I have an amana heat pump central a/c and I changed the thermostat to a honeywell and it didn't solve the problem so I reinstalled the amana thermostat now it won't power on what did I do?
    Sergeant:
    Novelist:
  • 185 Answers
Did you shut the power off to the furnace before you changed the stat? If you didn't then you could of tripped the cicruit breaker on the transformer or fuse or you could of shorted out the transformer. I would check for voltage between R and C on the control board to see if the transformer is working.You should have 24 volts AC.
recheck your wiring on the stat. General guide go down to the furnace and write down what colored wires are hooked up on control board and match up to thermostat...
Posted on Jan 02, 2011
I have Drayton Heating System in new home. I seem to be unable to put my central heating on without also having the water heater on. The boiler will come on if the water heating and central heating is on...
you will only be able to have the central heating on seperately if the system is fully pumped. Why would you not want the water to heat? it is more cost effective to use the residual heat to heat the water and keep the temperature up. Costs alot more to heat a cold house and a cold water tank
Nov 06, 2011 | Honeywell Programmable Thermostat Heater
Programmable Thermostat Heater: no power to honeywell central heating control...
Multiple possibilities:
Damage to cable (doing any DIY?)
Failure of thermo
Board gone in heat unit
Possibly simple as loose or disengaged connection, check at thermo & heat unit, if nothing obvious, call serviceperson.
May 18, 2010 | Honeywell Programmable Thermostat Heater
Central heating - room thermostat Honeywell T6360B
hI he has wired the pump to permanant live there should be link between two of them ? cannot recall which . not much help sorry
Feb 28, 2010 | Honeywell Programmable Thermostat Heater
No Auxiliaty heat with new thermostat
The Vision Pro is a great t-stat and I have installed many of them with great results. I am wondering though if it is set up correctly. Did you go in and make sure that it is set for heat pump and for 2 stage heating? Look on the instructions how to get into the advance installer options. Go through that meanu and make sure that everything ig set correctly for your type of heating system and that it is set for 2 stage heating. From what you have here and I can tell the wiring should be okay that is why I think that it is in the t-stat programming.
Nov 15, 2009 | Honeywell Electronic Programmable...
St6400c thermostat wont run the central heating independantly
This does not sound like a thermostat problem. I would be looking for a zone valve or circulator pump problem.
Nov 05, 2009 | Honeywell Programmable Thermostat Heater
Honeywell ST6400C central heating programmer fault
you may vae to enter a different "Mode" to change the time....also try removing the batteries for 10 minutes and then reprogram the thermostat again
Oct 25, 2009 | Honeywell Electronic Programmable...
I need a wire diagram of a central heat and air with a heat pump
W- White (heat)
Y- Yellow (condenser)
G- Green (Indoor fan)
C- Blue (Common 24v)
R- Red (24VAC)
O/B (Only needed if system is a heat pump)
May 07, 2009 | Honeywell Heating & Cooling
Changed out a Honeywell Thermostat with an Aprilaire Thermostat
The smell is usually dust on the wires for electric resistance heat.The thermostat shouldnt have anything to do with it.
Nov 19, 2008 | Heating & Cooling
Central heating thermostat
Looks like it was replaced by the CM67 series, try this link for the manual:
http://www51.honeywell.com/pacific/common/documents/CM67_User.pdf
Geno
Feb 29, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
