch (1998), Katrina (2005), Wilma (2005), Ike (2008), Gustav (2008), Irene (2011), Jova (2011), Matthew (2016), Hermine (2016), Otto (2016), Irma (2017)
Sep 13, 2017 | Miscellaneous
Generator is two yrs old only had a couple of outages maybe totaling thirty hrs Generator ran great and also ran every wk for its exerciser cycle. The generator didn't start on this cycle and the system...
Is this a natural gas fueled generator? Sounds like a fuel problem, i would go through the fuel system and find out whats wrong. If its a natural gas/propane unit its most likely a bad regulator or low pressure.
May 04, 2017 | Eaton Electrical Supplies
My freezer not getting cold. it is about 10 yrs old and after Hurricane Ike it stop freezing.
if the fan run and does not freeze, possible compressor or compressor start kit. Start kits that a beating in stormy weather. Start kits consist of a relay, capicator and overload sensor. These 3 parts can be ordered seperately or a generic start kit with all the of these made in one. if the compressor is bad on a 10 year old freezer you might want to look at a new freezer
Feb 28, 2010 | Kenmore 65802
I need the setting for my coleman power generator 10hp tecumseh
If you have fire coming out of the carb, then your intake valve is stuck open. Take the head off, and as you turn the engine, tap on the valve with a plastic screwdriver handle to make it go in, then turn it more to push it back out. If you need to put a light coating of oil on it, so be it. Keep doing this until it's freed up, then put it back together.
Jun 08, 2009 | Coleman Powermate Powermate 5000W...
My Guardian 16KW
I have never heard that generators need to be perfectly level to prevent generator damage. It doesn't compute -- auto generators/alternators run at all sorts of angles -- so do motors. And for the damage to occur in 2 hours running doesn't sound right either.
It does sound like the generator itself is not working/generating properly, but I doubt it was caused by the slab.
Apr 29, 2009 | Generac Guardian Quietsource 25,000 Watt...
Blinking timer light - no power
Replace the power board and it should work, it got a spike from the unstable voltage of the generator
Dec 15, 2017 | Televison & Video
Motors fine, but no electricity - coleman 6250
pramac bought them out i just order parts today oct-15-08 call1-800-445-1805 took me awhile to get a hold of someone but she seemed to know what was going on. my guess is that the printed curciut board in the back of the generater head is bad i have had to change alot of these out.
Oct 08, 2008 | Coleman Powermate Premium Plus 6250W...
Not a 6250W but a 6500W Coleman Powermate Black Max.
Call Pramac Co. at 770-218-5430. I get parts from them every week. A service center left holding the bag when Coleman/Powermate went out. Ken's Repair
Sep 15, 2008 | Coleman Powermate Premium Plus 6250W...
Honda Mmd 5000 Watt Electric Start Generator W/  Engine Ngk 6000HE Logo
748 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
