Question about Ovens
Can NOT remove glass cover to change light in oven Jenn Air W30400P
    Problem Solver:
  • 15 Answers
If it is the round glass cover it should unscrew. It is thick glass so you might need to try more force of tap it with a piece of wood.
Posted on Jan 04, 2011
Can NOT get cover off to replace bulb in oven
Assume it is the round glass cover.
It is quite robust so use more pressure. Even tal with a piece of wood.
Jan 02, 2011 | Jenn-Air W30400P Stainless Steel Electric...
Our display panel light went out on our model w30400p jenn-air single wall oven.
Make sure there's power getting to your range, oven or cook-top. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. I would also advise to inspect the junction point on the backside of the unit for a possible separation of the power cord as well. If all checks out ok, The main control board will be the culprit.
NOTE_ If your unit is equipped with a relay board, this will be the likely culprit, if all checks out ok. If there is no relay board present inside the unit, replace the main control board.
Jan 02, 2010 | Jenn-Air Ovens
How to change the oven light
jenn air usually hides the model number good lol if you open the door on the outer face of the oven might be a little grill where you can see inside and your model might be in there or it might be around the warming drawer if you have one
you need just a regular appliance 20v light bulb you can get at home depot or hARDWARE STORE  if you open the door on the back wall on the left or right upper hand side there is a glass bulb looking object , the material is thick glass/ plastic that just screws off lefty loosy right tighty once that is off you have access to the light bulb
if there is a little wire in front of the thick glass/plastic object just pull it up or down dont unhook it or break it off
Jun 07, 2009 | Ovens
Time and Temp. display on my JennAir Expressions is not working.
99% likelihood of a bad clock, part # 71001799. This is unfortunately very common with this model. Hope this helps!
Dec 31, 2008 | Jenn-Air W30400P Stainless Steel Electric...
Jenn Air oven
Does anyone know the part number to replace on model W30400P - the digital display is completely out - the oven heats up but can't read time/temp - not a thing on the LED display - thanks!
Nov 19, 2007 | Jenn-Air W30400P Stainless Steel Electric...
Jenn -air oven w30400p
Do you mean the service engineer replaced the hinges?
If so call him again and tell him he didn't fix it. The service engineer should come again and fix it for free if there's any justice in this world.
Nov 08, 2007 | Jenn-Air W30400P Stainless Steel Electric...
JennAir W30400P
i think you can get downloads from maytag.
Mar 25, 2007 | Jenn-Air W30400P Stainless Steel Electric...
Display Panel Light
There is a replacement display assembly, i think its around $150-$200. Its pretty easy to change if you are at all mechanically inclined. Good Luck!
Oct 29, 2006 | Jenn-Air W30400P Stainless Steel Electric...
Ovens Logo
70 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
