Question about Uniden Cordless Phone
Why is the volume/ caller id button not working?
  • 98 Answers
Your phone might have been hit by humidity, and some buttons might be damaged. I would advice you to get a new one.
Posted on Jan 02, 2011
Caller ID is not displaying caller s number.....
ity is possible that the caller has blocked his number from being displayed
if other caller numbers are being displayed but not that one , that will be the case
if not reset the settings for caller id
Aug 13, 2016 | Emerson EM2646-WH Big Button Corded Phone...
The caller ID screen is so faint I can't read it. Is there a way to brighten it or change the contrast so I can read it?
. Press and hold the dial/menu button until "Options Menu" is shown in the display.
2. Use the up/down buttons to scroll through the options below, and press the dial/menu
button to select the desired option you wish to set:
• Set Language
• Local Area Code
• Set Time/Date
• Set Flash Time
• LED Contrast
• Set Tone/Pulse
• Exit Options
3. Use the up/down buttons to adjust the setting, and press the dial/menu button to confirm
and set.
NOTE: It is important to set the Area code so that the telephone can distinguish local or long
distance calls when dialing from the Caller ID list.
NOTE: Time and Date will automatically set when you recieve the first or second Caller ID
Oct 16, 2012 | Emerson EM2646-WH Big Button Corded Phone...
My phone ringer is off and I don't know how to turnit on
You may follow the steps below.
1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press mute/program button to enter the menu. SET RINGER 1HI 2LO 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2 or 3, or use the caller ID-volume
( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the mute/program button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
May 12, 2011 | GE Lands Phones
Caller id not showing
Hi If Caller ID is working on the other phones on the system , try pressing TRANSFER 119 and scroll on the volume button untill it reads caller ID . there is a website called http://www.abbeytelecom.com showing how to program the Samsung prostar, I've posted a sample
Dec 02, 2009 | Samsung Phone PDCSLCD12B
Set call rings
From the manual:
1. Press the CALLER ID-VOLUME ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press mute/menu OK button to enter the menu. SET RINGER LEVEL 5 shows in the display.
3. Use the CALLER ID-VOLUME ( 6 or 5) button to scroll to your selection. LEVEL 5 is the default setting.
4. Press the mute/menu OK button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
Apr 26, 2009 | General Electric 28811FE2 Twin Cordless...
Visual message waiting indicator
Press the mute/program button, then press the caller ID-volume button to select handset setup. Next press caller ID-volume until you get to Default settings. Use the caller ID-volume button to select 1yes. This will return the phone to the factory settings and for took care of the blinking blue light, however you will loose any custom setting or numbers you entered.
Sep 16, 2008 | GE 28112EE2 Cordless Phone
Round button in middle quits working.
Sounds like you may not be selecting the right menu buttom. The soft keys are right below the screen. these three buttons function change depending on which screen you are viewing. I have copied the instructions from the manual below. You must select phonebook to view the phone book using the round button. You must select volume to change the volume with the round button.
The Standby Screen
When the phone is in standby, the handset display shows the following items:
Handset
Ringer off icon (when the ringer is off)/ day of the week and time / battery iconHandset ID and BannerNumber of new Caller ID calls received (If there are no new Caller ID messages, the Handset ID appears here.) SUN 12:00A Handset #1 New CID: 5REDIALMENU
Using the Four-way Function Key
Your handset has a four-way function key that allows you to move the cursor (or highlighted area) on the display and access the most commonly used features at the touch of a button. By moving this key to the left, you open the Phonebook. Move the key to the right to access Caller ID information. To use this four-way key, place your thumb over the key on the station and move to the four positions to get the feel of how it moves and operates.
Using the Handset Menu
To open the menu, press the MENU soft key. Highlight the option you want by pressing the four-way function key. This will move the cursor; the option currently highlighted appears in reversed out text. Select the highlighted option by pressing the OK soft key. To exit the menu and return to standby, press [].
If you do not press a key within 30 seconds, the phone will time out and exit the menu. When setting Date and Time, the time-out period is extended to two minutes.
Note: For GLOBAL SETUP and DEREGISTRATION menu options, make sure the line is not in use and the handsets are within range of the base. 123abcdefView the phonebook Four-way Function KeyUpView the Caller IDDown123abcdefView •
Jan 31, 2008 | Uniden TRU9480 Cordless Telephone
Blue light
Press the mute/program button, then press the caller ID-volume button to select handset setup (then press mute/program again to select this option). Next press tye caller ID-volume until you get to Default settings (its the last setting so pressing the up arrow is the fastest way to it). Press the mute/program button again to select the option. Use the caller ID-volume button to select 1yes. This will return the phone to the factory settings and for took care of the blinking blue light, however you will loose any custom setting or numbers you entered.
The first time I did this it didn't work, so I did again and toward the end of the steps above the phone beeped at me and stated "Reset Default Settings" (or something like that) then time I hit the mute/program button again and everything worked great. I think that last beep maybe have been a are you sure you want to restore to default question.
Remember tis will erase any custome settings you made on the phone (ring tones, ring volume, memory, etc.)
Jan 31, 2008 | GE 28111 Cordless Phone
Blinking blue light
Jul 10, 2007 | GE 28111 Cordless Phone
Uniden Cordless Phone Logo
18 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
